Old Nov 15, 2012, 01:01 AM
johnwohl is offline
Find More Posts by johnwohl
United States, ND, Fargo
Joined Aug 2007
How do I clamp a torn fuselage?
Hey, I'm wondering if there isn't a better way to do this.
We all know what happens when EPO aircraft hit the ground a little too hard. Fuselages can rip and break.
How does one best repair a crack or tear about the circumference of the fuselage (as opposed to along the length), especially if it is a partial crack and not fully broken all the way around?
I use 30 minute epoxy because I find that CA eventually comes loose, hot glue sets to quickly, and I've never had an epoxy repair break in the same place. I use the 30 minute because it isn't as brittle and seems to "bite" more than the quick stuff.
How does one clamp a repair like this while it sets? Holding it tight and still until the glue sets up is very annoying and sometimes painful. I cant really see how to clamp it effectively from the front and back, even if I had a big enough clamp, and simply clamping the side doesn't give pressure in the proper direction.
I thought about maybe using bamboo skewers on either side of the crack and bringing them together with clamps or bands to hold the crack shut but then I end up with more holes in my plane and what could be weak points with the potential for starting additional cracks.
ideas?
johnwohl is offline Find More Posts by johnwohl
Old Nov 15, 2012, 08:52 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
If the fuse is strong enough to take a light weight clamp either side of the break you could try rubber bands on these to pull it together;or even another clamp across them.
Masking tape can sometimes be enough.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 15, 2012, 09:14 PM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
I use 5 min but when you put it on wiggle the two bits togethor. If you don't already do it you will see just how strong it is
scrub monkey is offline Find More Posts by scrub monkey
Old Nov 15, 2012, 10:21 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I agree with Stupot. Masking tape is a pretty good thing. It has a tiny bit of stretch. Several strips across the joint should do the job. Just make sure is is clean so the tape will stick.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my other senator
Old Nov 19, 2012, 11:05 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
i've found that packing tape is my friend for these kind of jobs
CrashAffinity is offline Find More Posts by CrashAffinity
Old Dec 08, 2012, 05:45 AM
Berkie is online now
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
You can't beat hot melt for foamies.
Once repaired it may still be mishapened so dunk it in hot water for awhile, but not too hot otherwise the hot melt will melt again
Berkie is online now Find More Posts by Berkie
Old Dec 15, 2012, 10:52 PM
rrg is online now
rrg
Find More Posts by rrg
rrg
rrg's Avatar
United States, KY, Edgewood
Joined Dec 2007
Rubber bands plus masking tape here....
rrg is online now Find More Posts by rrg
Old Dec 16, 2012, 04:36 PM
rockyabq is offline
Find More Posts by rockyabq
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined Apr 2008
Two 18-inch-long lengths of aluminum angle iron held on with several wraps of tape will keep the fuse perfectly aligned while the epoxy dries.
rockyabq is offline Find More Posts by rockyabq
Discussion how do you cover a balsa planked fuselage with ultralite? FlyBoysRc Scale Kit/Scratch Built 5 Aug 06, 2012 04:08 PM
Question how do you make fuel line clamp from a piece of fuel line?? nakman8 Engines 6 Mar 18, 2010 06:42 PM
How do I use my Craftsman clamp meter #82014? papasmurf Power Systems 9 Feb 15, 2010 01:13 AM
How do I stop the prop parallel to the fuselage sides? neonbutterfly Power Systems 4 Feb 16, 2003 11:28 AM
How do you straighten a fuselage on a Edge 540 Parkflyer Sport Planes 7 May 21, 2002 07:03 PM
