Joined Nov 2011
how far ahead of the fan should the foam piece be? how big is that piece of foam? photos would be wonderful :-) Usually 10 + blade fan means heavy set up and waste energy for the white sound. But I love a good light weight set up of a lesser blade fan, and some white noise by placing flat foam piece, in front or behind the fan and still have light weight and efficient system thanks |
Joined Oct 2011
Just got mine today and it seems to be made well. I ran it up on my 2W20 and it was pretty smooth outta the box! The adapter has 4 small hex bolts to attach it too the shaft and not 2 as on usuall fans. The shroud seems to be of fair quality also. I do not have the 10 blade to make a comparision too and my watt meter is currenty in the mail from HK so this is about all the fair feedback I can provide as of right now, Oh the shipping was quick from X-flite also! I hope to see more info on the thread as people get their fans, it looks to have potential.
Removing 6 blades might be something to look at. Maybe if someone breaks one blade off they can use it as a test rotor.
Latest blog entry: EDF, My First Six Years, mostly Pictures
Joined Oct 2009
I actually broke off one blade by accident on a 70mm CS10 several months ago. So after some cursing, I broke off the adjacent blade on the opposite end to make it an 8blade unit. Runs fine, although a bit noisier than before. |
Joined Oct 2011
It's going to take some power to hit 52000rpm!!!! I ran it up a few times on my Cyclone 3300 and the fan it pulled off the shaft. I only used 2 of the grub screws to attach it to the shaft on the first run up. So needless to say it needs all 4!! Solid power on the run up's but I will need a lower KV...
| Thread Tools | |
| Discussion Change Sun 10 blade 70mm (Test Results Consolidated) | 901racer | Electric Ducted Fan Jet Talk | 164 | Apr 09, 2013 01:11 AM |
| Discussion Change Sun 70mm 10 blade EDF | SpaceAviation | Electric Plane Talk | 8 | Jan 22, 2013 04:06 AM |
| For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN | rlc2052 | Aircraft - Electric - Jets (FS/W) | 1 | Nov 01, 2012 02:24 PM |
| Sold Change Sun 70mm 10 Blade EDF | TreeFlyer | Aircraft - Electric - Jets (FS/W) | 5 | Mar 01, 2012 03:50 PM |
| Sold New Change Sun 70mm 10 blade fan. | TreeFlyer | Aircraft - Electric - Jets (FS/W) | 4 | Feb 29, 2012 05:59 PM |
