Old Dec 02, 2012, 09:14 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
So Erh7771 If I go 7S on my BL 32 will I be closer to 5 lbs thrust?
pencon is offline Find More Posts by pencon
Old Dec 02, 2012, 09:27 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Don't know, looking at the fan efficiency it might...
I'm impressed so far...I'm recharging my packs and digging out eagle true to confirm the amps...
They seem mighty low
Basically on a twin that's 9lbs of settled thrust for 2200 watts...if everything is confirmed
edit...knew the amps were a little low
4lbs 14oz\6s\70amps\ 25c gens ace...
Different scale too...so it looks commensurate with the 10 blade right now in efficiency
erh7771 is offline Find More Posts by erh7771
Old Dec 02, 2012, 10:37 PM
onefastxp is online now
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
Originally Posted by erh7771 View Post
Yes....
Just not on proper shroud but numbers are good never the less
are you saying your getting more thrust with the 12 blade rotor? with same set up as your 10 blade rotor?
onefastxp is online now Find More Posts by onefastxp
Old Dec 02, 2012, 10:48 PM
Aerobatman is online now
Find More Posts by Aerobatman
Aerobatman's Avatar
Akron, Ohio
Joined Nov 2005
A7 source
Originally Posted by mopetista View Post
Andreas, I'd also be interested in your source :-)
thx
Clemens
Andreas, me too! Can you PM me?
Thanks!
Aerobatman is online now Find More Posts by Aerobatman
Old Dec 02, 2012, 11:34 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
e,
so this is with the L2855-2300kv motor?
If so, I don't think it will take the beating...
I had similar/same numbers with the 2300kv+10 Blade +6s
anlucas is offline Find More Posts by anlucas
Old Dec 03, 2012, 05:15 AM
erh7771 is offline
Joined Nov 2005
Originally Posted by anlucas View Post
e,
No, it's a 2856 motor I found for little more than the 2300...I don't think it'll take that kinda beating either
I'll do a unloaded run of the motor and the 2300kv 2855 I have, one of them is off in KV
Old Dec 04, 2012, 05:00 PM
Alpha10 is online now
Find More Posts by Alpha10
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
I'd love to see some Cyclone 3300 4S numbers! : )
Alpha10 is online now Find More Posts by Alpha10
Old Dec 04, 2012, 06:08 PM
Alpha10's Avatar
Joined Aug 2011
Has anyone seen this yet?
Change Sun 10 blade 70mm (0 min 52 sec)
Crazy amp draw for a 3200kv motor. I hope that's not the case.
Old Dec 04, 2012, 10:15 PM
Aerobatman's Avatar
Akron, Ohio
Joined Nov 2005
CS12 on L2855-2100 6s
Finally received my CS12 to test out. Balanced the fan and it was pretty close, but it did need balancing. I used the $2 aluminum spinner as well. Mounted everything up and did the fan housing mod PeterVRC detailed: ground some of the case away for the motor wire clearance. Good news - the stock adapter I received seems to run true! So no need to purchase another adapter.
Numbers:
Motor: HK L2855-2100
Batteries: 2 Sky Lipo 2200 40c in series
Run 1, full charge:
1343 watts, 64 amps, 20.81 vm
Run 2, after about 30 seconds of half throttle:
1301 watts, 63 amps
Run 3, after about 45 seconds of half throttle:
1245 watts, 61 amps
Needless to say the motor was quite hot after these runs! Measured 155 F!
Now I need to try out that 2300kv motor on 5s next.
Old Dec 04, 2012, 10:39 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
To be able to use those numbers as any form of reference they would need to include thrust.
Though really, it is not even worth anything except as a reference against a 2100kv in a CS10, as in aircraft use terms it would be no use..... it wouldn't last long! hehe
PeterVRC is offline Find More Posts by PeterVRC
Old Dec 05, 2012, 06:46 AM
beachflyer is offline
Find More Posts by beachflyer
RC since 1979!! AMA 112747
beachflyer's Avatar
Neptune Beach FL USA
Joined Nov 2000
Definitely need to balance that unit it won't last long with those vibrations.
QUOTE=Alpha10;23442142]Has anyone seen this yet?
Crazy amp draw for a 3200kv motor. I hope that's not the case.[/QUOTE]
beachflyer is offline Find More Posts by beachflyer
Old Dec 05, 2012, 07:00 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
https://www.youtube.com/watch?v=l1md...e_gdata_player
[/QUOTE]
Yeah, you can particularly hear the unbalance at mid-throttle.
alexandermh is offline Find More Posts by alexandermh
Old Dec 05, 2012, 10:43 PM
Aerobatman's Avatar
Akron, Ohio
Joined Nov 2005
I do need to fabricate a thrust stand for myself, good point. This test was just more to see the amp draw - of course these 2100kv motors won't last too long at these amp draws as you've noted before. I'm currently running a 2300kv on 5s with the CS10 in an FMS F-16, but will be trying the CS12 soon if the weather holds here.
Old Dec 06, 2012, 12:46 PM
erh7771 is offline
Joined Nov 2005
Numbers:
Run 1, full charge:
1301 watts, 63 amps
1245 watts, 61 amps
155f is pushing it but not burning it up, I've run mine with great success using non high c packs..
I'd theorize the metal spinner helps a little with heat disipation on the shaft where it gets REALLY hot.
Old Dec 06, 2012, 01:29 PM
erh7771 is offline
Joined Nov 2005
I verticle thrust stand is easiest and injects least amount of variables
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 12:34 PM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 04:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 02:24 PM
Sold Change Sun 70mm 10 Blade EDF Twinkletoze Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 03:50 PM
Sold New Change Sun 70mm 10 blade fan. Twinkletoze Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 05:59 PM
