Old Nov 12, 2012, 01:59 PM
UlteriorModem is offline
Find More Posts by UlteriorModem
UlteriorModem's Avatar
Joined Aug 2011
Bonding nylon / delrin
I have a glider which has a plastic nose cone. I believe it to be nylon or a close cousin to nylon.
Is there an adhesive preferably a solvent type that can be used to fix some cracks?
Nothing bonds to the stuff. Not cyanos, hot glue, epoxy, silicone, even acetone doesnt touch it.
UlteriorModem is offline Find More Posts by UlteriorModem
Old Nov 12, 2012, 05:15 PM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I haven't found anything yet -I'm surprised it cracked. They usually just bend..
You might try a soldering iron and see if it'll "weld"....Try a little inside with some extra plastic from something else.
epoxyearl is online now Find More Posts by epoxyearl
Old Nov 12, 2012, 05:38 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Try Goop from the hardware store.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Nov 12, 2012, 06:00 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
how about pvc cement, like you would use for drainage pipes? or tenax 7R - that glues up plastics really nice
I wouldn't think delrin could be formed into a nose cone, unless its milled from a larger piece.
jonquinn is offline Find More Posts by jonquinn
Old Nov 12, 2012, 09:00 PM
edwin1 is offline
Joined Sep 2003
I've used pipe glue and fiberglass cloth, it worked but stinks a lot while you're doing it.
Edwin
Old Nov 12, 2012, 09:41 PM
kenh3497 is online now
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I've "welded" many a plastic item using a soldering iron. Everything from motorcycle fairings to riding mower grills. Glue in may cases, like yu found out, just won't stick.
Use the iron and place the tip across the crack until it melts and penetrates at least 3/4 of the thickness. After you made several stitches, go back and smooth it as best you can with the iron. Continue until the crack is closed. Try it on some scrap first to get the hang of it. Sand and apply filler and paint to make it look pretty.
Ken
kenh3497 is online now Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old Nov 13, 2012, 06:14 AM
AL_T is offline
Find More Posts by AL_T
Maryville, TN
Joined Dec 2007
Just a caution. Google "delrin and formaldehyde". Can give off nasty fumes when heated.
AL_T is offline Find More Posts by AL_T
Old Nov 13, 2012, 09:57 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Yep on the fumes. Do the soldering iron "welding" outside. Also the times I've fixed some motorcycle bits with heat welding I used a lamp dimmer wired into an extension cord that I made up years back as a heat controller so it's not TOO hot. You want to melt and form without making the plastic turn black.
BMatthews is online now Find More Posts by BMatthews
Question Glue for bonding nylon and aluminium? (Skywalker PT) boopidoo FPV Talk 18 Sep 20, 2011 01:11 AM
Careful! "Bond, James Bond" flying a SLOPESTREAM! Chief High Horse Slope 95 Jan 11, 2008 12:51 AM
