Old Dec 29, 2012, 07:01 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
So these are in stock now, any idea if they're good?
http://www.hobbyking.com/hobbyking/s...ntroller_.html
I'm currently on my way back home, won't be back in my flat until 8pm or so. So I won't work on the frame today, I just want to relax for a while.
WiseDuck is offline Find More Posts by WiseDuck
Old Dec 29, 2012, 07:04 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Those are also a little slow, I have 2 of those.
I'm starting to suspect being slow is inherit to 1s ESCs.
Freakazoid is offline Find More Posts by Freakazoid
Old Dec 29, 2012, 07:05 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Well... I don't think they were designed with multirotors in mind. :P Just tiny indoor planes without much control authority or speed. I hope there's an Arduino Nano waiting for me at home right now so I can flash these with BLHeli. If BLHeli is anything like SimonK then I will be very happy.
Old Dec 30, 2012, 12:29 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Tadaaaa!
But I still have a long ways to go before I have a working quad. If I even get that far, we'll see how it goes!
Old Dec 30, 2012, 02:54 PM
Freakazoid's Avatar
Joined Dec 2004
Aha, well on your way I see! Im actually a bit jealous of your carbonfiber model, it looks quite nice.
I bet its quite light as well!
I truly hope those ESCs are the little miracles we've been looking for.
Old Dec 30, 2012, 05:03 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
It's very light yeah. Not quite as stiff as I thought it would be, but considering how little weight it needs to carry, it won't be a problem. Now I just need to figure out the wiring, pull off a bunch of unnecessary pins from the Afro Mini board and so on. Think I'll stay up for a couple of hours and work on this thing. Won't have time for this tomorrow, it's new years eve and I'm going to a party. :P Also, fireworks.
I'll cut another one from 1.5mm CF later. Unfortunately, with the 300x100 sheets I'm not sure I can cut a frame that'll work with 3x2 props. I might have to find a bigger sheet later if I don't get enough lift from the 2x1 props.
Old Dec 30, 2012, 06:51 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
You cut that by hand..?
Look like the sheet was just a bit too small.. there are flat spot on the motor mount.
Look real good..
Dialfonzo is offline Find More Posts by Dialfonzo
Old Dec 30, 2012, 06:53 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Nah, me and my father drew it in EdgeCam, generated a program, I then prepared a CNC machine at work and cut it. Unfortunately, we didn't have any good tools at hand, so we had to improvise a bit and the mount wasn't perfect... So we got a few flat edges. Not that it matters in the end, itll still perform well, flat edge or not. :P The program was made so the entire sheet was used, so we had to mount it at a perfect 90 angle. We couldn't.
Still, the end result was surprisingly good considering how crappy our solution was.
Old Dec 30, 2012, 06:55 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Sure and you can be proud to have made it yourself..
What kind of CNC it was ?
Old Dec 30, 2012, 06:59 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
An old, used and worn out Dyna DM1007. It's an old brand, not sure if they make machines anymore. I wanted to use a newer machine, but I could not be arsed to remove the axis guards, hook up the spindle oil cooler etc..
Old Dec 30, 2012, 07:02 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
A big milling?
I like cnc.. Haha
Old Dec 30, 2012, 07:15 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Nah, its quite small. 250mm in X, 200 in Y. Something like that. :P CNC machines are great, I wish I had one at home.
Old Dec 30, 2012, 07:26 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Here is my baby..
It's a routing table not a milling.
Would like to have a smaller stronger thing to cut Aluminum clean and fast.
Still experiencing with Alu.
Old Dec 30, 2012, 07:34 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
That's certainly good enough for making frames. Most of them consist of flat parts anyway. :P
Old Dec 30, 2012, 07:36 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes mostly..
I am playing with a design i like these days.
Discussion Need help with getting the smallest and lightweightest possible setup for an orni Legendary_Agent Ornithopters 17 Apr 26, 2012 08:37 PM
New Product The ROME Board or Smallest Simple Brushed/Brushless Motors Controller 26*27mm Doblao Multirotor Talk 36 Apr 02, 2012 08:23 AM
Smallest Flying Wing Possible snowball1288 Foamies (Kits) 7 Dec 28, 2004 06:39 AM
