Old Dec 11, 2012, 10:50 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Originally Posted by erh7771 View Post
...and bigger can holder, more stators, longer though...
It's like the took the cad data for the 90mm and shrunk it, well worth the extra dollar over the 10blade and the 2usd for the metal caps.
I've heard more tip whine at lower RPMs but that's OK for me cause now I'll put it in more planes seeing I'll be able to hear it now
What RPM are you running it at where you are getting the tip whine? I haven't run mine yet, but with the different blade angle, I had assumed that the RPM of the 12 blade should be similar to the 10 blade.
alexandermh is offline Find More Posts by alexandermh
Old Dec 12, 2012, 05:47 AM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
I did some back to back tests today on the 10 and 12 blades.
The sound is better on the 12blade as you can see in the videos.
Also the amps/watts are really close, so what maters here is thrust... I dont have any thrust numbers yet but I will maiden my Vampire with the 12blade fan later today and see how it sounds in the air.
Enjoy
10blade
Change sun 70mm 10 blade fan on 4s Het 2W25 2720KV (0 min 31 sec)
12blade
Change sun 70mm 12 blade fan on 4s Het 2W25 2720KV (1 min 9 sec)
PAPE is offline Find More Posts by PAPE
Old Dec 12, 2012, 07:18 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Good Job!! nice videos.
Let us know the thrust figures once u hv measured it. cheers!
viperviper is offline Find More Posts by viperviper
Old Dec 12, 2012, 10:16 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
The RPMs are similar
, I haven't really compared the two side by side like the previous poster has done either so the sound of tip whine at low RPM is subjective
erh7771 is offline Find More Posts by erh7771
Old Dec 12, 2012, 03:03 PM
Alpha10 is online now
Find More Posts by Alpha10
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
Enjoy
10blade
http://www.youtube.com/watch?v=NJFjlW0z5hQ&feature=plcp
12blade
http://www.youtube.com/watch?v=P9YGVCzmi84&feature=plcp
Great man! I think these things would ROCK on a 3300kv inrunner of we could keep the draw under 80 amps.
My 10 blade pulls 68A on a 3300kv Cyclone.
Alpha10 is online now Find More Posts by Alpha10
Old Dec 12, 2012, 03:26 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Is that a 4s or 5s setup?
DamonH is offline Find More Posts by DamonH
Old Dec 12, 2012, 03:29 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
A10 thanks for the tests and videos, but I think you should have been using a lip on the shroud. Were you using metal shrouds in the test?
clive45 is offline Find More Posts by clive45
Old Dec 12, 2012, 03:47 PM
dougind is offline
Find More Posts by dougind
United States, OH, Toledo
Joined Dec 2000
Cs12
I've been watching this thread as this is my first EDF
Do you have to press the arbor through the fan
It seems like a press fit or should I make it a slip fit and glue it in place.
Please be gentle this is my first time.
dougind is offline Find More Posts by dougind
Old Dec 12, 2012, 04:22 PM
limodune is online now
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
I have just done some test's with this new fan in it's housing and lip attached, sorry no thrust figures, fresh 4s battery used 4500mah 25-50c nano tech
Test 1.10 blade fan L2855 2300kv 41amp 600wt ---no lip 31amp 450wt (just wanted to see how much gets lost)
Test 2. 10 blade fan L2855 2800kv 55amp 810wt
Test 3. 12 blade fan Tacon 2855 2618kv 64amp 915wt ( last test on the battery)
limodune is online now Find More Posts by limodune
Old Dec 12, 2012, 04:30 PM
Alpha10's Avatar
Joined Aug 2011
4S 3300mAh 65c
Old Dec 12, 2012, 04:32 PM
Alpha10's Avatar
Joined Aug 2011
Test 2. 10 blade fan L2800 2800kv 55amp 810wt
Looks like the amps shoot up QUICK with even a little kv : /
I hope the thrust numbers do it justice
Old Dec 12, 2012, 05:08 PM
erh7771 is offline
Joined Nov 2005
Thrust test should be done with lip for accuracy...
regards
Old Dec 12, 2012, 05:22 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
What alloy housing fit the 12-blade?
The videos don't show the first fan... maybe it was a stock plastic housing?
They sounded the same to me, but if there is a bit of difference there would be if they were in different housing types too.
You have to use a lip to get true numbers. Seeing the numbers were close that means both had no lips.... but the stock plastic housing would have a different 'edge' than alloy, so one would flow that bit differently. Tests need to be in the same housing type, which in this case pretty well means both in their stock housing.... or both in the same brands alloy housing. eg a CyclonePower will be different to an ExtremeRC... not a lot, but a bit.... due to a very likely inlet lip difference (CP have their own, ERC would use the stock lip). But anyway you want a lip.. and the same lip for both test setups too. (or at least what they gave you with the stock fan itself).
Seeing the bits are not interchangeable... or rather, you just get whatever comes with each version, most people will only have those bits (that came with that fan - CS10 or CS12), so a comparison of most use for the masses is just using the stock fan of each type, just as they come.
PeterVRC is online now Find More Posts by PeterVRC
Old Dec 12, 2012, 06:07 PM
PAPE is offline
Joined Jun 2012
Both test were done in the same exreme alloy housing from mark. They were the same no lip and 2650 4s lipo 45c. The 12blade fan fits tight but if balances perfectly like i did. It dosent rub.
Old Dec 12, 2012, 06:13 PM
PAPE is offline
Joined Jun 2012
Well i flew the vampire with the 12 blade fan and all i can say is. The sound is the best I have herd from all the high blade fans.
Also the sound was louder than the 10 blade fan. Normaly a perfectly balanced cs10 is to quite at a distance. With the 12 blade fan on the vampire the woosh sound is herd all the time. But take in considerarion I never flew the vampire on a cs10. Only other planes, and the vampire is a whooshy airframe. So that might have to do with some of the whoosh.
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 01:34 PM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 05:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 03:24 PM
Sold Change Sun 70mm 10 Blade EDF Twinkletoze Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 04:50 PM
Sold New Change Sun 70mm 10 blade fan. Twinkletoze Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 06:59 PM
