Old Nov 13, 2012, 09:33 AM
Daytonarc is offline
Find More Posts by Daytonarc
United States, FL, Daytona Beach
Joined Sep 2012
Spektrum AR6210 failsafe problem
I have a Spektrum AR6210 receiver that goes to full throttle when transmitter signal is lost. I have followed the propper bind proceedure (several times to make sure this was not the problem) by placing all controls at nuetral and throttle at low idle setting when binding. After propper bind proceedure if transmitter signal is lost (I turn off transmitter to simulat in flight signal loss) the throttle channel failsafes to wide open throttle. Throttle servo is JR537. No other chanels have this erratic function when transmitter signal is lost. Does anybody have any suggestions as to what may be wrong or how to fix this? Has anybody else experienced this? Obviously I would be worried about flying with this "wide open failsafe".
Daytonarc is offline Find More Posts by Daytonarc
Old Nov 13, 2012, 09:37 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Your throttle channel is reversed
the other channels just stop receiving commands to move -so nothing happens.
richard hanson is online now Find More Posts by richard hanson
Old Nov 13, 2012, 09:41 AM
Joined Sep 2012
The throttle servo is reversed on the transmitter due to linkage configuration in aircraft. Transmitter is DX5e. The chanel is reversed via switch on transmitter (no programmable functions) but reverse switch is in reverse position when binding. How can I get the servo to failsafe to low idle with this configuration?
Old Nov 13, 2012, 09:43 AM
Joined Oct 2007
Hmm- unless you add a simple bellcrank to linkage -or a reversed servo -I really don't know.
Old Nov 13, 2012, 09:45 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Set up the radio with the throttle in the correct low position.
Re-bind rx and tx.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 13, 2012, 09:49 AM
Reflex1 is offline
Find More Posts by Reflex1
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
I think all you now need to do,
is Rebind with the Throttle at Low
This should set new failsafe points
Reflex1 is offline Find More Posts by Reflex1
Old Nov 13, 2012, 09:50 AM
Joined Oct 2007
I missed something ---
Joined Sep 2012
Re-bind rx and tx.
Andy
Andy I have done this ( 4 times) and it still failsafes to wide open throttle. When bind plug is in receiver and receiver is powered up with tx off, throttle servo goes to wide open. Turn tx on with bind switch (trainer switch) held in up position, bind till solid rx light, let go of bind switch, throttle goes to low idle.
Old Nov 13, 2012, 09:57 AM
Joined Oct 2007
Start over -bind - then remove bind plug when bind is completed.
Unless I read you incorrectly - the rx is now calling for "low throttle ".
Move throttle stick to full- turn off tx - servo will now go to low position
Y/N?
Old Nov 13, 2012, 09:59 AM
Joined Sep 2012
Y/N?
No still goes to wide open when tx is turned off
Old Nov 13, 2012, 10:01 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
So what happens if you now remove the bind plug, then power up the rx with the tx still off? It will go to the place you programmed it at the bind.
When the rx is in bind mode, there is NO SIGNAL TO THE THROTTLE! If it moves on power-up, that's because the servo went there on its own due to no throttle signal (a glitch on the line), NOT because the rx wanted it to go there.
There's not a solution for that, other than to use a servo with a different behavior. My guess is you have an analog throttle servo, no?
Andy
Site Sponsor
Old Nov 13, 2012, 10:09 AM
Joined Sep 2012
Andy
Andy, First of all I want to rocognize you for stellar customer service. Your instant replies and attention to customer concern is awsome. I was going to PM you with a link to this thread but you were on it before I had a chance. This is a new JR analog servo. I will try another servo when I get home tonight and let you know the result.
Thanks again to Horizon Hobby/Spektrum for unparalleled customer service!
Old Nov 13, 2012, 10:49 AM
Joined Oct 2007
I tried my DX5 and a AR500 rx and two different servos
A JR9001 (old design)and a Spektrum 4020 and a fresh 4.8 volt pack
The TX worked correctly in either reversed or normal switch position.
IF the reversing switch is moved after the bind is completed and the plgu removed - then - the fail safe goes bonkers .
Old Nov 13, 2012, 10:55 AM
Joined Sep 2012
Richard, Thanks. The reverse switch was in the correct position at bind. I will try another servo later this evening.
Old Nov 13, 2012, 11:35 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Skip the position of the reverse SWITCH for a second.
After you bind once, position the throttle STICK in the right (low throttle) position and use the switch to make sure the throttle is closed. Now DON'T touch the switch.
Now re-bind with the tx UNCHANGED stick positions.
Andy
Site Sponsor
Discussion Problems with Orange RX DSM2 and Failsafe jtprouty Radios 7 Nov 17, 2015 04:40 AM
Discussion Graupner MX-20 Failsafe problem zaguruinzasky Radios 5 Apr 11, 2015 04:43 AM
Discussion DJI F450 failsafe problem hartrockets Multirotor Talk 2 Sep 29, 2012 05:54 AM
Sold Spektrum AR6210 Receiver NIB, $70.00 shipped fltekdiver Aircraft - General - Radio Equipment (FS/W) 3 Apr 11, 2011 05:42 PM
