Old Nov 15, 2012, 02:12 AM
henkster is offline
Find More Posts by henkster
United States, NV, Verdi-Mogul
Joined Mar 2012
MediaTek GPS and eLogger V4
I have a MediaTek GPS unit from a Remzibi OSD on eBay - don't do it kids! it was sold as genuine, isn't, stopped working within an hour, and I have an ongoing eBay dispute. Complete and vocanlo has not been at all helpful.
I decided to go a little more upmarket with Eagle Tree stuff, and got an eLogger V4, Pro OSD, and Guardian. Now i'm out of budget, so wanted to see if I can make use of the GPS unit I have left over.
Can I assume that I can connect the MediaTek GPS to the eLogger?
I hooked up a connection by matching cable color to connections and the GPS unit's LED comes on, but doesn't make the "normal" flashing when it's trying to aquire satellites. So I've either got something hooked up squiffy, or there's an issue with the baud rate or protocol, or something. I'm a bit of a newb, so I'm a little lost.
I have a FTDI and read that I can chat with the firmware using a terminal. Anyone know more specifics? Such as the command I'd need to use to change the settings so it'll work with the eLogger?
henkster is offline Find More Posts by henkster
Old Nov 16, 2012, 07:49 AM
dhares is offline
Find More Posts by dhares
Saline, MI
Joined Jul 2006
I can help a little bit. Here's what I know:
Wire usage:
Power - Red
Ground - White
Data From eLogger to GPS - Yellow
Data From GPS to eLogger - Brown
ET sends one initialization command to the GPS on startup, then just listens passively. I believe that command causes the GPS to output some standard ascii data stream. Hope this is of some help.
dhares is offline Find More Posts by dhares
Sold OSD Pro Pkg with V4 100A eLogger and GPS / Guardian (((SOLD))) bah7566 FPV Equipment (FS/W) 5 Aug 21, 2012 05:36 AM
Sold Eagle Tree OSD Pro, eLogger and GPS V4 $180 Blucross FPV Equipment (FS/W) 3 May 19, 2012 07:50 AM
Sold Eagle Tree Systems OSD Pro, GPS V4, eLogger V4, and Guardian constantmotion FPV Equipment (FS/W) 8 Apr 15, 2012 10:26 AM
Sold Eagle Tree Systems ELogger V4 150A GPS V4 Expander willy43 FPV Equipment (FS/W) 0 Mar 11, 2012 07:42 PM
Discussion Current draw of ELogger V4, OSDPro, GPS V4 Ironhead Eagle Tree Systems 3 Mar 02, 2011 08:29 AM
