Old Nov 13, 2012, 12:07 PM
dalton1981 is offline
Find More Posts by dalton1981
Joined Apr 2008
Will Fatshark Dominators work with any cam?
I have this board cam http://www.securitycamera2000.com/pr...-Menu-DNR.html
And the turnigy 9x with Frksy 2.4 djt upgrade. http://www.hobbyking.com/hobbyking/s...Firmware_.html
And the Bevrc 1.3ghz 800mw video tx/rx - http://www.bevrc.com/bev-13g-800mw_p52.html
I read somewhere after buying this, that the fatsharks only work with immersion video rx/tx equipment. I bought the made-in-china kind..
I'd like some fpv goggles instead of my 10" lcd screen - my question is. Will the fatshark dominator work with my setup? and will I be able to do head tracking with the TX I bought? If there's a different goggles setup you recommend, feel free to share.
dalton1981 is offline Find More Posts by dalton1981
Old Nov 13, 2012, 12:46 PM
ridgewalker is offline
Find More Posts by ridgewalker
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
Yes they will work.
The Dominators come with either a 2.4 or 5.8 vrx built into the goggles so you would need to have a cable from the video out of your 1.2 vtx that plugs into the inbuilt vrx and switch the vrx to "video in".
Or
You could get a 5.8 or 2.4 vtx and set up a relay.
1.2 vtx on plane 1.2 vrx on ground,then video out from 1.2video vrx to video in on the 5.8 or 2.4 vtx which will send the video signal into the goggles.
The relay would enable you to have a wireless connection to your ground station when using the 1.2.
If not using the relay set up and flying on 1.2 then you would be tethered to the ground station as i was with the goggles on and the passenger lcd screen set up.
ridgewalker is offline Find More Posts by ridgewalker
Old Nov 13, 2012, 01:23 PM
Joined Apr 2008
The FOV doesn't have to match, does it? FOV is a stat listed on goggle specs, does it matter what the FOV of the cam is?
Old Nov 13, 2012, 01:31 PM
daggad is offline
Find More Posts by daggad
Aalesund, Norway
Joined Jun 2012
The FOV is short for "Field of vision". And is the angle from the edges of the screen in your googles to the center of your eyes. The wider FOV will give a "bigger" screen (closer to your eyes). But you will see imperfects better as well.
The Dominators have a quite narrow FOV of 30 degrees. But a very clear picture. I have these myself and like them a lot.
It does not matter what FOV the googles have. They will work with any analog video signal.
daggad is offline Find More Posts by daggad
Old Nov 13, 2012, 01:48 PM
Joined Aug 2008
Those specs are of the FOV of the goggles screen.
Take the predator goggles with a 25* fov,kind of like watching a small screen tv across the room,more empty space around the screen.
The larger fov is like watching a large screen tv,you can see it better.
my goggles are the Aviator version with a 46* fov which is supposed to be like watching a 80'' screen tv from 7' away.
No the cameras fov does not have to match the goggles fov,that camera you got would be fine.
The large fov in the goggles screen will give you a more immersed feeling while flying.
Discussion Any micro CP helis that will work with my 9x? johnwohl Micro Helis 9 Sep 04, 2012 10:02 AM
Help! Problem with Fatshark Dominators goggles sharonx FPV Talk 0 May 03, 2012 07:00 AM
Discussion HD keychain cam charging but not working (any help?) schmitty007 Aerial Photography 6 Mar 31, 2012 08:07 PM
Sold Fatshark Dominators with 2.4 rx 250.00 viper6549 FPV Equipment (FS/W) 2 Mar 15, 2012 10:33 PM
Question Problem with Fatshark Dominator Head Tracker and Robbe/Futaba FX-30 MrBean FPV Talk 2 Dec 13, 2011 05:35 PM
