Old Feb 21, 2013, 12:13 AM
mdv is online now
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
Originally Posted by pmackenzie View Post
Sounds like a good argument for an outright ban on the use of Orange modules at flying fields.
There really is no good reason to buy one of these.
It is no less expensive than a genuine Spektrum module once you factor in the receiver you get with the latter.
It has no FCC approval, so its not legal to use anyway.
And on top of that, it may or may not shoot someone else down.
Great product. Kudos to the guys at Orange/HK.
Aren't the Spektrum modules discontinued so Orange modules are the only option?
mdv is online now Find More Posts by mdv
Old Feb 21, 2013, 02:14 AM
MikeRobey42 is offline
Find More Posts by MikeRobey42
Perth, Western Australia
Joined Jan 2010
You are correct but you can still pick one up on eBay which is what I intend to do.
MikeRobey42 is offline Find More Posts by MikeRobey42
Old Feb 21, 2013, 02:47 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
In stock at Horizon for $110
http://www.horizonhobby.com/webapp/w...pe=productgrid
That includes free shipping and an $80 receiver, so the module alone is only $30.
They were gone for a long time, but they became available again a few months back.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Feb 21, 2013, 04:14 AM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
Best price in the UK for the Spektrum module is around 85, but the biggest difference is that the so-called $80 receiver actually only sells on for 25 - 30 judging by completed listings on Ebay.
So although the sums of money aren't great, the module will still end up costing twice as much as the Orange one. If the Spektrum module had been remotely comparable I wouldn't have looked at the Orange on. As it is I think the chances of conflict with my use are pretty much zero, and I will probable convert to an internal antenna which will be neater than the Spektrum on in any case.
aesmith is offline Find More Posts by aesmith
Old Feb 21, 2013, 09:27 AM
ercapoccia is offline
Find More Posts by ercapoccia
Italy, Lazio, Rome
Joined Jun 2012
I'm a computer engineer and i've been working al ot with connection protocols.
I don't know how DSM2 and DSMX protocols work on binding but i'd assume that they are like point to point communication where both TX and RX are in binding mode at the same time. If your RX in already binded it won't accept another connection and a TX in the same range will not be able to bind with that ID.
This is just how it works in my mind.
ercapoccia is offline Find More Posts by ercapoccia
Old Feb 21, 2013, 09:36 AM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
I haven't followed all of this but wouldn't both radios have to come up with the same ID? Isn't that next to impossible?
Rich in ILM is offline Find More Posts by Rich in ILM
Old Feb 21, 2013, 09:39 AM
phil_g is online now
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Pats reasoning is good in the US but doesnt work in the UK unfortunately, where the combo costs much more and the supplied rx seems to be worth much less on the 2nd-hand market.
I've just been on the OrangeRx website and posted a query on their support page:
Originally Posted by Phil to ORx
Please could you clarify the situation with the OrangeRx DSM2/DSMX modules, specifically the uniqueness of the ID or global identifier. The ability to reset it and the explanation as to why this might be necessary has caused a lot of flyers extreme concern, to the point that it has been suggested that these be banned at club flying sites. The concern is that it appears from the description that the OrangeRx module could share a common ID with a genuine Spektrum set.
It may be that the perceived problem is a misunderstanding, as a result of poor translation.
Please could you post a technically detailed explanation of the ID allocations and confirm whether or not there is the possibility of a clash with other systems. This concern must be badly affecting sales of the OrangeRx modules so a prompt response would benefit yourselves as well as model flyers.
Not sure if they'll respond, we'll see.
Cheers
Phil
phil_g is online now Find More Posts by phil_g
Old Feb 21, 2013, 05:31 PM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Yes, pretty much, actually 1 in 4 billion. Imagine two people buying lottery tickets, picking the exact same numbers, and then showing up to the same field.
It could actually be less, or even 0. Suppose (hypothetically) that Spektrum started out with the simple sequence {1,2,3,...}. Suppose also that HK looked at the IDs on some Spektrum units, and noticed that they were all down in the 10,000 or 100,000 range. If they then started their IDs at 2 billion, there wont be a potential collision until Spektrum makes their 2 billionth unit.
marhar is offline Find More Posts by marhar
Old Feb 21, 2013, 06:03 PM
robertc is offline
Find More Posts by robertc
glen innes australia
Joined May 2001
If the modules had a 'globally UNIQUE id' then that would be the case. If they did they would not need a button to change ID.
How many ID change buttons do you find on other transmitters?
regards
Bob Comerford
robertc is offline Find More Posts by robertc
Old Feb 21, 2013, 08:51 PM
marhar is offline
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
And now that I think about it... most likely Spektrum has sampled some of the ORX units to verify the numeric range ORX is using, and will intentionally avoid that range.
Old Feb 21, 2013, 11:40 PM
Joined Jan 2010
So what you are saying is that if person A was already up and flying and person B came along and his module had the same id then person A would be fine and person B would have to change his id and rebind his model?
If that is the case then that is good news because nobody gets shot down and the orange module guy just has to changeid's (which is annoying but not going to do any harm either).
So I guess now the question is whether or not that is the case.
Old Feb 22, 2013, 02:31 PM
aesmith is offline
Joined Apr 2010
Originally Posted by phil_g View Post
... I've just been on the OrangeRx website and posted a query on their support page:
Cheers
Phil
I asked three times on Hobby King's web site and each time they closed the support request unanswered.
Old Feb 22, 2013, 04:16 PM
phil_g's Avatar
Joined Jul 2007
Me too, same thing happened - also asked Scotty the UK rep personally (he's an old acquaintance through motorbike racing) but no joy - hence asking OrangeRx directly.
Cheers
Phil
Old Feb 22, 2013, 08:38 PM
Joined Jan 2010
I think that yes it is unlikely for two people to randomly come up with the same id's BUT people win the lottery all the time so it is possible and the consequence could be someone losing a model.
Given scott from HK isn't talking and neither are HK then I conclude that either they know it is a problem or they don't know and cannot determine if it is a risk.
I was hoping that someone from HK would confirm the fact that, once a connection is made, the model cannot connect to another radio. To me that means its safe to use them.
Personally I am not going to use mine (or sell it or give it away) until I know for sure its safe. If it was just my model at risk then that would be different. I take the risk and I accept the consequences but I would be heart sick if I shot someone else's plane down.
Old Feb 23, 2013, 05:22 AM
phil_g's Avatar
Joined Jul 2007
I'm happily using mine as I dont have any DSMX receivers.
Discussion HobbyKing Orange Rx DSM, any problems/complaints? big_poppa4904 Radios 26 Aug 12, 2013 04:08 AM
For Sale Blade sr dsm tx hp6dsm and blade 120 sr tx Garrett1234567 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Nov 08, 2012 04:46 PM
For Sale Spektrum Telemetry TM1000's, TM1100's,AR6000 DSM2, 4 New Orange DSM 2 Receivers, daign FPV Equipment (FS/W) 8 Jun 02, 2012 03:26 PM
Sold Brand New Orange DSM 2 Satellite Receivers healthyfatboy Aircraft - General - Radio Equipment (FS/W) 9 May 06, 2012 04:17 PM
Sold Mint Spektrum DX6i, DSM 2 with 6ch Orange RX tankbuster Aircraft - General - Radio Equipment (FS/W) 2 Apr 06, 2012 08:39 AM
