Old Nov 15, 2012, 01:44 AM
heli_madken is online now
Find More Posts by heli_madken
Liverpool, England
Joined Jan 2005
Build Log
BAC 167 Strikemaster Scratch Build
Hi Everyone, This is my first Jet Build which I am undertaking for a friend.
Subject is the BAC 167 Strikemaster with the following dimensions etc -
Jetcat P80SE
Wingspan - 2.2m
Fuselage - 2m
Airfoil - Clark Y
Incidence - 1'
Dihederal - 5'
Construction will be traditional built up balsa, hoping to keep the airframe under 3kg
As its my first Jet build I need lots of help so please chip in
Completed the basic wireframe drawing which to some extent is the hardest part, next stage is to work out the position of all components and source things like the exhaust, fuel tank, retracts etc.
Any help/opinions would be appreciated
Ken
heli_madken is online now Find More Posts by heli_madken
Old Nov 23, 2012, 07:11 AM
Liverpool, England
Joined Jan 2005
Hi,
Got the basis of the wing construction design completed.
Wing tubes are carbon fibre, frames are a mixture of 1/8th and 3/16th liteply. Outer wing tanks will be glassfibre.
A good portion of the wing will be built into the fuselage to house the undercarriage
Any advice on the size of fuel tank?
Let me know if I am not posting in the right place
Old Nov 23, 2012, 09:41 AM
Liverpool, England
Joined Jan 2005
I am looking at a Dubro 50oz / 1500cc tank, do you think this is big enough?
Working out the CG and placing the tank on it gives me a good indication where the P80 can go giving some room for airflow, CG is 186mm back from the LE
Not sure if I worked out the wing loading seems far too low I guess I may have the max Cl wrong
Old Nov 25, 2012, 02:42 AM
Boomerang1 is offline
Find More Posts by Boomerang1
You made that out of trees?
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
I think you will be short on fuel.
The sports model I fly is about the same size (AUW 9kg + fuel) with a similar thrust engine (Wren SS) & I have the 50oz tank in series with a 20oz tank plus the header tank which you should never include in your available fuel.
My flight timer is set for 7:40, comfortable for a start, taxi, reasonable length flight & a taxi back. I guess a taxi tank would give another couple of minutes of flight time. - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Nov 26, 2012, 01:31 AM
Liverpool, England
Joined Jan 2005
Thanks John thats a great help, there is plenty of room so I can move up to the 80oz/2.4Ltr tank no problem.
Old Nov 29, 2012, 09:15 PM
FOShowNoClass is online now
Find More Posts by FOShowNoClass
SDF
Joined Sep 2002
Here's one I am trying to do for 90mm EDF. It's Jet Provost T3. Love the T5/Strikemaster.
FOShowNoClass is online now Find More Posts by FOShowNoClass
Old Nov 29, 2012, 09:26 PM
SDF
Joined Sep 2002
Was just looking at your wing tube placement. Depending on the area between the tire and rear of the main spar, could you use a carbon fiber or aluminum blade for the wing joiner instead of the tube? You can even do a split spar where you could have a blade in front of the wood spar and one behind it to form a sandwich that will just slide around the wood spar in a C channel. Just a thought...
Will
Old Nov 30, 2012, 01:41 AM
Liverpool, England
Joined Jan 2005
Hi Will that looks phenomenal, keep us posted on the build
Interesting concept for the wing joiner, I have spent the last week changing the design of the wing to stressed skin construction so will work out if the idea works better
Thanks, Ken
Old Nov 30, 2012, 05:07 PM
SDF
Joined Sep 2002
Here is a T5 version I drew in Sketchup. Can't get the nose section just right...
Old Dec 06, 2012, 04:02 PM
SDF
Joined Sep 2002
Been reworking the model some. Intakes enlarged 9% from scale to get 100% FSA of a 90mm fan (7.6 square inches). Wingspan is 60". Length is 51".
Old Dec 14, 2012, 01:49 AM
Liverpool, England
Joined Jan 2005
Looks great Will, I will soon need to be thinking about intakes
I dont think I have ever spent so long designing a wing! I made two decisions, first to change to stressed skin construction so I needed to enlarge the wing ribs by 1mm and take away the cut notches for the stringers, then thought that Will's suggestion of a flat spar joiner was a good one and re-designed the whole wing to suit.
I think it has worked out well, will be stronger and lighter, using 2mm carbon for the spar and pockets into which it slides
I still havent finished yet as I need to think about how flaps and ailerons will work
Old Dec 14, 2012, 10:41 PM
SDF
Joined Sep 2002
Ken,
Just go a new router after my last one went out on me. Progress looks fantastic! I hope your new spar works out. It looks like a much cleaner install than a what the tube would have been. Think it's lighter?
Will
Old Dec 28, 2012, 03:15 AM
machine man is offline
Find More Posts by machine man
Joined Dec 2012
Hi Ken
Just found your thread while researching for info on the Strikemaster, I am planning to be building a scratch built 1/4 scale. The biggest problem I saw was the wing attachment as previously built models with two main wing panels plugging into the fuzz can suffer from wing failure, like you I propose to do a 3 piece wing with the center section carrying the retracts and the tips plugging in similar to your design. I would like to possibly incorporate the center section into the fuzz like you intend but width may be a problem at around 42", for storage & transport. I will follow your build with interest.
Dave
machine man is offline Find More Posts by machine man
Old Dec 31, 2012, 05:45 AM
Joined Dec 2012
Ken I think you graphics of you design are great, I am still in the age of drawing out on lining paper. What drafting package are you using.
This is the info on the Strikemaster I have to date.
Full size
Span 36' 10" over Tanks
Length 33' 81/4"
Dihedral 6 degrees
Incidence at root 3 degrees
Incidence at tip 0 degrees
Root width 7' 8"
Tip width 4' 4"
Wheel track 10' 8.9"
Wheel base 9' 7.4"
Main wheel 24" dia
Nose wheel 16" dia
Aifoil section NACA 2315 (modified) at root NACA 4412 (modified) at tip
Tail span 13' 6" ( I do not have the tail incidence as yet )
From this at 1/4 scale I will have a span of 2807 mm with a root chord of 584.5 mm and tip chord of 330.5 mm. Depth of rood rib 85 mm, depth of tip rib 45 mm. 100 mm nose wheel & 150 mm mains which will be great for grass.
Length will be 2567 mm with a tail of 1030 mm. Power to be Wren Pro 160 with estimated weight dry 42 lb (19 kg). Retracts will be Premier UK units 85 degree reverse acting mains and a 90 degree nose unit with custom legs supplied by Kingfisher Aviation.
Old Dec 31, 2012, 09:02 AM
Joined Dec 2012
Just found some more info contradicting my previous posting regarding wheel sizes.
Mains are 21" dia x 6.75"
Nose are 16" dia x 4"
so my mains will be down to 5.25"dia which are still ok for grass.
Discussion Martin 167 Maryland design and build. RyanPSU21 Scale Kit/Scratch Built 189 Oct 14, 2013 07:29 AM
Found Wanted: PLD-BAC-ESJ; Combo BAC switchjack wdwimbish Aircraft - Sailplanes (FS/W) 1 Sep 06, 2012 02:12 PM
Discussion f-15 build Foam scratch build, wanna go faster Foamies (Scratchbuilt) 60 Sep 03, 2012 11:57 PM
Build Log BaC F-6 Lightning EDF from GAD build mjblack Foamy EDFs 81 Nov 11, 2009 09:10 AM
