Old Nov 12, 2012, 10:19 PM
danielwow12 is offline
Find More Posts by danielwow12
Joined Nov 2004
New to the hobby, need some advice
Hello everyone!
I am interested in purchasing my first rc sailing yacht, but I wanted some advice first!
I am not new to the rc hobbies (helis, planes) but I am new to boating. There are a few models I am considering but they all seem to require radio electronics which are not included.
I am "ok" with that seeing as how I own a dx6i. My only problem is I am now concerned about which receiver I should use to go along with it as well as a "receiver battery" which I'm not entirely sure about. There are so many different ones (and counterfeits) I'd hate to invest in the wrong products.
I look forward to your suggestions and can't wait to get started!
Also: which models would you recommend nowadays? There are some REAL cheap ones over at hobbyking, but I'm trying my best to avoid them as seeing the reviews are very up and down in regards to their longevity and performance. I'm not really too interested in racing, just looking into a great boat for a nice day.
danielwow12 is offline Find More Posts by danielwow12
Old Nov 12, 2012, 10:43 PM
thorsail is offline
Find More Posts by thorsail
thorsail's Avatar
Chicago , Illinois
Joined Jul 2008
Hi Daniel
I can start the ball rolling on one topic - since your already using Spektrum
technology your golden - if you want a dedicated RX for a sailboat all you really
need is one of those "orange" generic ones- very little chance you will run out
of range - just keep the antenna up under the deck as best you can, and
oriented with the bow/stern of the yacht.
batteries will be a interesting topic - as you already have a charger and RX
packs, we just need to see do you have anything "in stock" that will have the
MA's to give enough run time - and if you just cruising around for laughs maybe
that don't even matter ? when we race, my boat can be powered up for like 4
hours - I could use smaller packs and change during a lunch break -but I run
bigger heavier boats, so I don't care about pack weight. in smaller boats weight
can be an issue. also, smaller boats,smaller servos, so less power needed...
I think a lot of "rtr" boats probably use 4.8v, my big hulls I need 6v. neither will
be too much for any RX, voltage wise.
I'll let the next guy jump in here now...
by the way - where are you from ? any RC sailboat clubs near you ?
you can find out on the AMYA website----www.theamya.org
look under the "club locator" tab there.-local help/hands on is always good
for a newby.
Allan
thorsail is offline Find More Posts by thorsail
Old Nov 12, 2012, 10:55 PM
Joined Nov 2004
Thanks for the post!
Outside of a bunch of 2300 mah AA rechargeable energizers and a 1000mah nimh I have nothing. Not opposed to getting some more, just not sure of what I'd need. Run times for me wouldn't need to be too extraordinarily long, I'd hate to be in a situation where I'm lost at sea though!
I know of the orange rx and I'm ok with getting one. My only concern is we tend to avoid those with our rc planes, and I fear the sailboat might get "stranded" out in the lake!
I'm currently living in AR due to work, no clubs unfortunately But tons of little ponds and lakes I'd love to relax at on the weekends!
Old Nov 12, 2012, 11:08 PM
thorsail is offline
thorsail's Avatar
Chicago , Illinois
Joined Jul 2008
Daniel
those batteries are fine-I run 2300 nimh packs and can't run them out-and
that is on some BIG servo's.
you said planes/helos so I figured little lipos or such for you.
if ALL you batts are charged, and you can still see your boat, you will have
a signal.yes, they sell those add on antenna's, you shouldn't need it.
another perspective : plane=lost signal=crash
sailboat=lost signal=it drifts to shore (eventually)
Old Nov 12, 2012, 11:12 PM
Joined Nov 2004
OK thats great! Do you think I could get a 4x AA battery holder for the Rx pack then be good to go along with the orange rx?
Old Nov 13, 2012, 03:24 AM
mrpenguin is offline
Find More Posts by mrpenguin
Australia, TAS, Penguin
Joined Mar 2012
@danielwow:
Batteriies first - I use the 5xAA 2300 ESD NiMh packs from HobbyKing they will last all day with anything up to and including an A class. Works for me...
You are also asking for advice on what boat.....big question, there will be lots of opinions - my two cents worth:
1) Have a think about how much money you want to outlay
2) If there is anyone nearby sailing already, consider something similar
3) Consider the size - relating to storage and transport - a one metre boat will be nearly two metres high fully rigged
4) Consider the sailing location - shallow ponds mean smaller boats
5) Small boats (eg 500mm) are much more tricky to sail than larger boats (eg 1000mm) Larger boats are faster. Smaller boats need less draught
You are wary of HobbyKing - from my experience you get what you pay for. I have three Chinese boats (two of them from HobbyKing) Example - a 1 metre Phantom plus batteries plus charger plus Hobbyking TX and RX plus freight comes out under $200 in most cases. The Phantom is a great boat for the price. Ditto for the 800mm Surmount and the 900mm Monsoon. Yes they do go better and reliability improves with some simple modifications.
Further up the price scale are a wide and varied range that others will no doubt be able to advise you on....
