This thread is privately moderated by burkefj, who may elect to delete unwanted replies.
Old Nov 13, 2012, 02:32 PM
burkefj is online now
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
Bomarc A model, version 2
I've updated my Bomarc plans to reflect the A or B model wing/ramjets. I redesigned the ramjets to not have an X form but just double of the side view and it looks like it will work fine and weigh the same. I think it makes a cleaner look. I built this one as an A model with the wing and pods moved back and AUW rtf is 11.3 oz with an E-6RC motor.
Doing the ramjets by doubling them allowed me to round them more and it gives a better shape, I think.
I did the markings on the pieces/painting first before assembly and was very careful with the CA when applying to avoid running the marker lines. I used model master "titanium" for the ramjet rear ends, and some Q-tip shafts for the pitot/counterbalance probe thingys...
I used styrene sheet on each side of the fuse to support the rail buttons as well as give something solid to drill and glue to when attaching the ramjets.
I also added styrene strips to the bottom of the ramjets to help them survive landing rash as well as the underside of the nose, and used contact cement(uhu por) to attach it. I don't indicate that in the plans, if you land on trimmed grass it probably isn't necessary, but I already had the styrene on hand.
I did this one in a slightly different white color scheme I found with a black nose and use sharpie pens to do the panel lines/accents, sig stars and bars and vinyl letters from Office Max.
Build time was approx 8 hours including cutting plans, dry fitting, markings and finishing.
Test flight in 8 mph winds was good, boost was vertical, just a bit of weather cocking at the end of the boost that was easily adjusted back to vertical. Glide setting was fine. This is using the same relative CG position (relative to the wing LE where it hits the top view fuse profile) as the B model. IE mark the wing as shown on the plans for CG, move the wing back to the A model position and the same CG markings will apply.
Plans are updated on the plans page.
Frank
burkefj is online now Find More Posts by burkefj
Old Nov 13, 2012, 06:15 PM
mdine1us is offline
Find More Posts by mdine1us
I want to believe
mdine1us's Avatar
United States, CA, San Diego
Joined Jan 2002
That is one of the COOLEST model rockets I have ever seen. Nice!!
Marty
mdine1us is offline Find More Posts by mdine1us
Discussion any one got a freeair tom 740 mm (29") wing ? steve gerrard Flying Wings 6 Jan 10, 2013 04:53 PM
Discussion Who's got the November Meeting??? Twinboom Inland Slope Rebels 1 Oct 22, 2012 03:33 PM
Discussion NBC tom Brokaw" Gov got us to the moon" SPEED-E-FLYER Life, The Universe, and Politics 38 Aug 31, 2012 04:57 PM
Found OS MAX 40fp carburetor-Got one,Thanks Tom misplacedtexan Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 22, 2009 10:55 PM
