Old Nov 22, 2012, 02:16 AM
hp88 is offline
Find More Posts by hp88
TRex 450,500,600, Dragonus II
hp88's Avatar
Australia, QLD, Brisbane
Joined Nov 2008
Decided to go with twin struts after reading this build thread http://forums.offshoreelectrics.com/...style-build%29 . I have most of my hardware for the build, i will be running counter rotating drives running on 6s. At this stage I am trying to work out how much room to leave between the prop shafts. I have to work out what will be the biggest diameter prop that I might use and then I can use this to set the distance for the struts. I am looking for around 50 to 60 mph.
hp88 is offline Find More Posts by hp88
Old Mar 05, 2016, 03:12 AM
martno1fan is offline
Find More Posts by martno1fan
Closed Account
Joined Mar 2008
How did your build go ? the pics you posted were of some of my Apache hulls built by friends,the twin electric ran very well with 57 mm props 52 mph on 6 s so not inefficient as someone commented especially when you consider the size of the motors used 600 size heli motors.
The blue hull with twin arnesons used an inline gas motor k600 rcmk through a 1.1 ratio cr gearbox to twin 67 mm props turning outwards and runs 70 mph.
Mart
Heres the twin electric ..
Welcome onboard my 58" rc boat (8 min 14 sec)
martno1fan is offline Find More Posts by martno1fan
Question The holes of the bottom of BRAtt. JPCAT Scale Boats 5 Nov 13, 2012 06:52 PM
Discussion Distance between twin stingers on Deep Vee hp88 Racing Boats - Electric 2 Nov 02, 2012 05:07 AM
Sold dremal flex shaft chyorn Aircraft - General - Miscellaneous (FS/W) 5 May 02, 2012 01:14 PM
For Sale NIB Dremel 7360 Flex shaft tool kit. Ramboamt Aircraft - General - Miscellaneous (FS/W) 0 Apr 16, 2012 11:48 AM
Sold Flex shafts gkamysz Boats (FS/W) 16 Mar 22, 2012 09:25 PM
