Nov 28, 2012, 10:22 PM
United States, NC, Raleigh
Joined Aug 2012
Iv seen these "carbs boil over", for about 3.00 u can get a little w shaped tool that makes sure the metering needle inside the carb is set at the right height, if the metering needle is not set right it makes it a pain to tune. If its to high the diaphram will hold it open and can flood the engine, if set to low it can cause it to run lean. A while back I had one that after it heated up and u shut it off u could see fuel coming out of the main jet in the carb from the fuel boiling. Other than that I'd try wat one other has said with brake clean spraying around while running to see if u can hear the engine change speed. Hope this helps.