Hope this helps....
mrpenguin is offline Find More Posts by mrpenguin
Old Nov 13, 2012, 03:27 AM
liljimmy is offline
Find More Posts by liljimmy
20M northeast of Hell Mi
liljimmy's Avatar
United States, MI, Howell
Joined Jul 2012
Be for you purchase batteries an such do remember their are air and ground radio channels (being that you fly you know the routine) http://rcsource.hobbypeople.net/faqs/freqlist.htm 2.4 gig hetz? Boat size; the larger boats handle differently then the smaller ones you can scale size and weight but you can’t scale the wind or water that’s why I prefer the lager boats(that and I have a pick up truck) Their are a lots of starter kits on the market when you decide on size (will it fit into your car)maybe a used one just to get your feet wet ? I started with a ryobi kit that sailed just fine. got involved with local amya club they help out a lot
Most sail radios that I have seen only need 2 servos (rudder and sail winch ) believe it or not I use rayovac or the local brand and I sail all day (no power needed when sailing in a straight line )
my newport 12 http://www.rcgroups.com/forums/showthread.php?t=1685085
I bought for a bought $ 500 back in the late 80s it was used but it was ready to sail. I redid the deck and painted it and a new set of sails, deck oal is 1 inch shy of 6 ft the mast is 80 inch and weight is aprox 40 lb that would not fit into most cars of today
Just post your findings and ask, most of the comments a helpful on this sight
liljimmy is offline Find More Posts by liljimmy
Old Nov 13, 2012, 03:44 AM
SleepySean is offline
Find More Posts by SleepySean
PEMAC
SleepySean's Avatar
Australia, New South Wales, Penrith
Joined Jul 2007
Might want to consider LiFe batteries for RX packs. No more expensive than nimh, but lighter.
Something like this?
http://www.hobbyking.com/hobbyking/s...iver_Pack.html
SleepySean is offline Find More Posts by SleepySean
Old Nov 13, 2012, 04:04 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi DaniŽl,
In my 1M sailboat, I use a 2S lipo 4000mAh, combined with a UBEC, so the receiver and sailservo get their 6V.
The boat has a runtime of several days on one charge, depending on wind and weather ofcourse.
Check the sticky on top of this section for information on the various choices of sailboats available.
The Chinese boats suchs as Monsoon are not bad, but need a number of modifications to make them sail reliable without sinking tendencies.
Check out this forum for those threads.
If you have questions, post them here, prior to buying something that is known to sink at the first outing...
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Nov 13, 2012, 11:28 AM
Joined Nov 2004
I was thinking about picking up a thunder tiger victoria and the appropriate servos for it. Do you know how well it runs out of box?
Old Nov 13, 2012, 02:27 PM
seabee CE is offline
Find More Posts by seabee CE
Nirvana 38, Seawind 178
seabee CE's Avatar
Joined Feb 2012
The victoria and Nirvana are both nice boats, I believe you can get the Nirvana with or without radio gear. Haven't been around a vicky for awhile but seem to remember them being nice once some updating was done. The Nirvana will need less tweaking to be a good sailer. Doubt you could go wrong with either, surprised you haven't had someone suggest building a wood kit, but sure it will happen. Welcome to the sport, I'm sure you will enjoy it.
seabee CE is offline Find More Posts by seabee CE
Old Nov 13, 2012, 04:11 PM
Fokker Ace is offline
Find More Posts by Fokker Ace
Fokker Ace's Avatar
Joined Aug 2006
You should build a wood kit.
Try a Tippecanoe T27 or T37. You can request it without the radio to save money. The boats sail fantastic, take only a couple weeks to complete and in the end you'll have the wonderful satisfaction of creation rather than simply opening a box from China.
Fokker Ace is offline Find More Posts by Fokker Ace
Old Nov 13, 2012, 11:59 PM
liljimmy is offline
liljimmy's Avatar
Joined Jul 2012
oooooo nice boat what are specks for that ?
Old Nov 14, 2012, 04:49 AM
mfr02 is online now
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Very well. It does need a high torque servo to work the sails if it is to perform in wind, as opposed to moving air. Mine was second hand, and benefited greatly from re-rigging after I had read the instructions.
mfr02 is online now Find More Posts by mfr02
Old Nov 14, 2012, 03:48 PM
Hircsailor is offline
Find More Posts by Hircsailor
Kimo
United States, HI, Honolulu
Joined Jun 2011
The Tippecanoe T37 is 37inches long and a total height of 5 feet. It weighs 4lb ready to sail and has a sail area of over 600 sq, inches. It's easy to butld and could been built in under 2 weeks. The nice thing about his kits is that they come with every needed to build the boat and the only thing that you need to buy is paint to finish the boat. I have built a T37x and am now building a T50.
Hircsailor is offline Find More Posts by Hircsailor
Discussion need some advice on buying the MJX-F45 or the G.Tec 9019 alcatres Large Electric Helis 7 May 27, 2012 01:13 PM
Discussion Need some advice for steering servo for racing traxxas13 Off-road Cars 7 Apr 19, 2012 11:19 PM
Help! Initial Setup - Apprentice...need some advice before buying. holic86 Beginner Training Area (Aircraft-Electric) 17 Apr 12, 2012 03:54 PM
Discussion Need some advice please quadcopter goldsworthy Multirotor Talk 5 Mar 09, 2012 05:41 PM
