Old Nov 24, 2012, 12:50 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Well the 10 blades are blowing up at about 44k, so I doubt that the 12 blade will make it to 52k, but you never know. They may have beefed up the base of the blades.
And you are right about power. It would probably take over 4kw to get the 12 blade rotor to 52k.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Nov 24, 2012, 03:42 PM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
It sure does sound nice though. At least the 10 blade does.
Pepperpete is offline Find More Posts by Pepperpete
Old Nov 24, 2012, 05:41 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Don't get me wrong. I like the 10, and will try the 12 too.
Old Nov 24, 2012, 09:37 PM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Congrat for those who bought it...hope to see some comparsion of 10 blader vs 12 blader thru testing data! Amp drawn, watt and thrust figures!
cheers and happy EDFing..lol
viperviper is offline Find More Posts by viperviper
Old Nov 24, 2012, 11:05 PM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Whats the shipping time for most?
capt soap is online now Find More Posts by capt soap
Old Nov 25, 2012, 06:54 AM
FireHawx is offline
Find More Posts by FireHawx
FireHawx
FireHawx's Avatar
United States, NV, Reno
Joined Oct 2011
I paid EMS and had it in just a few days.
FireHawx is offline Find More Posts by FireHawx
Old Nov 25, 2012, 11:12 AM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Looks like the BL32 on 6s should be great with the 12 blade . I heard this motor can handle 7 s with an eflite 80 mm fan
pencon is offline Find More Posts by pencon
Old Nov 25, 2012, 01:14 PM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
i have the bL32 10 blade on 6s set up now do you think if i intall the 12 blade rotor it wil have more thrust and sound even better.
onefastxp is offline Find More Posts by onefastxp
Old Nov 25, 2012, 04:06 PM
flylow2011 is offline
Find More Posts by flylow2011
Joined Nov 2011
the problem is the motor shaft is 5mm, stock fan comes with 3.17mm and 4mm rotor adapters :-'(
another thing is how big is the motor housing of the fan? only big enough for 28mm size motors????
flylow2011 is offline Find More Posts by flylow2011
Old Nov 25, 2012, 04:09 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Get Tamjets 5mm adapter, problem solved.
If you dont like Tamjets then get one from Extreme RC in Australia.
I have bought from both and can recomend both.
Eric B.
AirX is offline Find More Posts by AirX
Old Nov 25, 2012, 08:37 PM
RockApe is offline
Find More Posts by RockApe
RockApe's Avatar
Sydney, Australia
Joined Aug 2004
test stand of awesomeness - No numbers yet. Was too chicken to run it up too far without a proper stand so this run doesn't even make 1/2 throttle.
Changesun 12 Blade 70mm EDF First Run Up (0 min 36 sec)
Thrust seems good and sounds great. Sounds even more like a Dyson vacuum cleaner than the 10 blader should sound good in the Windrider 737.
2300KV motor - 5s 3300 40C batt.
Will do some numbers testing over the next few days and post.
RockApe is offline Find More Posts by RockApe
Old Nov 25, 2012, 08:52 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
Wow you really wanted to run her up.
PAPE is offline Find More Posts by PAPE
Old Nov 25, 2012, 08:59 PM
RockApe is offline
RockApe's Avatar
Sydney, Australia
Joined Aug 2004
lol yep. I was pretty keen.
The stand looks dodgier than it really is. There's no movement in the unit when spinning it up.
Like I said I'll run it up in a real stand and post some numbers
Old Nov 25, 2012, 09:16 PM
limodune is online now
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
Thanks for posting the vid---sounds great, now lets hope there is less amp draw than the 10 blade for the same thrust, they advertize a new designed blade so I think there will be
limodune is online now Find More Posts by limodune
Old Nov 25, 2012, 09:44 PM
Aerobatman is online now
Find More Posts by Aerobatman
Aerobatman's Avatar
Akron, Ohio
Joined Nov 2005
RockApe make sure you try that fan out with the intake ring attached. You'll be surprised at the difference in sound and the increase in thrust. Next time please don't stand in front of the fan in case it decides to leave the motor - safety first!
Aerobatman is online now Find More Posts by Aerobatman
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 12:34 PM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 04:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 02:24 PM
Sold Change Sun 70mm 10 Blade EDF Twinkletoze Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 03:50 PM
Sold New Change Sun 70mm 10 blade fan. Twinkletoze Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 05:59 PM
