Get 'er good and wet on top and bottom...You have to very carefully block it up with no twist..But you need to put the bow up...block it off the work surface as high as the "bow",then weight it down and let it dry a long time..The weight should push the center of the panel slowly to the surface. It should now be bowed the 'other' way when it dries.
When you remove the weight,it should end up straight. If you haven't glassed the surface yet , you can weight it then too..but it should be straight before you begin. Oh-it doesn't matter whether it's hot or cold water-it's the same amount of 'wet' |
Latest blog entry: Model Builder
| Thread Tools | |
| Poll Phoenix Vs. Realflight for Fixed Wing 3D | Gringostr | Simulators | 8 | Sep 20, 2012 10:01 AM |
| Yippee! Fix for wing rock, Sebart Katana S 30E | Stark | 3D Flying | 9 | Aug 23, 2012 02:58 PM |
| New Product JCX-M6 Flight Controller for RC Airplane RC Model Plane FPV Fixed-wing Airplane | wenney2009 | Video Piloting (FPV/RPV) | 3 | Jun 19, 2012 05:10 AM |
| Discussion Phoenix difficult setups for fixed wing planes | JReis | Simulators | 4 | Apr 27, 2012 05:41 PM |
