Espritmodel.com Heli Air
Old Nov 13, 2012, 07:14 PM
Joined Sep 2012
DX18 firmware update failure
Hello. I am attempting to update the firmware on my new DX18, and it's not going well. I downloaded the firmware, saved it to an SD card, inserted card, powered up transmitter. Next a screen with a progress bar appeared, as expected. The backlight flashed on and off a few times, the bar disappeared, reappeared, disappeared, reappeared. Strange, but there's a note on the download page saying this is normal. After that however, nothing. The radio is stuck with the backlight off, the progress bar on the screen is not updating (going on 10 minutes now). Seems like a borked update. The instructions say not to interrupt the process, but I'm not sure what else to do at this point. It'll be pretty disappointing if the radio is bricked before I've even flown it!
Thanks in advance for any tips/pointers.
Steve
stevegalle is offline Find More Posts by stevegalle
Old Nov 13, 2012, 07:46 PM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
DX8 and DX18 owner here with plenty of updating experience and never once had any issues with updating.
Yes some of the updates do cause a lot of flashing/disappearing/reappearing to happen but never had one get stuck.
freechip is offline Find More Posts by freechip
Old Nov 13, 2012, 08:02 PM
Joined Sep 2012
Unfortunately I'm not so lucky; over an hour on the dark progress bar screen and it hasn't budged. I guess I'll be on the horn with Horizon in the morning to figure out what to do. Not the first evening with the 18 I was hoping for.
Old Nov 13, 2012, 08:08 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
At this point being you say over an hour I would if it were my radio removed the SD card and format it. Download the update again making sure not to change the name of the file nor the extension.
Then power off the radio, insert the SD card and reboot the radio and hope this procedure worked out.
That's if this was my radio.
Old Nov 13, 2012, 08:21 PM
Joined Sep 2012
Thanks, yeah, tried that right after I posted. I used a different CF card, freshly formatted, downloaded FW from different computer, wrote it with a different card reader/writer, same result. And of course with a partial update done, the transmitter is dead. It's strange that it seems to go ok until it stops... oh well.
Old Nov 13, 2012, 08:23 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Hope HH resolves this for you quickly and to your satisfactory.
Old Nov 13, 2012, 08:28 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
If you have a different SD card, you ought to give that a try, too.
Here's the sequence they'll tell you on the phone if your update failed.
1) Format card, copy download to it again.
2) Make sure file is named exatly SPMTX.SAX on the card. Select EJECT before removing card!
3) Attempt update.
If update fails in the same manner as yours did:
4) Use a different card.
5) Make sure file is named exatly SPMTX.SAX on the card. Select EJECT before removing card!
6) Attempt update.
I don't think we've had more than 3 or 4 radios that haven't been fixed by this point that I've heard of. And guess what those turned out to be? Yup, the second SD card was bad too.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Nov 13, 2012, 08:40 PM
Joined Sep 2012
Andy thanks for the reply. I have now tried two SD cards, and multiple sd card writers. Do all previous updates to 1.03 need to be installed in order to install 1.03? I have also tried to format the cards both FAT and FAT32, doesn't seem to make a difference.
Old Nov 13, 2012, 08:49 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
You don't need to install the older updates, just the most recent.
Old Nov 13, 2012, 08:50 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Only install the latest version. The older versions should all have been disabled. Do NOT go backwards!
The radio accepts FAT or FAT32 just fine. It will take anything from an ancient 512K MMC up to 32 gig MicroSD if you can afford one.
One of the key steps is to click on the Eject for the SD card. This causes the PC to flush the cache to the card immediately. If it doesn't do that, you really only get a partial copy of the SAX file on your SD even though it looks like the whole thing is there.
Andy
Site Sponsor
Old Nov 13, 2012, 09:01 PM
Joined Sep 2012
Ok, thanks again. At this point I have tried 3 cards, 2 card reader/writers, 2 filesystems, have ejected every time, re-downloaded the firmware, same behavior. We'll see what they say tomorrow.
Old Nov 13, 2012, 09:06 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
How about downloading another copy?
Site Sponsor
Old Nov 13, 2012, 09:15 PM
Joined Sep 2012
Yep, downloaded the EN/DE/FR, and the EN/IT, multiple times
Old Nov 13, 2012, 09:22 PM
Joined Sep 2012
This is how the process goes:
update issue (0 min 23 sec)
Old Nov 14, 2012, 01:12 PM
Joined Sep 2012
So as expected, the remedy is a trip to the service center. Oh well, it's an r/c transmitter, not a defibrillator; the wait won't kill.
Thanks again Andy and Freechip for the ideas.
Mini-HowTo Update Firmware for Devo TX - Import/Export Devo TX Models - Update Devo RX Firmware Tom Z Micro Helis 21 Mar 30, 2013 05:55 AM
Discussion Phoenix sim update failures tripleup05 Simulators 4 Apr 23, 2012 12:37 PM
Discussion DJI Naza firmware update failure seojeff Multirotor Talk 15 Mar 20, 2012 08:23 AM
Help! Firmware update error with OSD pro ONLY Data Logger and Gardian firmware update works whosthebaddest Eagle Tree Systems 10 Mar 17, 2012 05:26 AM
Discussion Cant use update client or firmware update jaysbay Hoverfly Technologies 6 Nov 07, 2011 10:19 PM
