Espritmodel.com Heli Air
Old Nov 13, 2012, 10:20 AM
Joined Jun 2011
ServoCity Tube Gearbox (1" hollow shaft)
SPG785A1-5 - starting at just $119.98...servo included!
http://www.servocity.com/html/spg785...o_gearbox.html
Introducing the all new patented SPG785A1-5 Servo Power Tube Gearbox. A stock HS-785HB servo can rotate 3.5 turns (1.75 turns left or right from center) or 1260° total. When you install the HS-785HB servo into this tube gearbox, the total amount of rotation is decreased but the power and accuracy is increased. Position feedback remains since the internal potentiometer is not removed. Trading total rotation for power and precision is what this gearbox is all about. Simply choose the gear ratio you need (see chart for ratio specs) along with the amount of rotation your application requires. The lower the gear ratio, the more precision and power you will have but with less rotation. The SPG785A1-5 can handle tremendous side loads with the dual ABEC-5 precision ball bearing supported 1” aluminum hollow shaft. The shaft is hollow to allow wires from cameras, sensors or other devices to not tangle during multi-turn rotations. The frame of the SPG785A1-5 is machined from 6061-T6 aluminum (anodized) and offers our 0.770” hub pattern inline with the output shaft. Patented.
Want to attach this gearbox to a another gearbox? This setup works great for antenna tracking systems. Use an Aluminum End Cap (sold separately).
ServoCity is offline Find More Posts by ServoCity
Site Sponsor
New Product 1" Hollow Aluminum & Stainless Steel Tubing ServoCity ServoCity.com 0 Oct 10, 2012 09:43 AM
For Sale 6 sq tubes = 1/2" x 1/2" x 2' feet .062 walled aluminum square tubing Percalotor - Quad_Addict Aircraft - Electric - Multirotor (FS/W) 1 Jul 23, 2012 11:53 AM
Discussion Hollow inrunner motor shaft Stupot46 Electric Motor Design and Construction 5 Jul 22, 2012 12:06 PM
Discussion Removing Hollow shaft from Lama 400D Krazydy Coaxial Helicopters 4 Jun 02, 2012 08:02 PM
Wanted planetary gearbox for 1/8 shaft 3-4:1 planetary rcgreaves Aircraft - Electric - Power Systems (FS/W) 0 Jan 30, 2006 06:37 PM
