Old Jan 26, 2013, 02:30 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Darmar, I will give you $10.00 for it.. Ask for another one if you want perfection. Im the same way with NEW stuff.
capt soap is offline Find More Posts by capt soap
Old Jan 26, 2013, 02:48 PM
USA, PA, Pittsburgh
Joined Jul 2001
Perfection is not the point. If I damaged it on first run, fine. This is new out of the box, screw the customer thing. No I am not selling it, thanks for the offer.
darmar is offline Find More Posts by darmar
Old Jan 26, 2013, 03:30 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Originally Posted by Eddie P View Post
This is what a $16 dollar fan looks like at times. As long as you balance it and it runs smooth you are well ahead of the game. As an example, if you bought a Shubeler 70mm fan and ran it a little out of balance you would lose more performance on an out of balance fan than you will with small nicks like that on one blade. Not that a Shubeler fan would be running out of balance unless you were using a cheap motor. Besides that, a cheap motor with a little lower efficiency will bring down overall efficiency far more than a little blade deformity I would imagine. I fly real jet engines and on pre-flight inspections I see blades that have been "dressed" to take out FOD damage below a certain level all the time. So even real jet engines have blade deformities that they pick up over time between overhauls.
Nicks are stress risers, especially the closer to the hub they are. "Dressing" them out and rebalancing definately helps.
The Shubie rotor would be less likely to grenade for any reason due to the carbon weave, but even they will go boom at high rpms if nicked in the wrong place or out of balance.
$18 or $250, it's still keeping your $800 - $1000, 70mm jet in the air.
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Old Jan 26, 2013, 08:00 PM
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
For sure any fan, let alone a $16 dollar fan, should never be allowed to be a weak point in an expensive jet. My point was actually looking at the subject from the other side of the coin. It's a cheap fan, so expect cheap components once in a while. Nobody should fly those sub standard rotors if they get them until they "dress" the nicks or better yet buy a couple rotors and cherry pick the parts. Or, buy a better quality fan that doesn't have these issues. But a $16 dollar fan is bound to have a few issues for one to overcome. It might be a bargain once it's worked out but it's still a mass produced, low QA production... by nature.
Eddie P is offline Find More Posts by Eddie P
Old Jan 30, 2013, 04:16 AM
Česká republika, Hlavní město Praha, Praha
Joined Nov 2011
Hi all,
Any tricks how to tighten the main nut on the CS12 v2? Is there any other way to hold the fan stationary not using the blades to transfer the force?
amalka is offline Find More Posts by amalka
Old Jan 30, 2013, 06:53 AM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Originally Posted by amalka View Post
Hi all,
Use a star washer between the fan and adapter. I just carfully hold a fw blades to tighten with this small fan.
4stripes is online now Find More Posts by 4stripes
Old Jan 30, 2013, 06:55 AM
Australia, VIC, Melbourne
Joined Nov 2006
File flats on the shaft adaptor end....
PeterVRC is online now Find More Posts by PeterVRC
Old Jan 30, 2013, 06:57 AM
Greece, Attica, Athens
Joined May 2011
Hi all,
I drill a hole across the end of the shaft adapter and use it to hold with a screw driver while tightening the nut.
anlucas is offline Find More Posts by anlucas
Old Jan 30, 2013, 07:22 AM
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Or file a slot on the end of the shaft adapter (ala Tam's) so you can hold it with a flat screwdriver.
alexandermh is offline Find More Posts by alexandermh
Old Jan 30, 2013, 07:24 AM
Vienna, Austria
Joined Apr 2007
or file away some of the thread on the tip (conically) using a file on the turning shaft - then you can grab the front with pliers (and still get the nut on)...
mopetista is offline Find More Posts by mopetista
Old Jan 30, 2013, 08:37 AM
Joined Nov 2005
Originally Posted by petervrc View Post
file flats on the shaft adaptor end....
+1...
erh7771 is offline Find More Posts by erh7771
Old Jan 30, 2013, 08:38 AM
Joined Nov 2005
Can this be done without ruining the threads?
I'm always thinking I'm going to walk the bit into the rest of the threads and make it unusable.
regards
Old Jan 30, 2013, 08:57 AM
Joined May 2011
The threads are affected a bit but can be cleaned up.
Old Jan 30, 2013, 09:08 AM
Vienna, Austria
Joined Apr 2007
...and the part of the thread on top can be a bit mutilated, it should be cleaned up using a steel nut (not aluminium), but there will not be any load, it should just be good enough to get the nut on the thread, that's all. The part where the nut has do to its job is further down where the thread is fine...
Old Jan 30, 2013, 10:22 AM
Joined Oct 2008
Here's what I do and it seems to work. I file a flat spot on the motor shaft witha dremel, then tighten a grub screw over the flat spot. Then tighten the shaft nut over the fan by holding the motor from behind and turning the nut with a tool. I get enough torque to tighten the nut. I don't use any locktite on the nut, in case I need to remove it. I found putting locktite on the nut causes big problems if I have to change out motors.
Mike St is offline Find More Posts by Mike St
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 164 Apr 09, 2013 01:11 AM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 04:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 02:24 PM
Sold Change Sun 70mm 10 Blade EDF TreeFlyer Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 03:50 PM
Sold New Change Sun 70mm 10 blade fan. TreeFlyer Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 05:59 PM
