Old Nov 14, 2012, 11:21 AM
Rich215 is offline
Find More Posts by Rich215
Rich215's Avatar
United States, CT, South Coventry
Joined Jun 2011
Are Water Rudders Really Needed
I'm building an E-Flite 25 size J3 on floats and the cable sysyem they provide to drive the water rudder leaves a lot to be desired. So my question is, for this plane anyways, is the water rudder really needed? How affective is it? If I leave it off will I end up regretting it?
I ended up adding the rudder. As I stated I wasn't impressed with the cable setup that came with the kit so I added a sub micro servo to the left float and connected it to the rudder using a flybar from a Trex 500. I did some test runs with it in the water and seems to track straight.
Rich215 is offline Find More Posts by Rich215
Old Nov 14, 2012, 01:49 PM
Sopwith Mike is online now
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
You will need a water rudder on any single-engined floatplane. On twins, differential throttle is best: if you can mix it with air rudder, even better.
The main reason is that turning downwind can be very tricky with just an air rudder and steering at all in any sort of breeze is just plain difficult.
The most elegant method is to bury a servo in one of the floats and have a single water rudder with a pull-pull action. If possible, the rudder should be able to trip up if it hits an obstruction.
Good luck!
Sopwith Mike is online now Find More Posts by Sopwith Mike
Old Nov 14, 2012, 03:08 PM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
Or a BIG rudder with lots of throw !!
lake flyer is offline Find More Posts by lake flyer
Old Nov 14, 2012, 03:10 PM
lake flyer's Avatar
Joined Nov 2005
I have several without water rudders and often wished that they had them , as Mike says turning downwind can be difficult .
Old Nov 14, 2012, 03:50 PM
how much is online now
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
what they all said...
a water rudder on a single engined float plane is very very usefull... especially on a Cub.
it does however work better when its in the water... a different version of the perfect 2 point landing
David
how much is online now Find More Posts by how much
Old Nov 14, 2012, 07:24 PM
Rich215 is offline
Rich215's Avatar
Joined Jun 2011
Thanks everyone for the replies. You've convinced me to use the rudder.
Good luck!
Mike:
I picked up another servo that I'll mount on the float and connect it using a flybar rod from a Trex 500 that I had left over. The rudder that comes with the floats is brass and hinged so it will swing up if it hits something.
Dave:
Nice picture. I hope it survived...
Old Nov 14, 2012, 08:20 PM
JimCasey is offline
Find More Posts by JimCasey
Seaplane Nerd
JimCasey's Avatar
Joined Jan 2005
There are techniques to taxi without a water rudder.
Most flyers can't be bothered to read the article, much less to understnd and practice the techniques. They are taught by the EAA for taxiing full-scale floatplanes.......
http://www.smilesandwags.com/Floatsi...%20skills.html
JimCasey is offline Find More Posts by JimCasey
Old Nov 14, 2012, 09:27 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
Water rudders are nessesary with ANY little wind.
Kyler1 is offline Find More Posts by Kyler1
Old Nov 14, 2012, 11:14 PM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
Yep !! Even one water rudder is a tremendous improvement. Hard to tell the difference between one or two.
lindart is offline Find More Posts by lindart
Old Nov 20, 2012, 09:21 PM
chasronw is offline
Find More Posts by chasronw
Itchy scratchy
Joined Aug 2011
water rudders
air boats work just fine with water rudders or turn fins.
i have a pby the water rudder (WR) broke off and there is no difference
my icon a5 has a little no effective WR
my skorsky s39 has a tail wheel that dosen't help much
i have learned move around just fine
generaly the prop blast is greater than the wind
chasronw is offline Find More Posts by chasronw
Old Nov 21, 2012, 02:26 AM
Joined Aug 2004
Hi Jim,
A very interesting article, and many thanks for posting it. My preference is still for a water rudder but I might unplug the one on my Fun Cub and try some light wind air rudder taxiing.
Old Nov 21, 2012, 03:50 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
The trick to turning without a water rudder is to intermittently rev the throttle and quickly blast the air rudder... keep doing this in small increments to get the tail turned in the right direction, then do a fast-taxi (nearly on step) to keep sufficient air moving over the rudder. Of course, it helps to plan ahead and use the wind to your advantage... you might have to tack back and forth to keep out of direct cross-winds that could tip a high-wing plane. Then once you get to your spot, let the wind weathervane you into the headwind. Half of my seaplanes (I have over a dozen) have no water rudder and I manage just fine.
warhead_71 is offline Find More Posts by warhead_71
Old Nov 25, 2012, 01:05 AM
Detroit Dave is online now
Find More Posts by Detroit Dave
Detroit Dave's Avatar
United States, MI, Taylor
Joined Mar 2009
The seaplanes seem to turn better without a rudder than the float planes. Maybe it's because the seaplanes are so much lower to the water and catch a lot less wind. It's to the point now that I put water rudders on all my float planes without even thinking about it.
Putting a rudder on each float looks cool, but doesn't seem to work any better than a single one.
Dave
Detroit Dave is online now Find More Posts by Detroit Dave
Old Nov 25, 2012, 02:32 AM
how much's Avatar
Joined Jul 2011
just worth mentioning.. if you havent flown it yet?
i assume you are talking about the eflite 25e Cub.. not the eflite 25 super Cub?
(there is a big difference)
then i would recommend
disregard the "equal control throws" for the ailerons in the handbook... the ailerons are massive on this model and really need taming.. set as described in the book the model is "a flying tip stall"
set the aileron neutral with both ailerons around 2mm up at the tip
dial in some aileron differential.. you want at least 3:1 ratio of up to down
set your dual rates on the ailerons to reduce throws even further if required
couple some rudder in with the aileron, i use around 60% rudder mixed
be extra carefull with the c of g.. make sure it sits slightly nose down
this really does tame the tip stall and turns it into a very pleasent model to fly
and
get some stick time on the model without the floats and get used to it first. fitting the floats adds a lot of weight and drag and will effect the handling.
all the above will matter a lot more than the water rudder
just my 2 cents worth
David
Old Nov 26, 2012, 08:07 PM
Rich215 is offline
Rich215's Avatar
Joined Jun 2011
David,
Thanks for the suggestions. I'll definately take them into consideration.
Discussion Do I really need a rudder? Napoleon_Taner Electric Sailplanes 5 Aug 12, 2012 06:03 PM
For Sale Ernst water Rudder .90-1/4 scale new MOUNTAINROAD Aircraft - General - Miscellaneous (FS/W) 0 Jun 19, 2012 08:36 AM
New Pilot need Help? Is Rudder really needed? PrasadL Electric Plane Talk 26 Apr 13, 2005 10:10 AM
New Pilot need Help? Is Rudder really needed? PrasadL Beginner Training Area (Aircraft-Electric) 10 Sep 17, 2004 06:48 AM
Do i really need the rudder??? deadcell Foamies (Kits) 10 Apr 23, 2001 05:48 AM
