Old Dec 29, 2012, 12:47 AM
rebranger is offline
Find More Posts by rebranger
USA, AL, Huntsville
Joined Apr 2007
I have had a lot of problems with the knock off carbs on the RCG, RCFG, & SV-26's. Do a "complete" rebuild on the knock off carbs several times. Get a "real" Walbro rebuild kit, think it's a K or w -10 for about $11.00 Be sure to remove the lil plug & clean out the low & hi side jets & don't swap the needles!! Get the lil W tool & set the float properly. Put the new needle & "real" arm (China one bends). Sand the reed blocks & check for case leaks as u have been advised. I finally found some "real" Walbro Wt-694 new carbs!!
rebranger is offline Find More Posts by rebranger
Old Dec 31, 2012, 09:01 AM
Machzx is offline
Find More Posts by Machzx
Joined Nov 2012
Pulled my new Dle 30 apart to put in my Frank Bowman ring
The cylinder wall finish leaves alot to be desired
One patch is not scuffed by the hone at all
No big deal just Chinese quality control
I don't have a ball home that small so ill try makin a flap sander with some 600 grit to do it
Just a few swipes to clean it up
Machzx is offline Find More Posts by Machzx
Discussion Dle 20cc setup michael88997 Engines 14 Mar 25, 2015 08:10 PM
Discussion dle 20cc and 4blade prop chaos2984 Engines 24 Feb 07, 2013 10:46 AM
Discussion DLE 20cc unclecrash Engines 8 Jul 01, 2012 01:39 PM
Sold DLE 20cc//World Models 1/4 scale clip wing cub and extras crosby Aircraft - Fuel - Airplanes (FS/W) 6 May 08, 2012 02:07 PM
Discussion DLE 20cc VS DLE 30CC Performance/Weight mikes68charger Engines 6 Apr 21, 2011 11:23 AM
