Old Dec 14, 2012, 03:35 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Originally Posted by SebastianJ View Post
What ESC's are you using?
http://hobbyking.com/hobbyking/store...dProduct=10334
Freakazoid is offline Find More Posts by Freakazoid
Old Dec 14, 2012, 03:48 AM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Originally Posted by Freakazoid View Post
I believe those are Atmel based, if so they can be flashed with SimonK firmware.
Have you peeled the heatshrink? I'd like to see how they look naked.
SebastianJ is offline Find More Posts by SebastianJ
Old Dec 14, 2012, 03:52 AM
Freakazoid's Avatar
Joined Dec 2004
I'm sure they can, but not by a mere human like me.
Because I don't posses a microscope and 80 dollar IC clips.
Old Dec 14, 2012, 03:59 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
They are rebranded AEO ESC's can be programmed with a card.
Also sold as Moxie 5A ESC by LowpriceRC and card.
If you're not reflashing them, try the program card.
Old Dec 14, 2012, 04:03 AM
Freakazoid's Avatar
Joined Dec 2004
I cant do it with the TX?
Cause im not fond of blowing another 10 bucks on something potentially useless.
Old Dec 14, 2012, 04:22 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
I guess you can do it with the TX if you're patient , some ESC's has functions that are not available by TX programming.
Old Dec 14, 2012, 02:45 PM
Droner
SebastianJ's Avatar
Joined Mar 2006
Originally Posted by neobot View Post
timecop made that too
yes it could be slightly bigger than that white board looking at the pics ive seen but its smaller than the afromini got that too
here it is sat next to a postal mark on top of a sent UK letter
Attachment 5303124
Where can I buy this?
Old Dec 14, 2012, 03:47 PM
Freakazoid's Avatar
Joined Dec 2004
Ive tried setting it with the remote, setting startup to "fast" didnt do a thing, so I tried "super soft",
which resulted in a spin up that was almost comical. So programming was working.
Unfortunately this means this is as fast as id get em. Which is not good enough.
So if anyone wants em...
Old Dec 14, 2012, 04:21 PM
ABLomas is online now
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
So... Just reflash them with custom FW and use on multicopter?
Should be easy (they got 8L if photo provided earlier is correct).
ABLomas is online now Find More Posts by ABLomas
Old Dec 14, 2012, 04:58 PM
Freakazoid's Avatar
Joined Dec 2004
Like its easy soldering wires to 0.2mm IC legs? I certainly cant.
Old Dec 15, 2012, 02:34 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
They're not 0.2mm AFAIK.... MLF? Should be doable with some patience (i did that with basic tools, on few ESC's).
And... Maybe there are pads?
You got close-up photo?
Old Dec 15, 2012, 03:15 AM
Freakazoid's Avatar
Joined Dec 2004
This isn't a normal run of the mill fat amtel IC, its even smaller then that, and no pads.
Trying to solder a laquer wire to it would be insane, and once that solderingtin bridges even one leg its game over.
Yes its possible but youd need hair wire, a magnifier, and some kind of extremely sharp and thin iron.
Not what id call basic soldering...
Old Dec 15, 2012, 05:06 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
You think HKs new Atmel programmer will work on them?
WiseDuck is offline Find More Posts by WiseDuck
Old Dec 15, 2012, 05:22 AM
Freakazoid's Avatar
Joined Dec 2004
You mean that big white "stamp" looking thing? I think that only fits the regular sized IC's.
Old Dec 15, 2012, 05:52 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Right. I'm not even sure what the "regular" size is. Anyhow, glad I went for the Supermicro ESCs, it seems like they have pads for programming the CPU so flashing them with BLHeli should be easy. Still waiting for my Arduino Nano though, I need to reprogram that to turn it into a Silabs programmer.
Discussion Need help with getting the smallest and lightweightest possible setup for an orni Legendary_Agent Ornithopters 17 Apr 26, 2012 08:37 PM
New Product The ROME Board or Smallest Simple Brushed/Brushless Motors Controller 26*27mm Doblao Multirotor Talk 36 Apr 02, 2012 08:23 AM
Smallest Flying Wing Possible snowball1288 Foamies (Kits) 7 Dec 28, 2004 06:39 AM
