http://www.rc-heli.de/board/showpost...2&postcount=67 http://translate.google.com/translat...postcount%3D67 |
Philippines, NCR, Pasig City
Joined Nov 2012
Can anyone tell me if its possible to use this http://www.horizonhobby.com/products...taba-HAN173#t1 to make the futaba a slave and make the channel assignment correct?? Electronic experts pls help!
United States, MI, Brighton
Joined Oct 2012
Latest blog entry: Polaris Aileron Pushrods
They wouldn't say that if it didn't, because then you would not be able to use it as intended (and yes, it really does swap the channels). This is one of the differences between properly designed equipment and Chinese clone crap. The only problem with using it to correct the channel order of the Orange TX module is that the JR trainer port signal is low level (~1.4V) and AC coupled. The ppm input circuit in the Orange module looks like it might be able to recognize the signal that the HAN173 cable puts out, but as this is not its intended use you shouldn't be surprised if it doesn't work! |
Joined Oct 2005
Hey guys - I hope I'm not hijacking this thread. I think my question is directly along the lines of the current discussion. If not - I apologize and will happily start a new thread.
I'm tempted to use the orange TX module on my Futaba TX. My Futaba does not use a removable RF module. I figured I could take the signal from the trainer output and send it to the Orange TX module. Can anyone tell me whether this will work? Is the trainer signal protocol on the Futaba the right protocol? Right voltage levels? Thanks! |
Joined Nov 2012
it would work depending on the tx check this--->http://www.youtube.com/watch?v=CfdCuRmx0jc i'm planing to do this too.
btw whats your tx? |
Joined Oct 2005
Thanks. I have the Futaba T7CHP. If I understand, using this module will reverse two of the channels - right? And I presume that shouldn't be a problem if I use this receiver:
http://www.hobbyking.com/hobbyking/s..._Failsafe.html because I can just swap the servo leads into the respective slots - right? And one last question - how important is a satellite receiver? Thanks again. |
Joined Nov 2012
Ok i think you can make the module work on the 7c
But as you noted yes the channel sequence would be all wrong so you can't use it on bnfs Pls note that the channel sequence is futaba=aetr vs jr/spektrum would be taer so changing the servo slots would work and the satelite reciver would not be needed Ps if you need extra info PM numnutchris here at rcgroups Sorry..can't speak about how important the satelite is but from what i know you dont need it |
| Thread Tools | |
| For Sale Blade sr dsm tx hp6dsm and blade 120 sr tx | Garrett1234567 | Aircraft - Electric - Micro & Indoor Airplanes | 0 | Nov 08, 2012 03:46 PM |
| For Sale Spektrum Telemetry TM1000's, TM1100's,AR6000 DSM2, 4 New Orange DSM 2 Receivers, | daign | FPV/RPV - Equipment and Vehicles (FS/W) | 8 | Jun 02, 2012 02:26 PM |
| Sold Brand New Orange DSM 2 Satellite Receivers | healthyfatboy | Aircraft - General - Radio Equipment (FS/W) | 9 | May 06, 2012 03:17 PM |
| Sold Mint Spektrum DX6i, DSM 2 with 6ch Orange RX | tankbuster | Aircraft - General - Radio Equipment (FS/W) | 2 | Apr 06, 2012 07:39 AM |
| Discussion HobbyKing Orange Rx DSM, any problems/complaints? | big_poppa4904 | Radios | 14 | Jul 13, 2011 11:05 PM |
