Old Nov 13, 2012, 03:00 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Question
Smallest possible multicopter controller?
I was wondering, what are currently the smallest multiwii controllers?
I found a nano controller, though with its mountholes still at 35mm its smaller size is moot.
Id like to see something even smaller, with only the solder pads necessary, to be mounted gyro-style, with a foam pad.
Anyone know of a poststamp sized controller?
Freakazoid is offline Find More Posts by Freakazoid
Old Nov 13, 2012, 03:43 AM
rmteo is offline
Find More Posts by rmteo
User
Colorado
The entire control board (RF receiver, FC, ESC) of a Walkera Laydbird quad is only about 20x20mm - perhaps you can hack into it?
rmteo is offline Find More Posts by rmteo
Old Nov 13, 2012, 04:28 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Not available on TC store, but ask him - he still has some.
I used it as aircraft stabilizer and as copter controller. Works with baseflight - MultiWii 32 bit version.
Low price (~35$ all included), very small dimensions and low weight - good for anything, from flying wings, airplanes and DLG (that was original idea - to use it as variometer for DLG (that's why it has baro) and get aditional stabilisation and navigation, including auto thermalling), to multicopters ;-)
ABLomas is offline Find More Posts by ABLomas
Old Nov 13, 2012, 06:42 AM
JWinNewPhila is offline
Find More Posts by JWinNewPhila
JWinNewPhila's Avatar
United States, OH, New Philadelphia
Joined Jul 2012
The "Flip" from Witespy is only 35mm X 35mm. And has on board micro usb for programming. And it's only $20!
Click here....
And HERE is the thread about it.
JWinNewPhila is offline Find More Posts by JWinNewPhila
Old Nov 13, 2012, 12:26 PM
Freakazoid's Avatar
Joined Dec 2004
Those things are fun, they take a lot of abuse but they are too "standard" for me now.
Im trying to steer clear of both brushed motors and proprietary rx/tx systems.
I've got a method to make an assan RX only 1.8grams and output up to 12 channels PPMsum.
Oh, thats the gravy, right there.
That thing would pretty much shrinkwrap right ontop of a stripped assan receiver, making it stupendously small.
No hexacopter option is a bit unfortunate though. Do you happen to know what sensors are on it?
Im also not quite sure what multiwii 32bit is, im used to working with straight up conventional multiwii.
edit: Well aint that something, its exactly the same size as a stripped assan receiver. Was that on purpose?
Click here....
I got a similar one to those. Still too lumpy for a 1 celled setup though.
Old Nov 13, 2012, 12:45 PM
ABLomas is offline
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Sure, MPU6050 + BMP085.
And... No hex options, etc - because it was designed for micro-airplanes/gliders, but could work for copters also...
You could simply solder aditional needed pins to MCU, but... Too much work just to have "micro" FC.
Old Nov 13, 2012, 01:56 PM
Freakazoid's Avatar
Joined Dec 2004
Sensors are nothing to sneeze at, pretty darn good for that kinda money.
I dont think my hand is steady enough to be messing with 0.2mm spacing on that MCU.
A redicilously small quaddy should be alright with that board though, I think.
Just one question though, who's TC?
And can you explain what multiwii 32bit entails?
Do I need a completely different instructionset?
The "traditional" arduino firmware wont work I take it?
Old Nov 13, 2012, 02:01 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
TC = Timecop. I've already emailed him about this board. I want one too!
WiseDuck is offline Find More Posts by WiseDuck
Old Nov 13, 2012, 02:14 PM
Freakazoid's Avatar
Joined Dec 2004
Oh djeez, Timecop! Now it clicks, ok, thanks!
Didn't his boards need some weird converted firmware business though?
Old Nov 13, 2012, 02:29 PM
ABLomas is offline
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
How about reading a bit?
http://code.google.com/p/afrodevices/wiki/AfroFlight32
http://www.rcgroups.com/forums/showthread.php?t=1595761
Old Nov 13, 2012, 03:05 PM
Freakazoid's Avatar
Joined Dec 2004
Hmmm, looks like it runs on some kind of converted naze firmware?
Ill have to take a closer look, but im worried it might not be as easy to configure as im used to.
Old Nov 13, 2012, 03:06 PM
ABLomas is offline
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
It's MultiWii....
For me it's much easier to use than multiwii - no need to compile, no need to use some stupid IDE - just upload hex file, set gains in multiwii gui (or cli) and fly.
But... Nvm.
Old Nov 13, 2012, 03:35 PM
Freakazoid's Avatar
Joined Dec 2004
But in the first post it says "MultiWii-dev port to STM32 ("baseflight" in SVN)".
Isn't that some kind of conversion/recompile of the origional multiwii code?
But it can be accessed as a regular multiwii then?
Can I stick my bluetooth receiver on it and fiddle with it on my tablet like I do with my regular multiwii fleet?
Old Nov 13, 2012, 03:36 PM
ABLomas is offline
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Yes, it is.
But no relations to naza, as you told before.
Yes you can. RTM.
Old Nov 13, 2012, 05:45 PM
Freakazoid's Avatar
Joined Dec 2004
Well if it operates like a multiwii and configures like a multiwii.. good enough for me.
Ill send timecop a message, see if I can get one that's already programmed so all I need to do is some configuring.
Discussion Need help with getting the smallest and lightweightest possible setup for an orni Legendary_Agent Ornithopters 17 Apr 26, 2012 08:37 PM
New Product The ROME Board or Smallest Simple Brushed/Brushless Motors Controller 26*27mm Doblao Multirotor Talk 36 Apr 02, 2012 08:23 AM
Smallest Flying Wing Possible snowball1288 Foamies (Kits) 7 Dec 28, 2004 06:39 AM
