Old Nov 13, 2012, 07:45 PM
Mikedown is offline
Find More Posts by Mikedown
Closed Account
Joined Jul 2006
rocker answers
I've got a 29" mono with a 3674 motor with a 440 prop on 4S. Now i found 2 rockers between motor and transom with a rocker on each side of keel. The only way i know to fix this to lay basswood strips that are 1/4" x 1/4" in dimensions.What i think will work is to lay strips from keel out toward chine line about 1" apart to make bottom flat. The keel is good. Man, boaters this needs your help and sure could use exoertise on this, THANKS! The rocker is 3/16" deep and bottom has been f/glassed.---- Can't be fixed.
Mikedown is offline Find More Posts by Mikedown
Old Nov 14, 2012, 06:38 AM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
How bad is the rocker? You might be able to sand/fill it away.
wparsons is online now Find More Posts by wparsons
Old Nov 14, 2012, 08:52 AM
Mikedown is offline
Closed Account
Joined Jul 2006
rocker
Can't be fixed.
Old Nov 14, 2012, 10:12 PM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Fill low spots with body filler and sand to correct profile
nick_75au is offline Find More Posts by nick_75au
Old Nov 15, 2012, 07:34 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Make sure you sand and clean the area very good . You might even consider drilling some small holes to give the Bondo a better grip . But filling the depression and sanding is the best way to go .
highflyerbill is offline Find More Posts by highflyerbill
Old Nov 15, 2012, 08:19 PM
Mikedown is offline
Closed Account
Joined Jul 2006
rocker
I contacted boat builder and he said rockers are built in, but said cold and warm weather can cause warpage if stringers aren't put in. Mine didn't have stringers, but just m/mounts are in place. I took it on my own after you gentlemen posted.and put basswood at the 4" line from m/mount to transom and are 4" apart and epoxy them in. Guess what , i had to remove the basswood and left epoxy which left 1/16" rocker on each side and both sides are now equal in rocker depression, and right in the middle of trim tabs area and 1 1/2" in from transom. I guess all the work paid off.
Off Site NIB Saito 40 Open Rocker Jetmike007 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 24, 2012 06:36 PM
Off Site NIB Saito 30 open rocker Jetmike007 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 24, 2012 06:35 PM
Sold OS FS-60 Open Rocker excl in box jjscott Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 18, 2012 05:24 PM
For Sale It turns out that the 53 had a plain rocker cover and the 63 had a black rocker cover rpwarehime Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 01, 2012 09:54 PM
For Sale Open Rocker Saito FA-30 Chickenfoot Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 12, 2012 08:19 PM
