Old Dec 05, 2012, 05:52 AM
decones is offline
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Hi Spencer,
there is no play or lateral slope on this, I use 2 screws (2mm side by side) to keep the stab attached to the fuse cot, this 2 screws pass through 5mm solid carbon rod and attach to nuts in the fuse, the carbon rod do the "pivot" thing, I use some plywood as support to create the pivot hinge moviment.... Here is some pictures that helps to understand...
This is standart stratair building... I just copied them
André
decones is offline Find More Posts by decones
Old Dec 05, 2012, 09:09 AM
Jantar2A is offline
Find More Posts by Jantar2A
Just chillin @ 403 MPH
Jantar2A's Avatar
Boulder Colorado
Joined Nov 2005
From the Rawketenwurm's I have flown on the darkside I would reduce the cord of the flaps for flying at high speeds at Weldon. Looking forward to seeing it fly there.
Nick
Jantar2A is offline Find More Posts by Jantar2A
Old Dec 05, 2012, 09:12 AM
decones is offline
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Nick
What's the idea on reducing flap size?
avoid command flutter?
I'll run all the linkage on the wing bottom with huuuuge carbon horn
ordered 5 Hitec HS 7115 servos for my heavy wurm according to Joe suggestion,
it seems to be a good HV servo and it's cheaper than MKS
the light wurm will have standart Hyperion servos
Old Dec 05, 2012, 09:35 AM
Jantar2A is offline
Jantar2A's Avatar
Boulder Colorado
Joined Nov 2005
I was only using airtronics 761's on the flaps with tall carbon horns and mine would flutter in the low 200's you may have better luck than me with the servos you are using but if I were to build one for ultimate speed I would still reduce the flap cord lenth especially for weldon that has the easiest landing zone.
Old Dec 06, 2012, 11:06 AM
sll914 is offline
Find More Posts by sll914
sll914's Avatar
Joined Oct 2003
Thanks for the explanation Andre. It looks like a good solution!
The 7115th servos are great! I put them in a light K2m and like them alot so far. I would consider adding an external bearing if you want to go really fast as bearing play or flex appears to be their only limitation that might allow flutter. No flaw with the servo, I just think any servo that small could benefit from the external bearing...
sll914 is offline Find More Posts by sll914
Old Dec 12, 2012, 05:54 AM
decones is offline
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Nick
Hey Nick, your raketenwurm's was the 92"ws version F5F or the 74"ws F5B?
Mine is the F5B 74"ws, it has 17cm root chord with flap size being 4.2cm, so it's 25% of the main chord.... maybe reducinf just a little bit will help a lot, what you think?
Cheers,
André
Old Dec 12, 2012, 07:58 AM
Jantar2A is offline
Jantar2A's Avatar
Boulder Colorado
Joined Nov 2005
Mine was the 92" version so it's a different one than yours.
Old Dec 12, 2012, 12:13 PM
decones is offline
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
humm.. this give you more flap area and ...maybe....more command flutter possibility...
I played with math comparing the root chrod with flap size on DS planes,
avarage was 23% on the root are flap, my standart wurm2b is 26%, If I reduce the flap size (on the root) from 42mm to 38mm I reach that target....
Old Dec 17, 2012, 08:06 PM
Aerogance is offline
Find More Posts by Aerogance
Anyone can build! It's fun!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
You can always tape the flaps.
Aerogance is offline Find More Posts by Aerogance
Old Dec 18, 2012, 01:52 PM
josh18 is online now
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Your layup will be so much stiffer than a a standard one that I dont think it will be an issue. Are you going bottom drive on the flaps?, that will help
josh18 is online now Find More Posts by josh18
Old Dec 18, 2012, 02:02 PM
decones is offline
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
That's correct Josh, bottom drive big horns on flaps, Hitec 7115 all around, maybe will use those ext bearings to make them more solid linkage, I notice you don't use on your Scorcher.
Old Dec 18, 2012, 02:09 PM
608 km/h!
josh18's Avatar
Joined Jan 2010
Hey Andre, I used them on the flaps , and they seem great. I didnt think I'd have enough room on the ailerons but it turns out they would have fit. By the time I realized it was too late. I also could have used a smaller horn on the mks 6125 servos but I was afraid I wouldnt get the aileron travel I needed, which turned out to be a non issue. Now I know that it will fit I will use the frames next time, as there was a little slop in the ailerons that wouldnt be there with the frames. To use the frames I would have to cut one of the mounts off the frame to fit it in the wing, but the frame and servo are all glued in as one anyway so it wouldnt matter.
Old Dec 23, 2012, 04:55 PM
decones is offline
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
I ended up opening my xmas present a lttle early this year,
first rocket almost ready for launching, it's a triple carbon wing and a solid fuse,
dry weight 1370g, wing weight 1120g (with 80g on each tip).
This is my light wurm so I would be happy having it just around 2kg.
Flaps and ailerons normal size, no mod, will work hard on this linkage to have it safe and slop free...
next year I start the 3-4kg wurm..
Marry Xmas!!!
André
Old Dec 23, 2012, 05:00 PM
608 km/h!
josh18's Avatar
Joined Jan 2010
Oooh la la!
Old Dec 23, 2012, 07:39 PM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Originally Posted by josh18 View Post
Oooh la la!
+1 Very nice.
rockbus is offline Find More Posts by rockbus
Contest Gator F3B World Cup Event is on in Florida on Mar 1, 2, and 3, 2013 aussief3b Multi Task F3X 116 Apr 01, 2013 10:31 AM
Discussion Next week's PC: UAS Current Events patrickegan UAV - Unmanned Aerial Vehicles 2 May 26, 2012 10:37 PM
Discussion Next race event? boaterguy Racing Boats - Electric 2 May 09, 2012 09:00 PM
Discussion A New Event January 2013 any interest? flyingdan1 Competition Aerobatics 3 Apr 20, 2012 07:14 PM
When's the next event? Shawn Palmer Club Talk 0 Dec 30, 2002 04:09 PM
