Old Feb 13, 2013, 08:45 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Originally Posted by anlucas View Post
It's acceptable in cool weather and if you run the motor at low rpm for a minute or so before shutting the motor down on the warmer days.
The only problem I had was that the heat loosened one of these motors off the CS10 motor mount and the motor bell touched the motor housing. This was after running the motor WOT (1000-1200w) the whole 3min flight.
The CS12 housing looks like a stronger housing and there's much more clearance for the motor bell.
I like the clearance on the 12 blade shroud but the plastic motor mount area is not very solid. I really don't like the recessed screw openings as the plastic holding the motor is very thin under the screw heads. Now I'm noticing the heat is deforming the mounting area on my 12 blade shrouds and I'm running just under 1000watts. Some type of insulation may be needed to make the shroud hold together.
Will try and work on a fix tomorrow.
Cheers
4stripes is offline Find More Posts by 4stripes
Old Feb 13, 2013, 08:52 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Cheers
You can reinforce the motor mount area with some good quality 1/8" aircraft plywood (not lite ply for sure). Rough up the plastic some and glue it in and soak it with thin CA. It will insulate and reinforce the stock shroud. It works well even on 90mm and 120mm fans.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Feb 13, 2013, 09:05 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
So that T-500 was done on a stand-off ?
Seemed a good result.
PeterVRC is offline Find More Posts by PeterVRC
Old Feb 13, 2013, 09:10 PM
PeterVRC is offline
Joined Nov 2006
I used quite large 3mm washers, so they 'bridged' well across the main motor housing 'legs'.
It all felt very solid then, but I still wasn't impressed with the whole way it is done.
You mean a ply wood plate from the rear???
A painful effort.... LOL
"Plug and pray" would have been nicer! Can't they ever get everything right!!??? hehe
I don't like the 12 bladers at all really..... I will stick with 10 blades. Even if that means only Landers available (their 10 blade rotors).
Not even sure I will use the 4 CS12's I have in anything at all!
Though I have not tested ( but will) a Lander 10 blade in the CS12 housing (because it is a larger diam than the CS10)... to see what the 7 stators help, or make worse....
But even then.... that CS12 motor mount issue makes them a nuisance anyway.... sigh
Maybe there will be a V3......?????
Old Feb 13, 2013, 09:20 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Yes the T-500 is 42mm in dia, so standoff is the only option.
The plywood reinforcement is glued in behind the stock motor mount. Then, for cooling, holes can be cut in the ply with a zip bit.
Old Feb 13, 2013, 09:32 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
That is a good plan KL. Even if the screws melt through the thin plastic mounting area, they will hold in the plywood.
Thanks Eric
Old Feb 13, 2013, 10:47 PM
genghiskt is offline
Find More Posts by genghiskt
genghiskt's Avatar
Joined Sep 2011
Thanks Eric
Not really 4stripes, unless you have a longer motor shaft. I think a 1mm carbon plate will be better.
genghiskt is offline Find More Posts by genghiskt
Old Feb 13, 2013, 11:06 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Cheers
While I like Knife's solution, I am also interested with what you might come-up with.
In the meantime, I am switching some of my 1000w+ setups to alloy housings....
Have you guys seen these ?
http://rc-castle.com/shop/product_in...oducts_id=2921
anlucas is offline Find More Posts by anlucas
Old Feb 13, 2013, 11:18 PM
PeterVRC is offline
Joined Nov 2006
I have the 90mm version..... a hefty unit, somewhat like a typical Lander alloy housing. Even heftier! And also heavier than them.
I have some 70's on the way.
They are very well designed and made..... just a bit hefty and heavy. Somewhat overkill... like Landers are.
But the 90mms are bigger in dimension than typical 90's. The 70's specs are the same as 70's.... so hopefully they are not a wasteful in their overkill. hehe
Old Feb 13, 2013, 11:19 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
I have 70mm Housing in the works to accept 36mm dia inrunners.
Stay tuned.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Feb 13, 2013, 11:26 PM
PeterVRC is offline
Joined Nov 2006
Umm, would that be best done via something made with a typical motor 'mount' tube size - just to fit 30mm if people want to (29.5mm motors), but have an extension mount (alloy) like Knife does, with an extra bearing in that.... because you really want the motor out of the fan housing area, to allow full airflow still. ???
Hmmm, maybe some 70mm rotors have 36mm, or close, diameter rotor hubs anyway - I never measured one..... then it would be ok.
Old Feb 13, 2013, 11:28 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
Stay tuned.
Please let me know how many stators?
PAPE is offline Find More Posts by PAPE
Old Feb 14, 2013, 12:34 AM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Stay tuned.
Determined to hit that 52K are you ?
pencon is offline Find More Posts by pencon
Old Feb 14, 2013, 01:05 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Those cyclone 70mm housings are more than double the weight of my 70mm housings, certainly heaps cheaper to make in china without any complex CNC machining to do but whats the end result going to be? really high quality housings are not 'that' expensive anyway.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Feb 14, 2013, 02:14 AM
efflux RC's Avatar
Joined Aug 2009
5 stators
Not with this rotor.
Although It can be used with the CS 70 rotor, it's intended for high (3kw+) power with other (cut down, 80-90mm ) rotors.
Site Sponsor
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 12:34 PM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 04:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 02:24 PM
Sold Change Sun 70mm 10 Blade EDF Twinkletoze Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 03:50 PM
Sold New Change Sun 70mm 10 blade fan. Twinkletoze Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 05:59 PM
