Sure, does the voltage matter? BTW, the weight of the motor/fan, with the aluminum spinner is 12oz (340g).
Here are a couple of shots of the fan. This motor can be fitted to the stock shroud, it just takes some time so I just did a quick test of the rotor in this shroud. |
Latest blog entry: EDF, My First Six Years, mostly Pictures
I can recheck, but I`m pretty certain that all of the numbers are correct. The loaded and unloaded kv readings are in line and unless my clamp-meter and voltmeter are defective the V and A are correct also. The motor I`m using would have to be very ineffeciant to require 60% more power to hit the same rpms. If there was that much wasted power, the motor would overheat and burn up in a mater of seconds. My motor temps are good, so I doubt that is the case. |
Just think, if you did hook up this fan to a 454 that could turn 40k, the 454 wouldn`t even know it had a fan attached. It would get the same gas mileage with or without the fan hooked up. Loaded and unloaded mileage being the same would indicate close to 100% efficiency. That`s why larger motors are better, within reason of course. Just because manufacturers make 70mm fan housings with 30mm motor mount areas doesn`t mean that is the best size motor to achieve everything that the fan rotor is capable of doing. I`m looking for performance at the upper end of the curve. Namely, high efflux speed. |
KL,
Your numbers are very different from mine. Thou i m running the CS10 not 12. What is the thrust you get @ 94a 2.7kw? My 8s run on CS10 only at half of yours number.
Sorry for the poor quality, plus no pictures of the CS and motor. |
Rutland, England
Joined Feb 2005
The problem with fast running fans...
I'm sure these little fans will take 40K rpm plus, but is it really a viable thing to do? The problem is that at such high powers/rotational speeds your theoretical g/w will be 'pants'
... and your (actual) g/w (ie taking in the electrical losses) will be even more horrible Most of the energy will be used to 'warm-up-the-atmosphere'... by the way of (very) high velocity efflux ![]() For anyone seeking much larger thrusts, you'd surely be better off considering a bigger diameter fan? |
Sorry.....Bad Data
Well, the bad numbers were a result of my esc. I need to send it in and see what CC says.
I`ve changed the earlier post with numbers on 7s With a Suppo 200a esc. A...........57A V (7s)....27.3V W...........1550W RPM.......39k 87% of unloaded KV I`ll be testing the motor on higher voltage when my new ESCs come in. |
| Thread Tools | |
| Discussion Change Sun 10 blade 70mm (Test Results Consolidated) | 901racer | Electric Ducted Fan Jet Talk | 164 | Apr 09, 2013 01:11 AM |
| Discussion Change Sun 70mm 10 blade EDF | SpaceAviation | Electric Plane Talk | 8 | Jan 22, 2013 04:06 AM |
| For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN | rlc2052 | Aircraft - Electric - Jets (FS/W) | 1 | Nov 01, 2012 02:24 PM |
| Sold Change Sun 70mm 10 Blade EDF | TreeFlyer | Aircraft - Electric - Jets (FS/W) | 5 | Mar 01, 2012 03:50 PM |
| Sold New Change Sun 70mm 10 blade fan. | TreeFlyer | Aircraft - Electric - Jets (FS/W) | 4 | Feb 29, 2012 05:59 PM |
