Old Jan 09, 2013, 06:19 PM
LooseSox is online now
Find More Posts by LooseSox
Loose Sox Special Spec
LooseSox's Avatar
Australia, SA, Modbury North
Joined Feb 2012
Hey guys, wondering if anyone can give me some advice as to using one of these (or even the 10 blade version) with the random parts I have lying around at present?
I've got a vampire in the way, and am just a little addicted to the wooooosh noise
I've got a stash of 4s 3300 30c blue turnigy packs, a spare HW 80a esc, and a het 2w-25 (2700kv). I know it won't be a speed demon (I've got a wemotec/2w-18 viper jet for that), but should it keep the vampire running at a scale speed/sound level?
LooseSox is online now Find More Posts by LooseSox
Old Jan 09, 2013, 11:28 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Use the 12 blade.
It should end up adequate, and will have good 'whoosh'.
PeterVRC is online now Find More Posts by PeterVRC
Old Jan 09, 2013, 11:32 PM
savvy is offline
Find More Posts by savvy
Marton, New Zealand
Joined Apr 2005
I agree, I think the 12 blade will be better for the 2700. Don't know about the battery, I use a 2650 4s in mine so not sure if the 3300 might be too heavy?
savvy is offline Find More Posts by savvy
Old Jan 09, 2013, 11:36 PM
Joined Nov 2006
I use 4000 5S's even.... it flies fine even with a lot of weight. (1.6Kg area AUW).
So even though 4S 2700kv CS12-70 will be under my power level, it would have similar, or better, power to weight anyway - even with the 4S 3300 30C.
I have one of those batteries (For 4S prop use)... and even weighed it a week ago (also others), but I forget what it was! 380g area I think. It was very close to my 5S 3000mAh 20C weights - which are my main Vampire batteries.
Old Jan 09, 2013, 11:37 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I use a 4000mah batt in mine and it cg's fine...actually have a lot of room to go further forward. This is with and rclander fan/motor though so it has more weight than the stock fan/motor.
DamonH is offline Find More Posts by DamonH
Old Jan 10, 2013, 01:34 AM
LooseSox's Avatar
Joined Feb 2012
Cool, I like the sound of that! I'm at a stage now where I'm trying to base chooses for new planes/power systems around my existing packs. That being 3s 1300, 3s 2200 or 4s 3300. I have so many of them, if I can sneak a $300ish plane under the wife's radar and not have to spend another $200 on a few batteries specific to one model I stand a good chance of my balls remaining attached to my torso! lol
Old Jan 10, 2013, 10:15 AM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
I'm looking at putting together a pair of these 12b fans into my Projet A-10 and I am in the market for some new motors to fit it. I would like to run them on 4s packs with the option for the occasional 5s. If the numbers for the 12b is very similar to that of the 10b fans then I would imagine a motor with kv somewhere in 2800-3000 range would be ideal. But what about the Arc 28-58-1 at 3180kv? Perhaps a little too much rpm? Any suggestions for a better sized motor of that similar quality?
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Jan 10, 2013, 07:14 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Whalleyboy your Arc would be great for that fan on 4S I would think . I 'm thinking of using my Het 1w-40 with the 12 blade on 4s or maybe even 5 and that's even higher KV than your ARC (3300 ) The 12 blade seems to be a lot tougher than the 10 blade , especially the housing
pencon is offline Find More Posts by pencon
Old Jan 10, 2013, 07:25 PM
Joined Nov 2006
3300kv on 5S... yikes....
48K RPM area..... the 12bl MIGHT cope with that.
2550kv is already well into 60's amps.... 2300kv around 50 area or so....
3300kv.......????? 80....90....100???
Not likely to be viable.
It is already pretty high power on 4S.
Old Jan 10, 2013, 08:34 PM
Alpha10 is online now
Find More Posts by Alpha10
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
Agreed. 3300kv on 4S is basically max effort at around 80amps
Alpha10 is online now Find More Posts by Alpha10
Old Jan 11, 2013, 09:45 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Is anyone running this 12 blade on 6S? Not looking for crazy performance, just something in the 50-60A range so that it can be used in a twin on one 6S battery. I'm testing the L2855-2100 outrunner but having issues with vibration as the motor isn't running smooth (even without the fan). I bought the XK2845-B-2000 but it doesn't look suitable with its small shaft and tiny wires. It is also resisting being taken apart to add cooling holes. I think it has a fair bit of locktite on the end cap treads.
Thanks for your input.
Eric
4stripes is online now Find More Posts by 4stripes
Old Jan 13, 2013, 02:34 PM
FANtastic is offline
Find More Posts by FANtastic
Joined Sep 2010
What would be the best set up for this fan for light weight in my Jet Provost. AUW only around 1KG. Not looking for massive performance numbers or long flight times .
FANtastic is offline Find More Posts by FANtastic
Old Jan 13, 2013, 02:58 PM
4stripes's Avatar
Joined Jan 2009
Ran the 12 blade on a tired 6s with the 2855 2100kv outrunner. Initial amp draw was around 62a. This is too high for my application so I tried the 10 blade in the same shroud and got 58a. The 12 blade has more load than the 10.
At 62a the outrunner got hot pretty quickly and I doubt it would last at wot very long.
I am thinking the 2100 may be better suited for 5s.
anyone else running the 2855 2100?
Old Jan 13, 2013, 03:00 PM
rufu is offline
Find More Posts by rufu
Germany, NRW, SG
Joined Nov 2007
Have the ChangeSun 70 mm 12-blade impeller in my Alpha Jet eingegbaut.Fly him 30 c of 2800 mAh zippy with 4S.Level measurement in the model 1050 grams 56 ampHK Outrunner tuning L2855 2800Um-864W engineAlpha Jet is well lawn.
Gruß rufu
rufu is offline Find More Posts by rufu
Old Jan 13, 2013, 04:39 PM
Joined Nov 2006
My L2855-2300kv tests on 5S gave as good as identical results on the CS10/12
That is the only comparison test I have done.
I have a CS10 L2855-2100kv in my BAE Hawk
Bench test 44A 788W 1.36Kg Thrust on a 5S 4000mAH 30C
I am sure it would do some amount bit better on a Nano etc.
(Twin 30C gave 46A 864W 1.41Kg thrust)
Don't know if this link works:
https://www.youtube.com/user/MrPetersVideo?feature=mhee
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 01:34 PM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 05:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 03:24 PM
Sold Change Sun 70mm 10 Blade EDF Twinkletoze Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 04:50 PM
Sold New Change Sun 70mm 10 blade fan. Twinkletoze Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 06:59 PM
