Old Nov 13, 2012, 10:44 AM
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
ALignment of receiver antennas
I have just finished building a 3DHS 48 inch Viper. The optimal place for the receiver is with the 2 opposing antennas on the main receiver directly under and parallel with the carbon wing tube. It does have a satellite receiver on the side of the fuselage about 4 inches away with it's antennas at a perpendicular angle to the main receiver. Is there a problem with this setup? If this is OK what if there wasn't a satellite receiver? Would it be a problem then? Thanks in advance. Mike
Mr Big Head is offline Find More Posts by Mr Big Head
Old Nov 13, 2012, 01:56 PM
richard hanson's Avatar
Joined Oct 2007
On similar models - I move the rx away from CF tube - rearward as far as possible then - place the second (satellite) rx in the very bottom of the model - away from everything You can buy a longer wire to connect rx to satellite.
My basic setup assumes that generally the bottom of the model is presented to the tx (or side n bottom)
richard hanson is offline Find More Posts by richard hanson
Old Nov 13, 2012, 10:17 PM
USA, MO, Florissant
Joined Nov 2010
Ideally, the antennae should be at least one wavelength away from any large conductive objects that behave like a ground plane; that would be about 5 inches. If, however, you can turn the main receiver about 90 degrees to the CF tube, that would be better than parallel, because the shadow of the CF would be smaller at the receiver antennae, and the tube would look less like a ground plane to them.
Wintr is offline Find More Posts by Wintr
For Sale RV 2.4 Patch antenna + Lawmate 2.4 receiver sharonx FPV/RPV - Equipment and Vehicles (FS/W) 1 Aug 13, 2012 08:41 PM
For Sale 1.3 Ghz Receivers, patch antenna and Vee antenna pyrojets FPV/RPV - Equipment and Vehicles (FS/W) 1 Jul 07, 2012 06:12 PM
Discussion extra antenna or dual receivers or remote receiver for FASST? lincoln Radios 5 Jul 03, 2012 01:00 PM
For Sale 1.3 Ghz Receivers, patch antenna and Vee antenna pyrojets FPV/RPV - Equipment and Vehicles (FS/W) 0 May 25, 2012 09:10 PM
For Sale BNIB ALIGN 3GX w/ JR Satellite Antenna $135 Shipped lovespicyfood Aircraft - Electric - Helis (FS/W) 0 May 07, 2012 12:20 AM
