Old Nov 13, 2012, 09:16 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Question
What Kind Of Bender Do You Use For Piano Wire
In the past I have always just used a vice to make bends in piano wire for landing gear but getting into a kit with a faily elaborate 1/8 wire gear and may be a good time to get a wire bender. I see a couple from K & S, some from Harry Higley.
Any comments or suggestions would be appreciated.
Rick
Rickochet is offline Find More Posts by Rickochet
Old Nov 13, 2012, 09:46 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
" getting into a kit with a fairly elaborate 1/8 wire gear "
I have taken steel dowel pins, a 1/4 X 2" piece of aluminum, and made a jug that used the handle from the Higley bender to actually form the bends, Use caution, the wire will slip toward the bend as you bend, and the distance between bends will be different, from one to another. I have used small vice grip pliers to prevent this.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Nov 13, 2012, 09:54 AM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
I use bench vise to bend wire and the K&S tool. Since most gear in pairs I tape two wires together and make bends for the pair as much as possible. I try to bend without using heat as much as possible to maintain as much temper as possible. Asymmetry creeps in so at times I cut the wire and re-join with lengths of brass tube to correct for length discrepancies. This works well so long as wire doesn't have to show and is clad in balsa or etc. I also put the tube at the lowest stress area of wire like near a mounting point but not at the end nearest the axle. You probably know this already but here it is!
ARUP is offline Find More Posts by ARUP
Old Nov 13, 2012, 10:28 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I use both the K&S bender and the Higley ones. They both work great for my needs.
rcav8r2 is offline Find More Posts by rcav8r2
Old Nov 13, 2012, 10:54 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I found the Higley bender set of three for about $14 online. I like the K & S but saw a review that the mini bender wears out quickly and the larger Mighty bender will do 1/8" as the smallest.
Old Nov 13, 2012, 10:56 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Do you use the K&S mini or the mighty bender?
Old Nov 13, 2012, 12:10 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
My Mini has bent a fair amount of wire, and really isn't showing signs of wear...at least not enough for me to even consider. Unless your doing production work, I don't see it as an issue.
I love my Higley set too (I use the small size exclusively for making U-bends for control rods) , but you do have more control over the bend with the K&S bender.
Old Nov 13, 2012, 12:25 PM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I have some "Z" bend pliers I use for control rods. I also like doing "L" bends with the dubro quick links.
Thanks for the info on the mini bender.
Old Nov 13, 2012, 01:24 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
U-Bends are the way to go. No slop..none, zilch. Super easy to make. Also can have the rod enter the horn at just about any angle with no binding... Haven't used a Z or L bend in years.
Old Nov 13, 2012, 02:09 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I call my wire bender "Jim Davenport" I take him wire and a pattern,he gives me useful stuff back...lil' humor there....
I use a large bench vise and a 3/8 x 2" piece of steel with 1/4" roll pins in it.I have a bolt through two pieces of metal to keep it from slipping....I just pull the longer handle to make the bends,usually in 3/16 or 1/4 " wires.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Nov 13, 2012, 03:37 PM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I haven't tried a U bend but might try one. Another neat bend is a double L bend which is one bend down then another bend 90° to that one which allows you to remove it from the horn with just a twist.
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Great idea.
Old Nov 13, 2012, 06:17 PM
wizard of odd is offline
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, VIC, Sale
Joined Apr 2011
rcav8r2, I had to do a Google for the U bend. I'm used to L and Z bends but that one is new to me!
Odd
PS: I use the Mighty K&S bender as well as Higley benders and a bench vise for bending gear.
wizard of odd is offline Find More Posts by wizard of odd
Old Nov 13, 2012, 06:42 PM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I ended up ordering the Higley 3 piece set. I have had good success with Higley products over the years.
Thanks everyone for their inputs. Anymore DIY ideas please post them.
Old Nov 13, 2012, 08:58 PM
ARUP is offline
Joined Mar 2010
I see you've ordered... but I use the Mighty Bender. You can't got wrong with H. Higley stuff! The first time I saw the double 'L' bends you are talking about is on the Top Flite SE5 designed by D. Platt. BTW, I'm in Taylorsville, KY!
Discussion What other kind of flying do you DLG guys do? Mr. Wiz Hand Launch 86 Aug 18, 2014 10:37 PM
Question What do you do with a new brushless motor before you use it for the first time? Kcal Racing Boats - Electric 6 Oct 16, 2012 06:30 PM
Discussion Piano wire vs Piano MUSIC wire- difference? Lpbug Foamies (Scratchbuilt) 7 Sep 23, 2012 09:12 PM
Discussion What kind of RC toy do you recommend me to build? s.hantiu Multirotor Talk 22 Aug 17, 2012 02:28 AM
Rant What kind of controller do you use? What should I use? Solaris1985 Electric Plane Talk 10 May 27, 2009 02:25 AM
