Old Nov 14, 2012, 12:28 PM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Originally Posted by Chuchuf View Post
henke, this project must be edf. While I would like to build it with a P200, that is just not an option.
I like your ideas too, I just want to shuf in my experiences. Reading only on rcgroups leaves you lonely with the electric fanboys and you might loose the whole perspective.
Check out Andys T38 above(close in size and weight of the L39), an awsome project but badly needs more power if you ask me. 12kW sounds like alot, but for a big plane like this it's still marginal for aerobatic flights.
henke is offline Find More Posts by henke
Old Nov 14, 2012, 06:06 PM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
United States, GA, Atlanta
Joined Aug 2009
Originally Posted by falcon5 View Post
For planning and to get an idea of large EDF possabilities here is a twin Stumax 100mm EDF powered 12 foot long T-38 that flew decent on 6000 watts per fan for about 28 pounds of thrust. The plane weighed 44 pounds AUW and with onboard GPS reported 135 mph on a flat pass, calm wind.
http://www.youtube.com/watch?v=1SS2cD69wAI
Falcon.
I'm pretty impressed with the performance of your plane and would be pleased with performance like that.
Do a straight interpretation, if I hit 60 lbs, I'll need 8000+ W per fan to achieve results like yours assuming the air frames are equal (which they aren't)
So some quick math says on 14S I would be looking at 143A at 4V/cell call it 150A. Thats reasonable. Comes out to 266W/lb but I'm sure there will be a certain inefficiency of the twin so lets say 230W/lb. I'm still pretty happy with that.
Falcon, how did you construct your thrust tube arrangement?
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Nov 14, 2012, 06:11 PM
Chuchuf is offline
Joined Aug 2009
henke, you know from other groups that you and I are in that I like to go fast. Maybe not quite as fast as you but fast none the less.
If I build this plane it will be for someone else who would be very happy with performance like Andy's T38.
So I think that is a goal to shoot for.
Terry
Old Nov 15, 2012, 01:14 AM
henke is offline
henke's Avatar
Joined Jan 2001
Terry
If that's the case all is fine All is not about going fast, next years project will go slow but still with great performance.
Old Nov 15, 2012, 06:07 AM
LJE4357 is offline
Find More Posts by LJE4357
Closed Account
Joined Jun 2002
Speed of sound
True Steve, But the Speed of Sound we are used to is at Std temp and Sea level. See what happens to it when to go up to altitude, and temperature, and preassure changes, because of compression. LIke I said before, EDF's are air pumps, not turbines. There is no "Gain" like you have in a turbine. Also the XF-88B and XF-84H use laminer flow airfoils. EDF blades are nowhere close to that.
Bottom line, there is a limit to All EDF's as far as maximum RPM. If you want more thrust, the swept area has to get bigger.
My 2 cents worth
Larry E.
Originally Posted by Steve C View Post
Why would this have to be true? Wouldn't every fighter jet fall out of the sky then because the wing would stall at supersonic speeds?
A prop or fan can be made to run supersonic as long as the airfoils and angle of attack are under control. This was tested by NACA with a 6,000 hp prop dyno/windtunnel and the XF-88B and XF-84H
It is however unlikely that the ET fan was designed for this or that they ever ran one near 100k rpm.
LJE4357 is offline Find More Posts by LJE4357
Old Apr 05, 2015, 09:50 AM
valout is offline
Find More Posts by valout
Joined Apr 2015
Dear sir,
exist a 130 or 200 mm edf fan ?
need minimum 15kg trust
regards
v.e
valout is offline Find More Posts by valout
Discussion Sorting Classifieds by States ??Can this be done? eng30 Trader Talk 5 Aug 11, 2012 10:40 PM
Discussion 120Sr with AS3X from the mCPx - Why can't it be done? jbb Micro Helis 3 Apr 13, 2012 01:59 PM
Discussion Can "IT" be done... configure Forward and Reverse on a hobbyking brushed ESC fly_right Electric Power Cars 2 Apr 07, 2012 07:38 AM
Discussion BEC & aux power can it safely be done? Show 871 Power Systems 5 Mar 29, 2012 04:11 PM
Discussion This can be done with RC Belive me Kr1st1an Aerial Photography 5 Mar 09, 2012 10:54 AM
