Old Nov 14, 2012, 08:18 PM
DYORD is online now
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
KK2.0 Board ESC Calibration
I just tried calibrating my ESCs using the KK2.0 board. Followed the steps by holding the buttons 1 & 4, Tx at full throttle. Once i plugged the battery, motors start spinning at full throttle. It didn't go to programming mode. Did this couple of times to make sure that I'm holding the buttons 1 & 4. Same thing happen. I had no choice but to reprogram the ESCs one by one.
DYORD is online now Find More Posts by DYORD
Old Nov 15, 2012, 12:46 AM
albx is offline
Find More Posts by albx
albx's Avatar
Italy
Joined Jun 2007
firmware version?
albx is offline Find More Posts by albx
Old Nov 15, 2012, 12:58 AM
DYORD is online now
Joined Apr 2012
I think it's the earliest where ESC calibration instructions are still there. Probably 1.1? Just ordered the USBasp. But for now, I'm forced to calibrate the ESCs one by one.
Old Nov 15, 2012, 01:54 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
Calibration is in every version, after the 1.1, if i'm not wrong, was made simpler... in 1.1 you need to go in the menu and calibrate from there, with the 1.2 and later you have to do like you are doing now.. keep pressed button 1 and 4 while powering the board with full throttle... Update your firmware or look at the menu
Old Nov 15, 2012, 01:56 AM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
The KK2 ESC calibration method has never changed. Its the same from 1.0 through till 1.5
Here is a video I made of the process:
Calibrate ESC's using the KK2 Board (0 min 50 sec)
AcroFPV is offline Find More Posts by AcroFPV
Old Nov 15, 2012, 02:20 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
http://www.youtube.com/watch?v=qAaO6lyN0HI
No, it was different in the first firmware version, I remember it was more complicated.. you had to go in the menu and do it from there.. then KK changed it and made simpler
Old Nov 15, 2012, 02:28 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
No, you are wrong.
The process has never changed. In 1.0 there was a menu option for ESC Calibration, but all it did was give you directions on how to perform the ESC calibration. The method never changed, it has always been the same.
That video I made, was made with v1.0 firmware.
Old Nov 15, 2012, 02:41 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
No, you are wrong.
Listen.. in the first version you hsd to go in the menu, later it was removed, so isn't changed? Maybe you don't understand what I mean.. the calib with the 2 keys isn't changed, but early version didn't let you do it right now, you HAD to go in the menu and start it, it didn't worked if yiu powered the biard with the buttons pressed like now
Old Nov 15, 2012, 03:53 AM
ElectroDie is offline
Find More Posts by ElectroDie
Joined Oct 2012
Originally Posted by kapteinkuk View Post
Note that ESC calibration is a bit simpler now. You can plug in the battery and then press the buttons, since the welcome screen adds a bit delay. No need for 4 hands
Since 1.2
ElectroDie is offline Find More Posts by ElectroDie
Old Nov 15, 2012, 04:30 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
Originally Posted by ElectroDie View Post
Since 1.2
Thanks, I'm with my phone couldn't search it, I remember how difficult was for me, had to ask my wife's help to do the calib.
Old Nov 15, 2012, 06:47 AM
DYORD is online now
Joined Apr 2012
Ok, here it is: (i think)
There's a menu says esc calibration, then tons of instructions. I think menu is just there for the instruction.
Old Nov 15, 2012, 07:24 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
DYORD, If you can update the board's firmware is better, to 1.4 if you don't need to drive a gimbal, otherwise to 1.5. Calibration is made easy, you really need 4 hands to do it right now with this version, and some bugs where fixed with newer versions
Old Nov 15, 2012, 08:15 AM
DYORD is online now
Joined Apr 2012
I just ordered usbasp. And its on its way! Will let you know after the update!
Old Nov 15, 2012, 09:49 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
LISTEN! Maybe YOU dont UNDERSTAND!
THE PROCESS NEVER CHANGED! The only thing 1.2 did was remove the instructions from the menu, and added a short delay on bootup. The process is still the same.
Old Nov 15, 2012, 10:17 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
subaru4wd, it's good that your posts are hidden.... I love this forum
Question Esc Positive Wires to KK2.0 Board CH33ZEBURG3R Multirotor Talk 9 Dec 16, 2012 01:33 AM
Discussion KK2.0 and HK Blueseries ESC Calibration momofx Multirotor Talk 3 Oct 04, 2012 01:59 AM
Discussion KK 3.0 Board Won't Arm or Calibrate Guru06 Multirotor Talk 2 Sep 25, 2012 12:43 AM
Mini-HowTo Video - Calibrating ESC's using the KK2 board. AcroFPV Multirotor Electronics 0 Sep 17, 2012 12:00 PM
Discussion ESC Calibration with 4.0 Software Bonzer1 Hoverfly Technologies 14 Apr 22, 2012 09:58 PM
