Old Nov 13, 2012, 09:01 PM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Originally Posted by ARUP View Post
I see you've ordered... but I use the Mighty Bender. You can't got wrong with H. Higley stuff! The first time I saw the double 'L' bends you are talking about is on the Top Flite SE5 designed by D. Platt. BTW, I'm in Taylorsville, KY!
I'm in Frankfort. I think Gene Bond posted about the double L bends in the Scratchbuilt Foamies thread.
Rickochet is offline Find More Posts by Rickochet
Old Nov 17, 2012, 07:22 PM
mewert is offline
Find More Posts by mewert
Team Armattan
mewert's Avatar
College Place, WA.
Joined Apr 2004
Bender
I use a Breiten bender and cutter. I guess they aren't made anymore, but they work well. I can make the coil nosegear with it too. The cutter is a shear type.
mewert is offline Find More Posts by mewert
Old Nov 21, 2012, 09:25 AM
LWeller is offline
Find More Posts by LWeller
Holland, Michigan
Joined Dec 2006
I looked at several of these and decided K&S might be the best choice but at the last minute decided on Micromark's wire bender for three reasons:[LIST=1][*]Primarily bending 1/8" or less most frequently[*]The capture screw to hold wire in place when bending[*]Price
Another reason is I bought their small table saw a year ago (my very best friend) and appreciate the quality of their products. Go to:http://www.micromark.com/vise-mounte...nder,7044.html
I took a crude picture of the bender in a vice at work. The handle is upside down in the picture but you can see how it works. The screw is not tightened down either. The post the wire nestles against is groove to help retain the wire in position while bending.
There is a couple of other pics of my first wire bending attempt with landing gear. Luckily I got it right first time. Hope this helps someone.
Regards,
Larry
P.S. K&S will likely be my next choice for larger diameter wire. It looks good to me as well but about $10 more. Not having used one before I wanted to keep price to a minimum but for other reasons especially like the Micromark.
LWeller is offline Find More Posts by LWeller
Old Nov 21, 2012, 09:51 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
FWIW, my small K&S bender looks EXACTLY like your Micromark one
rcav8r2 is offline Find More Posts by rcav8r2
Old Nov 21, 2012, 10:51 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I got my wife one of the little table saws from them a few years ago. She does miniature doll house stuff and almost uses it daily. Great little tool albeit a tad expensive. I use it some also. It does a great job stripping balsa with the rip fence. I got some spare blades for it but amazingly it is still using the first blade. Pretty amazing considering how much it has been used.
http://www.micromark.com/microlux-mi...-saw,6936.html
BTW I ended up getting the set of three Higley Benders.
Thanks everyone for their help.
Rick
Old Nov 22, 2012, 10:12 PM
LWeller is offline
Holland, Michigan
Joined Dec 2006
rcav8r2, somehow I'm not surprised they are the same. I probably could have had my LHS order it in with their normal deliveries and saved the freight. Thanks for letting us know that.
Rick, your right about the saw expense. A friend loaned me his for a couple of years and then had the audacity to ask for it back. By that time I was so solidly hooked I had to buy my own. Before buying thought about all the airplane stuff I could have bought with the same money but I use this saw on every build...it really shines on stick builds like vintage rc planes. I found it speeds my build, far more accurate and really saves me dollars in balsa cost.
Let us know how you like your bender.
Regards,
Larry
Old Nov 26, 2012, 03:28 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Music Wire Bender & DIY "Z" Bends
DIY earlier thread:
1. Large diameter music wire aka piano wire, see examples of benders in previous thread:
. Need a GOOD music wire bender! and
DIY as per attached examples.
2. Small diameter music wire e.g. "Z" Bends:
a). Buy a pair of "Z" Bend Pliers, one squeeze and done.
b). Make an L bend with pliers and use a plastic or metal "clip" as pictured.
. - DIY Z Bends
c). Refer illustration attached. - Another method is to hold end in a vise and tap down with a hammer,
then square the z with a screwdriver tip tapped down - both can cause a ridge which eventually enlarges horn hole = slop.
More information available under
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
[Right click RCG attachments and select "open in new window".
Button bottom right of IE screen (or _+icons Firefox Toolbar) enables viewing size increase upto 400% for easier reading.]
A.T. is offline Find More Posts by A.T.
Old Nov 26, 2012, 04:56 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Rick, your right about the saw expense. A friend loaned me his for a couple of years and then had the audacity to ask for it back. By that time I was so solidly hooked I had to buy my own. Before buying thought about all the airplane stuff I could have bought with the same money but I use this saw on every build...it really shines on stick builds like vintage rc planes. I found it speeds my build, far more accurate and really saves me dollars in balsa cost. Let us know how you like your bender.
Regards,
Larry
Well, I used the Higley benders making a tail wheel wire from .078 wire. First impression is that they work ok for single bends but only so, so for multiple bends in different geometric planes. After the first bend it is difficult to make the second bend 90° to the first accurately as the the first bend tends to want to move out of position as pressure is put on the wire. You have to hold the wire with pliers inside the vice jaw which is awkward. I think someone posted a bender like the K & S with a screw to secure the wire. I will have to go back in the thread and look.
Old Nov 26, 2012, 04:59 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Originally Posted by A.T. View Post
DIY earlier thread:
. - DIY Z Bends
Alan T.
Thanks for the info Alan. I do have some "Z" bend pliers and they do work well. I also use the EZ clips with the L bends as shown in your picture. I also cut a small piece of fuel tubing and slide it over the clip end to make sure the clip doesn't pop off.
Old Nov 29, 2012, 04:13 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
My hero
Stuart A is offline Find More Posts by Stuart A
Old Nov 29, 2012, 06:32 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Originally Posted by Stupot46 View Post
My hero
Old Dec 21, 2012, 08:59 AM
William E Brown is offline
Find More Posts by William E Brown
Wichita, KS
Joined Apr 2003
Coil Bends
Any advice on making the coil (double circle) bends on landing gear wire. I have both the mini and maxi benders. It looks like I need to put in a 1/8" post to do a tight bend radius like this with 1/8" or 5/32" wire. I have been practicing with aluminum wire, will probably have to anneal steel wire for this tight bending? This is for a trailing link retract where the gear leg has a 45 degree aft bend about half way between the retract unit and the wheel axle.
William E Brown is offline Find More Posts by William E Brown
Old Dec 26, 2012, 01:51 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
K&S sells a coil bender. I use it so little, I just borrow my buddies. Works GREAT and is easy to use as the "normal" bender.
About 3/4 of the way down this page: http://ksmetals.com/accessories.html Item 326
Old Dec 29, 2012, 02:59 PM
Smoke7 is offline
Find More Posts by Smoke7
Smoke7's Avatar
Springboro
Joined Sep 2004
Wire Bender
I use this one most the time..
Smoke7 is offline Find More Posts by Smoke7
Old Dec 31, 2012, 09:40 AM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
What kind is that and where can I get one?
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Discussion What other kind of flying do you DLG guys do? Mr. Wiz Hand Launch 86 Aug 18, 2014 10:37 PM
Question What do you do with a new brushless motor before you use it for the first time? Kcal Racing Boats - Electric 6 Oct 16, 2012 06:30 PM
Discussion Piano wire vs Piano MUSIC wire- difference? Lpbug Foamies (Scratchbuilt) 7 Sep 23, 2012 09:12 PM
Discussion What kind of RC toy do you recommend me to build? s.hantiu Multirotor Talk 22 Aug 17, 2012 02:28 AM
Rant What kind of controller do you use? What should I use? Solaris1985 Electric Plane Talk 10 May 27, 2009 02:25 AM
