Old Nov 13, 2012, 02:55 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Sparrow "BOP-ish" glider
I saw these plans: ( http://www.rcgroups.com/forums/showa...2&d=1325607728 ) on another thread and it immediately caught my attention. Rather than hijack that thread though I'm starting a separate one (ain't I sweet? ).
I have been looking for a pure glider to use for windier conditions and perhaps sloping. I decided a flying wing would be the best choice and I want to build it as a woody (no offense, but ARF's and foam just don't do it for me). The fact that this is not only a built up wing, but a fore-swept wing - a'la Bird of Prey - makes it all that much more titillating.
My question is does anybody here know anything about this bird? How difficult is it to build? To fly? I will be using balsa, it will be RC and what I'm interested in is casual flight, no DS'ing or aerodynamcs. Any info, leads to build instructions or tips y'all could give are appreciated.
TIA
Fly Wheel is offline Find More Posts by Fly Wheel
Old Nov 13, 2012, 03:37 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
I remember that got a lot of comment when it was posted.The design has certainly stood the test of time.
Mark(Quick61) was interested at the time,he may have a bit more info.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 13, 2012, 05:35 PM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
Yea, I really like that one. If your going to do an RC conversion (and why would you not?) I would upgrade the main spar 1/4x1/8 with I beam shear webbing and more than likely go for a rudder elevator set up than elevons on this one, but maybe it's just me. As far as to how hard it would be to build? Asking that kind of hints that you have not built a bunch of scratch woodies. Though, with a little thought and taking your time it should not be that hard a project to take on. At least they are calling for balsa formers and not ply. Those formers made of ply would almost be a pain to cut by hand.
I'd say GO FOR IT!!! Start the build, and if you get real stuck on something, snap a few pics and ask. Lot's of good folks here and at least one or two of them might even have a clue.
I really don't know of any real build instructions as such out there but it should be more or less straight forward and build up like most any other. nothing all that special going on in the plans that I can see. Well, other than the funky way they want the wings attached. Might be the other thing to mod... Music wire and brass tubes might be a better way to stick the wings on.
Mark
Mark
Quick61 is offline Find More Posts by Quick61
Old Nov 14, 2012, 05:42 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Just been having a look at the drawing.Leading edge wingtips are interesting.Also shows 1/8" washout?
Stuart
Old Nov 14, 2012, 10:39 AM
Quick61 is offline
Quick61's Avatar
Joined Jan 2011
Stuart
I really think that "washout" should be "washin" as it is a forward swept wing. good catch there Stuart, I forgot to mention that. EDIT--- If your read what was here before, forget it. I looked at the plans further and those LE wingtips do look interesting. Now i am wondering if they really do mean washout. That slat is like what is used on the STOL aircraft.
Mark
Old Nov 14, 2012, 05:05 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Mark
I've just posted a Q about them on the free flight forum,see if they can shed any light.
Also what's with the hook? Just to protect the slat?
Stuart
Old Nov 14, 2012, 05:13 PM
Quick61 is offline
Quick61's Avatar
Joined Jan 2011
Stuart
To my mind, it would seem to be a part (being out on the tip of the LE) would be much better off bending on a tip strike than being balsa and breaking. That's the way i am seeing it.
Mark
Old Nov 15, 2012, 10:37 AM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
On the control surfaces.
There's nothing wrong with using ailerons but because of the sweep you'll want to use separate inboard elevators and outboard ailerons instead of mixed elevons. The reason being you want the elevator function at the rear most point of the wing and the aileron function at the most outboard. On a swept BACK flying wing these two points happen to both be at the tips of the wing so elevons work. On a swept forward wing these two points are not at the same spot. Hence the separation of the controls.
And no offense intended to the guy that did the plans but the fin on the plans simply does not match the picture. The fin in the picture has a far more elegant look.
Achieving a stable design in this case will be a fun challenge. Either there needs to be a trifle of washIN on the tips or the center area elevators will need some up trim.
A cheap and dirty small scale chuck glider with flat wings will soon answer a few questions on how best to trim the model. Try some elevator to see if it can be stabilized. Then try another with some washin on the tips and see how it works out for stall response.
The only thing with a washin trim is that it reverses when inverted. So just adding some center section reflex with a bit of elevator trim would seem to be the better option so it can just as easily be switched to the proper position when inverted with a bit of forward stick pressure.
BMatthews is online now Find More Posts by BMatthews
Old Nov 17, 2012, 10:28 AM
Fly Wheel's Avatar
Joined Sep 2007
Mark
Mark
This is true. I have yet to build from plans alone, unless you count my Miss Stik which is about as close to a scratch build as a kit can get. This is another reason I feel a wing would be a good place to start - simplicity, and as it is intended to be a chucker than building a prototype per plans would let me experiment with the design in real world conditions.
As this bird is intended for Windier conditions and slope I can see the sence of a rudder for yaw control; however since the wings do have a slight dihedral (3.375" over span length) how would the rudder affect flight? Edit: I don't plan on areobatics, so how the washout or in applies to inverted flight would be moot.
I have saved the .pdf plans, so I can wait and ponder as long as I like before starting such a prodject
Build Log Thumb Wing Glider - Alula-ish DIY Glider rcpinoy Foamies (Scratchbuilt) 97 Jan 22, 2014 07:23 AM
Wanted Complete-ish system for 3m glider arukum17 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2009 04:53 PM
Discussion Large (10ft ish!) Electric Glider matada34 Electric Plane Talk 8 May 23, 2007 11:44 AM
Discussion Glider Point in Yorba Linda -circa 1990-ish dcairns Slope 5 Jul 17, 2006 08:53 PM
newbie.ish glider setup wanted please thesnapper Thermal 9 Sep 11, 2003 11:59 PM
