Espritmodel.com Heli Air
Old Nov 12, 2012, 04:43 PM
Joined Nov 2012
Want to build a swift
Anyone Got plans for a maxiswift lookalike. I Will try to build one of depron to use with my spare edf motor :-)
And fly it with 2200mah 3s battery
Hope to get some more Info about my thoughts :-)
Cheers
Donkanan is offline Find More Posts by Donkanan
Old Nov 13, 2012, 02:48 AM
doggit's Avatar
northenden, manchester, england
Joined May 2009
hey Donkanan, this is not a plan, but it is a calculator that will give you all the measurements and a picture of the wing, and you can then draw it out onto your foam its very easy to do, you open up the zip file then open up the kesel calc.exe file and then just put in the span you want and it will generate a picture with all the measurements for that span, then use your ruler to draw all the numbers and cut out, this is a KFM foil hope it helps
carl
doggit is offline Find More Posts by doggit
Old Nov 13, 2012, 04:48 AM
Joined Nov 2012
carl
Hey doggit. I thank you for the thoughts. But i dont Think i am extérieures enough to scratchbuild Like That. I. Would rather try to make a wing That matches an exixsting one :-)
Mostly because it Will be alot easier to get In balance. Got to say
I am a noob scratchbuilder
Old Nov 13, 2012, 10:34 AM
doggit's Avatar
Joined May 2009
hi Donkanan, well i would say that to build a swift you will have to be able to use a hot wire cutter, and get an airfoil template, it takes some skill to do that, and have a look at the KFM airfoil thread, its the easiest foil to make as it is flat pieces added on top of each other, http://www.rcgroups.com/forums/showthread.php?t=1117276
it does not matter which airfoil you choose to balance them, they are all the same to balance, and if you do scratchbuild one yourself, you can use the cog calculator here http://fwcg.3dzone.dk/
carl
Old Nov 13, 2012, 01:41 PM
Never trust laughing dolphins
Joined Feb 2011
Getting a Maxi Swift build with no real plans might be a challenge though. Its not entirely flat, but has wings that are tilted slightly downwards. The foil has a sweet curve too, quite tough to match. Not impossible though. I'd love to see how far you'd get with this.
PHMX is offline Find More Posts by PHMX
Old Nov 14, 2012, 09:19 AM
Joined Nov 2012
i didnt say i would build it from one piece. i want to cut out spans and make a profile bend of 3mm
hasnt anyone build a nice flying wing from only foam and carbon ?
Old Nov 14, 2012, 09:31 AM
doggit's Avatar
Joined May 2009
try searching in the foam scratchbuilders http://www.rcgroups.com/foamies-scratchbuilt-428/
Old Nov 14, 2012, 09:33 AM
Joined Nov 2012
the last week i have tried to find something like it
Old Nov 14, 2012, 09:42 AM
doggit's Avatar
Joined May 2009
and you didnt find anything you liked , i am surprised at that, maybe you need to amend your choice, did you look at that KFM thread, there is nothing as simple as the KFM foil, or failing that buy a wing they are not expensive
Old Nov 14, 2012, 10:57 AM
Joined Feb 2011
Not in one piece, but the two wing cores will still need to line properly, preferrably with the curves I've mention and downward fold. I wasn't ever trying to disencourage you though. Built and have fun, you'll figure it out and part of it is doing the research you do right now.
Old Nov 14, 2012, 03:45 PM
Joined Nov 2012
I have fund a lot of pictures That i Like. But no plans for the actually build.
I Think i Would Like to build it Like If it Where balsa. Just use depron instead.
After searching some more ón kfm foils i Think i Will try the kfm4 but i cant find any plans.
Old Nov 15, 2012, 03:20 AM
doggit's Avatar
Joined May 2009
here are a couple of wings that use the KFM foil, i have built and flown them and they are great for beginners to experts, and they have PDF plans
http://www.rcgroups.com/forums/showt...ighlight=divin
and this one is not quite KFM but may interest you to build, it has build videos too
http://www.rcgroups.com/forums/showthread.php?t=1619684&highlight=flying+wing
have a good read, and just try one, you will get more involved as you build more, then you can design your own once your happy with building them, i hope these help you
carl
Old Nov 19, 2012, 08:40 PM
United States, WA, Moses Lake
Joined Feb 2012
Here is a nice thread for a swift 2 kf4 wing. 32 inch wing span maybe a little smaller than what you want but easy enough to scale up and very good build thread. http://www.rcgroups.com/forums/showt...highlight=kesl
Low and Slow is offline Find More Posts by Low and Slow
Old Nov 20, 2012, 05:35 PM
Joined Nov 2012
Thank you very much everyone. I ended up building an ultra micro version with inspiration from the little wing called David and another wing made of a friend of mine :-)
It flies great with the guts from halfdead sukhoi :-) 400mm wingspan and a weight of 30 grams
I Think i Will go for a larger scale of it as a next project.
Old Nov 20, 2012, 09:18 PM
Gravity Sucks
Somewhere in the Nations Capital
Joined Sep 2007
Hi Donkanan,
sorry a little late. See you have already built something, but may be of intetrest to you (either still or in the future).....
Try having a look at Leadfeather's Firefly, similar to swift, could suit your OP request, easy to build and fly great....
ResQ is offline Find More Posts by ResQ
Discussion Swift Boat Build Swift16 Micro and Sub-Micro Boats 33 Feb 15, 2013 05:24 PM
Build Log Swift 3D, inside: my building strategy RCvehicleGuy 3D Foamies 17 Sep 18, 2012 05:19 PM
For Sale Swift NX, Swift 550 Carbon, Swift 16 - Parts (NEW) shipping CONUS LowWatts Aircraft - Electric - Helis (FS/W) 0 May 19, 2012 12:09 AM
Wanted MS Composite Swift 2 wanted Davidpe Aircraft - Electric - Airplanes (FS/W) 3 Mar 31, 2012 10:31 AM
