Old Nov 12, 2012, 01:35 PM
See is offline
See
Find More Posts by See
See
Joined Mar 2012
Data Recorder Software crashes after downloading Date from logger
hey there,
Iam trying to download the actual data logged on the elogger v4...
When I open the Date Recorder I click on "load data" and then it shows a download bar.. 98& from 2MB filled and it starts downloading.. after that it shows "converting data" and after about two minutes the software crashes and shuts down....
what can I do??
best Sebastian
See is offline Find More Posts by See
Old Nov 14, 2012, 02:41 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Sebastian,
Sorry to heart about the issue. Can you let me know what version of our software you are running (under help/about)?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 15, 2012, 12:20 AM
See is offline
See
See
Joined Mar 2012
Originally Posted by billpa View Post
Hi Sebastian,
Hey,
it is 10.04
best
Seb
Old Nov 15, 2012, 03:39 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Seb,
There are a couple of things to try (in the order you prefer):
a) If you click "Advanced, Delete all eagle tree settings" it is equivalent to a fresh start. This would wipe out any potential settings that might be causing the issue.
b) You may want to try our beta software version 10.43, located here. It's possible that some change we've made have addressed this issue.
If neither of these work, it's probably going to be necessary to delete the data out of the logger, using the "clear recorder buffer" option, as it's possible the logger's data buffer has become corrupt.
Site Sponsor
Help! EagleTree Data Recorder Crashes RCTime Eagle Tree Systems 12 Mar 21, 2012 04:21 PM
Discussion V3 Data Logger Records Wrong Volt & Amp Data tsurt Eagle Tree Systems 12 Jan 22, 2011 01:01 PM
Discussion Data Recorder Software crashes after Download Telefisch Eagle Tree Systems 16 Jul 30, 2010 11:29 AM
Discussion Download the log from "Flight Data Recorder Pro" AeroSign Eagle Tree Systems 8 Mar 16, 2010 10:51 PM
Help! download data from RAM 3 altitude logger 320pilot Sailplane Talk 4 Jul 27, 2009 05:05 PM
