Old Nov 14, 2012, 01:29 AM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
No flat spot on shaft for set screw, stock 450 pro motor
Do I file a flat spot myself?
finguz is offline Find More Posts by finguz
Old Nov 14, 2012, 03:14 AM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
Seems to me the only logic solution, and it is what I would do....
However, I would not use a file but a grinding stone, whether that would be a benchgrinder or a Dremel, just to make sure, the flat spot will be really flat....
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Nov 14, 2012, 03:25 AM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I use a Dremel cutoff wheel, and slowly take off the shaft metal at a 90 angle. Good luck!
eagle777 is offline Find More Posts by eagle777
Old Nov 14, 2012, 08:06 AM
Jonathan Ott is offline
Find More Posts by Jonathan Ott
Will fly for food.
Jonathan Ott's Avatar
United States, IN, Fishers
Joined Jul 2002
use a zip-lock baggie too. Put the motor in the baggie, then punch the shaft through the plastic, then do your filing/grinding. This keeps the metal filings out of the motor/sticking to the magnets.
Jon
Jonathan Ott is offline Find More Posts by Jonathan Ott
Old Nov 14, 2012, 04:14 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
Thanks guys, also thanks for the bag tip Jon!
That sucks, I wish Align did this for me. They just expect someone to not do it and screw the set screw onto the round shaft? That's what the manual reads.
I saw a guy on youtube put green thread locker on his shaft to pinion, he set the screw too... then said to just use heat to get it off later. What's your guys' thoughts on that?
If it's not flat it'll move up and down? Seerms impossible then, I'm only a man. Would threadlocker red or blue, on the shaft, help keep it in place if it wasn't perfectly flat?
And the shaft seems at least somewhat hollow, at least partly, the way align does some of their main shafts.
Old Nov 14, 2012, 04:26 PM
The Netherlands
Joined Nov 2009
Threadlock between shaft and pinion works, as for keeping the pinion in place during flight. But I don't like having to heat the assembly and exert an axial force on the shaft.
You only need a very slight flattening, maybe 0.1 or 0.2 mm (0.004 to 0.008").
Even if that is not perfectly aligned with the shaft, the pinion usually will not ride up or down.
Brgds, Bert
Old Nov 14, 2012, 05:24 PM
RFDelie is offline
Find More Posts by RFDelie
Get to the choppa!
RFDelie's Avatar
United States, PA, Pittsburgh
Joined Sep 2012
My first motor had this and I just used a little bit of locktite in the screw hole before I fastened the set screw. I never had a problem with it slipping, but that engine was ruined by a short in the cheap esc so I only used it for about 2 weeks.
RFDelie is offline Find More Posts by RFDelie
Old Nov 14, 2012, 06:08 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
Brgds, Bert
Thanks, then maybe I'm overreacting, maybe it's not going to be so bad. Still, what if I were to put blue thread locker on the shaft & grind a slight flat spot? The thread locker would be a just in case. I gotta buy a dremel, I'm the only person in the hobby without one.
RFdelie, I put threadlock on my setscrew always. Was your motor you mentioned an esky motor? Just curious.
Old Nov 14, 2012, 06:45 PM
The Netherlands
Joined Nov 2009
Then you have an unnecessary hard time removing the pinion... that's what.
The flat spot has only one purpose: creating a local smaller "diameter" so the shaft locks onto the setscrew when the shaft tries to rotate in the pinion.
A light securing with blue loktite on the setscrew is really all that is needed, provided, you set the setscrew at the lowest point.
What I usually do is very slowly tightening the setscrew (with only loose fingertips) while twisting the pinion back and forth over the shaft. This way you make sure, the setscrew lands on the lowest spot. once you have found that spot, tighten it normally, and it should not give any problem both until and during the next time you need to loosen it.
Brgds, Bert
Old Nov 14, 2012, 07:08 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
Brgds, Bert
Thanks Brutus, I feel more confident about the whole thing now. I still wish align would've done it, I expected more from them.
Old Nov 14, 2012, 08:28 PM
RFDelie is offline
Get to the choppa!
RFDelie's Avatar
Joined Sep 2012
No fin, it was a cheap dytrum motor that I got from hobbypartz.com. I got the esc and motor for 37.00. It flew fine, no slipping. But burned out quickly.
Old Nov 14, 2012, 08:45 PM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
I have the same issue actually, the flat spot on the CopterX motor was only on the lower part of the output shaft, but i needed to raise the pinion to get it to line up with the main gear. So i put thread locker on the setscrew and screwed it in extra tight. Hope it doesn't slip.
Hajile is online now Find More Posts by Hajile
Old Nov 14, 2012, 09:16 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
that's detrum for you, burning out.
I thought about their combo for a future sport-3d plane build but think I'll pass. I've heard their esc's suck too.
Old Nov 14, 2012, 09:22 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
I'd grind a flat spot on it like I have to. But apparently Align doesn't think it's necessary so who knows. I'm going to grind a spot for safe measure.
Old Nov 14, 2012, 09:29 PM
Joined Jul 2012
Really need to figure out the local equivalent of the dremel. Seems like it'll be useful for this hobby.
Discussion Source for 5mm shaft collar with set screw? 7oneWo1f Electric Motor Design and Construction 2 Jul 26, 2012 09:00 AM
For Sale New 450 Pro parts Galore 2 full frames servos motor screws shafts gears bearings etc. blueindian Aircraft - Electric - Helis (FS/W) 2 May 16, 2012 01:21 AM
Discussion Should I grind a flat spot on my motor shaft for the flex cable coupler? zanek Racing Boats - Electric 9 Aug 14, 2011 08:54 PM
Best way to get a flat spot on your motor shaft austinflyer Power Systems 1 Jan 22, 2004 04:55 PM
New 16/15/5, do I grind a flat spot on the shaft? Captain Carlton Power Systems 9 May 21, 2003 08:23 AM
