Old Nov 13, 2012, 08:04 PM
Indgroove is offline
Find More Posts by Indgroove
Indgroove's Avatar
United States, TN, Knoxville
Joined Feb 2007
What JR/Spektrum receiver?
Hello.
I want to know what 2.4 JR or Spektrum receiver can I use in a Xplorer or Satori?
I have the 6255, R921X, 7000, and ar6200. Can I use any of these receivers?
Indgroove
Indgroove is offline Find More Posts by Indgroove
Old Nov 13, 2012, 09:24 PM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
I think you would prefer the 921 or the 7000 as you will need the extra channels. I prefer the AR9300 for the compact size and plenty of channels. As long as you have a full range receiver and enough channels, and can fit it inside, you're good.
mlee8249 is offline Find More Posts by mlee8249
Old Nov 13, 2012, 10:26 PM
tewatson is offline
Find More Posts by tewatson
Team JR Air
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
The AR7000 does not have an optimal antenna arrangement for sailplane fuses, but it will work. If the R921 will fit, use it, as it has two receivers in the main body vs. just one for the AR7000.
I am using the AR8000 in my Pike Perfection (also used it in F3B ships) and it has been an outstanding performer so far.
Tom
tewatson is offline Find More Posts by tewatson
Old Nov 13, 2012, 10:56 PM
onemetre is offline
Find More Posts by onemetre
USA, TX, Mansfield
Joined Aug 2004
Spektrum 9310
I'm going with a 9310 for my new x2 3.8m. Unfortunately it was DOA out of the package. It's presently at Horizon being evaluated.
Rob
onemetre is offline Find More Posts by onemetre
Old Nov 14, 2012, 01:49 PM
Indgroove's Avatar
Joined Feb 2007
Are you guys running the antenna inside the fuse or outside?
Old Nov 14, 2012, 02:46 PM
onemetre is offline
USA, TX, Mansfield
Joined Aug 2004
Am expecting to keep the antennae in the fuse. Will have main rx under the servos and satellite on the hatch. Will use the data logger to keep track of fades and holds and respond accordingly.
Rob
Old Nov 14, 2012, 03:07 PM
tewatson is offline
Team JR Air
tewatson's Avatar
Joined Oct 2006
Inside, using 2.4 friendly fuses.
Tom
Old Nov 15, 2012, 12:47 AM
mlee8249 is offline
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Inside with my one remote stuck to inside bottom of the canopy
Old Nov 18, 2012, 02:35 PM
Indgroove's Avatar
Joined Feb 2007
Okay, the 921 will not fit. Thought about taking the case off but decided against it and will order the sailplane receiver from Horizan.
Thanks for all the input.
Old Nov 18, 2012, 04:45 PM
tewatson is offline
Team JR Air
tewatson's Avatar
Joined Oct 2006
I continue to be impressed with the Spektrum AR8000...very compact, short antennas and shows outstanding results on the data logger.
Tom
Old Nov 19, 2012, 09:32 PM
rdwoebke is online now
Find More Posts by rdwoebke
get low
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
I use the 7000 in my tragi and Psyko.
rdwoebke is online now Find More Posts by rdwoebke
Old Dec 28, 2012, 07:58 AM
onemetre is offline
USA, TX, Mansfield
Joined Aug 2004
Rob
An update here. The unit wasn't DOA at all. It's easy to mis-understand the layout of the ports. I wasn't plugging in the bind plug into the right place. In speaking to HH they advised this is a common occurrence. So it's all good!
Rob
Old Dec 28, 2012, 08:01 AM
onemetre is offline
USA, TX, Mansfield
Joined Aug 2004
Tom
I can echo Tom's opinion. Using an 8000 DSM2 RX in my X2 with everything in the fuse had no issues reported on the data log whatsoever in terms of fades, holds, etc.
Rob
Old Dec 28, 2012, 07:59 PM
bundyglida is offline
Find More Posts by bundyglida
Joined Apr 2008
I use an AR 9300 in my Perfect, with an aditional remote reciever stuck to the underside of the canopy, with its whiskers exposed, and then another 'carbon friendly remote reciever (has a long single whisker) thant is located as far down the back of the fuse as i can get it, with the single whisker exposed through the bottom rear of the rudder. Never any issues with range....
bundyglida is offline Find More Posts by bundyglida
Old Dec 28, 2012, 08:12 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Ar8000,AR7000 and AR6200 only have ch3 failsafe, so IMO they are not suitable for sailplanes.
6255 has failsafe on all channels, JR 921 can do all channels or ch3 only depending on how you bind it.
Getting the proper sailplane receiver would be the best option for an expensive mouldie. They have the right form factor, the right kind of antennae and the right kind of failsafe.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Wanted JR & Spektrum Satellite Receiver Extension Wire farles Aircraft - General - Radio Equipment (FS/W) 0 May 09, 2012 07:03 PM
Sold JR 9303 72mhz, 9channel spektrum module, FrSky Module 6 receivers The_Tinker Aircraft - General - Radio Equipment (FS/W) 1 Apr 25, 2012 07:10 PM
Sold Jr/Spektrum DSM2 9 channel receivers concor Aircraft - General - Radio Equipment (FS/W) 2 Apr 16, 2012 06:23 PM
Sold JR / Spektrum R921 9-Channel DSMX Receiver jgalexander Aircraft - General - Radio Equipment (FS/W) 0 Apr 11, 2012 03:36 AM
For Sale *Trade* Spektrum Remote(24" extension) for JR Remote Receiver boggintuff Aircraft - General - Radio Equipment (FS/W) 3 Mar 03, 2012 07:27 AM
