Old Dec 12, 2012, 05:14 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
Well i flew the vampire with the 12 blade fan and all i can say is. The sound is the best I have herd from all the high blade fans.
Also the sound was louder than the 10 blade fan. Normaly a perfectly balanced cs10 is to quite at a distance. With the 12 blade fan on the vampire the woosh sound is herd all the time. But take in considerarion I never flew the vampire on a cs10. Only other planes, and the vampire is a whooshy airframe. So that might have to do with some of the whoosh.
PAPE is offline Find More Posts by PAPE
Old Dec 12, 2012, 05:15 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Oh ok, I guess that then makes a good comparison of "ExtremeRC housing with CS10/CS12".
And they will have different blade tip clearances, seeing the CS12 is a larger rotor diameter, so whilst that makes the test 'unequal' it is not unequal a test if the stated criteria is that "In an ExtremeRC alloy housing".
I would expect the CS12 then gets better thrust (tho hardly any amazing, or overly useful, amount) - seeing its tip clearance tolerance would be less... probably half (two thirds?) that of the CS10.
PeterVRC is offline Find More Posts by PeterVRC
Old Dec 12, 2012, 05:16 PM
PeterVRC is offline
Joined Nov 2006
You can hear a CS10 Vampire from as far away as you can see it!! LOL
(well at least with 850W - though I fly it at probably 600w really)
Old Dec 12, 2012, 05:24 PM
PAPE is offline
Joined Jun 2012
Yeah thats what I thought. But i could only hear whoosh no motor whine. All my other cs10 just go silent to the point that you have no idea if the motor is runing or not.
Old Dec 13, 2012, 06:32 PM
microlyn is offline
Find More Posts by microlyn
Fly it like you're in it
microlyn's Avatar
Canada, ON, London
Joined Nov 2012
Geat thread!
Just wondering how this setup
http://parkrcmodels.com/product_info...oducts_id=1407
would compare to the cs12/70mm with say an het or cyclone
I will be running a pair in my Dynam me 262 on 4s 5000mah 35-70c pack
not sure which way to go.
I would like the more scale sound and prefer take off performance,reliability, and maybe even longer flight times to all out speed.
Any advice would be appreciated.
thanks
microlyn is offline Find More Posts by microlyn
Old Dec 13, 2012, 06:43 PM
PAPE is offline
Joined Jun 2012
Its going to pull to many amps at Wot, its beter to get lower KV motors or maybe a 6S set up.
Old Dec 13, 2012, 08:05 PM
PeterVRC is offline
Joined Nov 2006
Yes, you would be far better off getting the 6S versions of those fans and using 6S.
It would actually be overkill, as I run 5S 2300kv CS10's and that only needs 40% to 50% throttle to fly scale, and WOT is "overly fast" - which is a relative term... hehe.
But using CS10 with L2855-2300kv cost only $30 each, so it is a very cheap effective power combo.
Old Dec 16, 2012, 11:01 AM
larry11 is offline
Find More Posts by larry11
I haven't had a chance to read through this entire thread.
But,
What is the hot setup for this fan?
What would be a good motor,esc,battery combo?
larry11 is offline Find More Posts by larry11
Old Dec 16, 2012, 11:04 AM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
since the 12-blade is pretty much the same load as the 10-blade you can go by the results of the CS70 data thread
http://www.rcgroups.com/forums/showthread.php?t=1601868
mopetista is online now Find More Posts by mopetista
Old Dec 17, 2012, 12:52 AM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
When will rc lander add the 12 blade fan to there combo edf cs package???
capt soap is offline Find More Posts by capt soap
Old Dec 17, 2012, 05:11 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Has anyone found any 1900 or 2000kv motors that fit this fan? Looking to have lower amp draw for a twin setup on 6S.
4stripes is online now Find More Posts by 4stripes
Old Dec 17, 2012, 11:50 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
I found this one that comes close....
http://www.hobbyking.com/hobbyking/s...dproduct=21480
It should pull around 35A max on 6s.
I tested it's 3000kv brother and they are of good quality.
This inrunner should also do
http://www.hobbyking.com/hobbyking/s...dProduct=17725
anlucas is online now Find More Posts by anlucas
Old Dec 18, 2012, 05:37 AM
4stripes's Avatar
Joined Jan 2009
Thanks Anlucas!
The 2000kv inrunner looks ideal. Not sure 1800kv would be powerful enough.
Cheers
Old Dec 18, 2012, 09:36 AM
Vienna, Austria
Joined Apr 2007
the 2000kV inrunner should be well suited for 6s on the CS70 - but how will it dissipate heat w/out cooling holes?
I would worry about overheating (and bad efficiency, if not failure)
anybody running this motor?
thx for the link, Andreas, anyway
Old Dec 18, 2012, 10:00 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
When I click on the link above for the 2000kv motor it takes me to one that is listed as a 11.1 max volt 3s motor. Is the link taking me to the wrong motor or are you saying that 3s motor is safe to run on 6s?
DamonH is offline Find More Posts by DamonH
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 12:34 PM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 04:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 02:24 PM
Sold Change Sun 70mm 10 Blade EDF Twinkletoze Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 03:50 PM
Sold New Change Sun 70mm 10 blade fan. Twinkletoze Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 05:59 PM
