Old Dec 08, 2003, 07:54 PM
torcgolf is offline
Find More Posts by torcgolf
PiLoTuS pArKfLyIcOuS
torcgolf's Avatar
Dub Cee, California
Joined Aug 2002
which prop adapter do i need for an omega 1.8?
i just picked one up and the prop adapter doesnt seem to fit flush with the front of the fuse. im new to e-sailplanes so i dont know what i need exactly.
right now the spinner or cone seems to be a lot bigger than the nose of the fuse, thats the best way to describe it. looks funny and i bet will cause more drag. it also sits way forward and there's a larger than usual gap between the back of the spinner and the front of the nose.
typically, how/what do you measure to get the proper fit? is it the diameter of the most forward part of the fuse?
please help
torcgolf is offline Find More Posts by torcgolf
Old Dec 09, 2003, 08:10 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Motor needs to be set back so there is very little gap between the spinner and fuselage. Small washers can help here, or a second bulkhead glued behind the first (measure first!!)
Spinner diameter (at it's widest point) needs to match the diameter at the front of the fuselage.
You choose the appropriate size spinner when you order the parts.
Here's a shot of a motor pushed back a little by an additional ply bulkhead (really a spacer - it's not glued to anything) mounted behind the factory-supplied motor mound (which is flush with the front - not ideal in most cases). The Graupner spinner/collet-style prop adater fits over the exposed mount bolts just fine (but many others will not).
Click to enlarge
..a
Need a fuse for an Omega 1.8 v-tail Mike in Fresno Aircraft - Electric - Airplanes (FS/W) 3 Apr 06, 2005 04:02 PM
Which brushless for an Omega 1.5E to pull 10 amps? GliderGuideMan Electric Sailplanes 10 Jul 02, 2004 05:29 PM
Which Hacker for an Omega 1.8 stevegarlick Electric Sailplanes 3 Jul 30, 2002 09:48 PM
Anyone want an Omega 1.8 for $225 Speedfreak Aircraft - Electric - Airplanes (FS/W) 3 Jan 06, 2002 12:28 AM
How big a field do I need for an Omega Electric? jimbarstow Electric Sailplanes 1 May 21, 2001 03:20 PM
