Old Nov 14, 2012, 12:10 PM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Wicked Wemo/6000kv on 4s: Don, have you seen this?!
Taken from the Skyangel 50mm thread in the Foamy EDF section:
Originally Posted by gooniac33 View Post
What an awesome day to fly yesterday!! It was 68 degrees and next to no wind! Got to fly the fleet of 50mm's and ran into Micromantis while I was out there. He had his new Screamer out there with Don's Wicked Wemo 6000kv set up ON 4S!!!!!!! Words can't describe how well this thing flies and how insanely fast it is!!! I was able to get some stick time with this little beast and then shot this video....
http://www.youtube.com/watch?v=AdWuspG4RnI
What's the expected lifespan of the motor/fan? What size 4s battery/ESC would you need to support this?
Amazing!!
MRGTX is offline Find More Posts by MRGTX
Old Nov 14, 2012, 04:17 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Unknown. It was never intended to run 4S in that fan due to the high watts. If he is getting full watts on 4S then with the thrust tube it should be about 120mph! I would make sure the rotor does not spin on the adapter which means it will probably have to be glued on and balanced very well.
Amazing!!
Well in theory if 380 watts on 3S, then going to 4S would be about 700-750 watts at 50-55 amps. Typically I don't recommend any of the regular wicked motors to be run over 600 watts. The 6000KV has thicker windings so might be OK if not run WOT all the time. This is uncharted territory
The Don is online now Find More Posts by The Don
Old Jan 16, 2013, 08:32 PM
Madman133 is offline
Find More Posts by Madman133
Madman133's Avatar
USA, CO, Golden
Joined Nov 2010
So say I wanted to possibly try something like this out...what esc's what be good at that high of rpm? The hobbywings are only rated to 70,000 rpm while this setup would be 90,000+ rpm.
Anyone know? I can't find specs for max rpm on most esc's
Thanks!
Taylor
Madman133 is offline Find More Posts by Madman133
Old Jan 16, 2013, 09:04 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Castle ESCs will work. In reality you will get about 80% of your KV so 14.8*6000*.8 = 71,040 which is still just over the HW ESC limit..
Old Jan 17, 2013, 12:39 AM
Madman133's Avatar
USA, CO, Golden
Joined Nov 2010
Hmmmm ok thanks for the response!
Sold Dons Wicked Wemo 6000kv NIB $22 ledgehunter Aircraft - Electric - Jets (FS/W) 3 Sep 17, 2012 05:45 PM
Sold 50mm dons wicked 6000kv wemo fan and motors w/ Hobbywing esc Forrest Gump 23 Aircraft - Electric - Jets (FS/W) 7 Aug 18, 2012 12:21 AM
For Sale 50mm wicked wemo combo w/6000kv motor thundercracker Aircraft - Electric - Power Systems (FS/W) 4 Jul 16, 2012 09:25 PM
Discussion Have You Ever Seen This In The Sky ? freddy warbird Life, The Universe, and Politics 40 May 07, 2012 09:55 PM
Sold ** Don's Wicked 50mm Wemo/4800Kv/40a Combo ** Sammy70 Aircraft - Electric - Power Systems (FS/W) 0 Apr 29, 2012 10:14 PM
