Old Nov 12, 2012, 08:37 PM
One apostrophe may be too many
patmat2350's Avatar
Motor City
Joined Dec 2004
Ballast Tanks
I've mentioned before how I like to make lidded compartments or removable ballast tanks to hold lead shot ballast. Here's my latest, in Sikuliaq. They'll be removable for easier filling and adjusting, and to make transport easier.
The tanks are faceted boxes of 1/8" plywood with plenty of gusseting inside. They nestle in between frames in fore and aft positions, and are built to hold enough shot to take the model to its waterline. A center divider will let me trim P&S sides.
BTW, solid lead weighs 6.5 oz per cubic inch. Round shot has about a 70% fill efficiency, which means a cubic inch of lead shot weighs 0.70 x 6.5 = 4.6 oz.
If I need 5 lbs = 80 oz of ballast, then that is 80 / 4.6 = 17.4 cu inch tank volume.
Since I designed the tanks in CAD, I was able to easily calculate the volume! Trial and error also works.
patmat2350 is offline Find More Posts by patmat2350
Old Nov 12, 2012, 08:40 PM
patmat2350's Avatar
Motor City
Joined Dec 2004
More examples:
Forward ballast tank in my 1:12 scale DUKW. More was installed behind the wheel arches aft.
Old Nov 12, 2012, 08:43 PM
patmat2350's Avatar
Motor City
Joined Dec 2004
Dearborn's bilge cabinets, partially filled with lead shot.
Old Nov 12, 2012, 08:49 PM
patmat2350's Avatar
Motor City
Joined Dec 2004
Model Slipway's Envoy, with a fiberglass hull.
Old Nov 12, 2012, 08:53 PM
patmat2350's Avatar
Motor City
Joined Dec 2004
My big 54" 45' ST tug used PVC pipes loaded with shot. They nestled into cradles for repeatable location.
Obviously, it's best to do this early in the construction!
Old Nov 12, 2012, 08:57 PM
P31
United States, WA, Spanaway
Joined Dec 2011
I like to use hefty bag's pre-measured at 1Lb and 1/2 Lb, then I can adjust them where I need them. I would have shot all over the place using that methode
P31 is offline Find More Posts by P31
Old Nov 12, 2012, 08:58 PM
patmat2350's Avatar
Motor City
Joined Dec 2004
I also used PVC pipes to load the ballast into this 1:144 Yamato.
Old Nov 12, 2012, 09:03 PM
P31
Joined Dec 2011
Looks very nice, and clean.
Old Nov 12, 2012, 09:04 PM
patmat2350's Avatar
Motor City
Joined Dec 2004
I find it worthwhile to neatly store the ballast... "ship shape and Bristol fashion"... sort of like the difference between:
and:
Old Nov 12, 2012, 09:05 PM
Shoreacres Texas
Joined Apr 2007
You always do such neat construction. Everything fits perfectly. The inside of your models are as well done as the outside. Everything has a place. Gives the rest of us mortals something to work towards. I like it.
Gravman is offline Find More Posts by Gravman
Old Nov 12, 2012, 09:10 PM
P31
Joined Dec 2011
Ah, you close the hatch, and no one will know.
Old Nov 12, 2012, 11:55 PM
P31
Joined Dec 2011
Mr Pat, have you ever used water bladders that you could pump water in and out, I have heard of this being done but never seen it done.
Gary
Old Nov 13, 2012, 01:13 AM
EUrope
Joined Apr 2008
In big tug boat I am using water tanks, instead of balast. They are free floded, there are holes on the bottom, air is going out via pipe over waterline. Once tug is in the water, tanks are floded, once tug is lifterd up, water is running out via holes in the bottom. Of course, there are two lead acit batteries, so some 4 LB of weight is there anyway. But better as 20 lb of shots. Water is always in the lake ;-) transportation is not required. Tanks alone are made of fiberglass, directly glued to the hull.
DDG 51 is offline Find More Posts by DDG 51
Old Nov 13, 2012, 01:30 AM
Tygum Lagoon Terror
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Water ballast does not work well for long narrow top-heavy hulls, the weight needs to be concentrated below the waterline.
Nice post Pat, Ive heard of lead shot placen into plastic bags and mixed with epoxy, then placed in the hull, this makes custom ballast that fully conforms to the available space but is still removable as the occasion may require
Cheers
Nick
nick_75au is offline Find More Posts by nick_75au
Old Nov 13, 2012, 07:26 AM
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Similar to fuel tanks aboard real vessels.
Jerome Morris is offline Find More Posts by Jerome Morris
Link Video link to dual syringe ballast tank CarreraGTSCS Submarines 10 Jan 27, 2007 10:39 PM
Discussion Revell VIIc/41 piston ballast tanks gpw-Pat Submarines 3 Apr 10, 2006 07:22 PM
Piston type ballast tank question CarreraGTSCS Submarines 21 Oct 29, 2005 02:06 AM
Ballast Tank Pumps Tregurtha1013 Dock Talk 5 Dec 10, 2004 07:29 AM
ballast tank and blow system Netminder321 Submarines 3 Jun 07, 2004 10:01 AM
