Old Nov 13, 2012, 01:29 AM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
1280 V antenna range
What is the difference in the signal strength on a typical VTx V antenna? front to rear, how much actual distance does it generally mean? Of course I'm considering facing the V toward the tail and I'm trying to determine the value.
picard10th is offline Find More Posts by picard10th
Old Nov 13, 2012, 07:17 AM
PeeMax is offline
Find More Posts by PeeMax
Registered Loser
PeeMax's Avatar
Iceland, VestmannaeyjabŠr
Joined Aug 2011
IBcrazy wrote that it gives a "slight" difference if I remember correctly, not sure what that means
PeeMax is offline Find More Posts by PeeMax
Old Nov 13, 2012, 12:48 PM
slowjett is offline
Find More Posts by slowjett
-NEFPV-
United States, MA, Sturbridge
Joined Jun 2008
The open end of the vee has a bit better transmission than the pointy end. Therefor its recommended to have the open end towards the nose of the aircraft so you dont lose signal after you've turned around.
slowjett is offline Find More Posts by slowjett
Old Nov 13, 2012, 01:24 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The reason is polarization. Te Vee has no balun on it and therefore it will tilt slightly in favor of the open end of the antenna. Range difference is imperceptible.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 13, 2012, 02:15 PM
picard10th's Avatar
Joined Jan 2007
That's what I wanted to hear, Thanks!
Sold RMRC 1280 Optimized 8dBi Patch antenna Opus44 FPV Equipment (FS/W) 2 Jul 18, 2012 12:20 AM
Found 1280 antennas thefokker FPV Equipment (FS/W) 3 May 03, 2012 01:25 PM
Found 1280 CP Antennas airbagit13 FPV Equipment (FS/W) 8 Apr 10, 2012 11:16 PM
Wanted 1280 Bluebeam Antenna set airbagit13 FPV Equipment (FS/W) 0 Apr 04, 2012 11:55 AM
For Sale ground plane antenna 1.2 ghz 1280 quadcopter007fpv FPV Equipment (FS/W) 0 Mar 14, 2012 10:08 PM
