Old Nov 13, 2012, 10:32 PM
xoxota is offline
Find More Posts by xoxota
Noob Quad Jockey
United States, WA, Seattle
Joined Dec 2011
Question
Need help figuring out correct ESC amperage...
I'm looking at purchasing these motors, and the specs are presented in a slightly different way than I'm used to, so I'm not sure what ESC to get, or whether I maybe already have something in the toolbox that'll drive these.
The Detail page for these talks about "max efficiency current", which just from the name I can tell is not very useful for calculating correct current draw, and "current capacity", which I don't even know what that is, but it sounds like "burst" current.
What number should I be looking at when choosing an ESC to drive these?
xoxota is offline Find More Posts by xoxota
Old Nov 21, 2012, 11:20 AM
xoxota is offline
Noob Quad Jockey
Joined Dec 2011
Seriously? Does nobody on RCGroups know how to choose an ESC? Or maybe this isjust such a dumb question that nobody wants to answer it?
Old Nov 21, 2012, 11:25 AM
vartaz is offline
Find More Posts by vartaz
Denmark, Central Denmark Region, Karup
Joined Aug 2012
If your motors max amp is 20 buy a 30a esc. Or similar, motors max amp plus 20% then your good. and also make sure that voltage your want to use that esc support it.
those motors you show says max 14a, then a 20a esc should be enough.
edit didnt see the 26a /60s . i see what you mean.
Get the 30a Plush escs, im using them with this motor http://www.hobbyking.com/hobbyking/s...dProduct=17345
vartaz is offline Find More Posts by vartaz
Discussion Help me figure something out, anyone used a servo driver to control an ESC? Scott_NJ Electric Power Cars 7 Oct 24, 2012 07:33 AM
Question question about how to figure out amperage on a given setup. out of stock Power Systems 3 Jul 06, 2012 07:17 AM
Discussion I need some help figuring out how to wire something up to my Rx asd9000 Radios 4 May 11, 2012 08:57 PM
Help! Please help! New to Nimh, can't figure out how to connect receiver pack to Elysium ch The knifes edge Batteries and Chargers 4 May 08, 2012 02:45 AM
