Old Nov 15, 2012, 07:12 PM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
Strip the Darby down, blow it all out and reassemble. Also for the $8 a litre I doubt the missus will worripy if you skip a couple of cups of coffee.
scrub monkey is offline Find More Posts by scrub monkey
Old Nov 16, 2012, 10:23 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
There is only a couple of things to keep the 2 stroke from running. Bad plug, Bad igniter battery, Bad fuel. Plugged spray bar, plugged air bleed. Or a wore out sleeve and piston, Fuel if left sitting on concrete or a damp area will suck in moisture which you can see in the plastic bottle gathering up above the fuel. Or loss of nitro content from evaporation if left open always close your fuel bottle as soon as possible.
unclecrash is offline Find More Posts by unclecrash
Old Nov 20, 2012, 02:37 PM
SYRFD is offline
Find More Posts by SYRFD
Joined Aug 2012
VICTORY!!!! Took into account all the replies and after some serious tinkering I finally have it running. Which as always leads to more questions.
With the air bleed low end needle setting, (The small hole in front of engine) how do I bring the idle up a bit? I figured turning it clockwise and reducing air in, would help. I will research some now. But any help is appreciated.
I set the high end needle and it seems to be running well there. Little bit of smoke and it revs up well with no hesitation. It was a little hot,but I would think that is normal. So maybe I should richen it just a bit.
Thanks again for the replys! The help on these boards is keeping me into trying this RC flight thing.
SYRFD is offline Find More Posts by SYRFD
Old Nov 20, 2012, 02:55 PM
SYRFD is offline
Joined Aug 2012
After looking up again how to set the low end air bleed I can't find any good answers online. Most just say start halfway and adjust from there... well which way should I adjust if it is sputtering out? I think I will try leaning it out and see how that works if I don't get any reply's. I need a longer screwdriver to do it while the engine is running so I don't lose fingers....
Old Nov 20, 2012, 03:34 PM
Brutus1967 is online now
Find More Posts by Brutus1967
The Netherlands
Joined Nov 2009
Not that difficult.
First make sure, high speed needle is set correct.
Then run the engine at idle for a longer time. Preferrably close the throttle in a brisk way, as the way it takes on idle in the first few seconds tells tales
If it slows down and dies sputtering, it is (much) too rich, open the air bleed a little. If after closing the throttle from full, it takes on idle than slowly revs up and dies, it is (much) too lean.
Fine tuning of the idle mixture is done looking at the way the engine takes up throttle. From a 15 to 30 second idle, open the throttle quickly.
If it hesitates and sputters before running up and gaining speed "slowly", it is (slightly) rich.
If it hesitates only once without sputtering, then either dies or takes on full speed, it is slightly too lean.
Adjust accordingly, until the engine will take on full throttle immediately, after a prolonged idle.
It is important, that you let it idle for at least 30 seconds, to get the engine stabilized on the idle mixture.
When adjusted correctly and with the tank in the correct position, the engine
should also take on throttle reliably when the nose is pointed upwards 45 degrees, although it is acceptable that it will not accelerate as smoothly. As long as it picks up reliably, it is OK.
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Nov 20, 2012, 06:58 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
What is a Darby, a litre, and a worripy?
datsunguy is offline Find More Posts by datsunguy
Old Nov 20, 2012, 09:42 PM
SYRFD is offline
Joined Aug 2012
Thanks Brutus! This sounds right. As It was slowing down and sputtering then dying, I was giving it more fuel which didn't help. Leaning it out should fix my problem. Which should be easy, thanks again for the explanation
Old Nov 20, 2012, 10:57 PM
Joined Sep 2012
Meant to be carby. Auto correct on the iPad keeps on changing it.
Old Nov 23, 2012, 11:50 PM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
That's because the iPad is American (they often shorten 'carburettor' to 'carb') and you are Aussi ('carby')...
The iPad knows it's down-under (it's got GPS), but is apparently not designed to deal with engine terms...
I just always use the un-abbreviated word 'carburettor'.
Now, I know what a 'litre' is (1,000cc - liter in the US), but what is 'worripy'???
DarZeelon is offline Find More Posts by DarZeelon
Old Nov 24, 2012, 12:02 PM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
"Worripy"
Maybe its Hebrew?
jeffie8696 is offline Find More Posts by jeffie8696
Old Nov 24, 2012, 12:25 PM
DarZeelon's Avatar
Joined Nov 2003
No such word in Hebrew, Jeffie.
Maybe it's Australian?! Oops, it is English they speak there...
Old Nov 24, 2012, 11:37 PM
TEAM BOCA
jeffie8696's Avatar
Joined Oct 2009
Barely
For Sale please but to help a fellow flyer os.12 engine 40$ shiped tommy2toes Boats (FS/W) 0 Sep 04, 2012 11:10 PM
For Sale member needs help sale OS .40 SF $60 sagomon Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 14, 2012 08:15 AM
Discussion OS 40 LA and OS 40 FP jsan2385 Engines 4 May 31, 2012 06:13 PM
Discussion help os 40 sudsy51david Engines 8 May 23, 2012 05:35 PM
