Espritmodel.com Heli Air
Old Nov 12, 2012, 01:29 PM
Plane and simple
RPM314's Avatar
Joined Apr 2012
RC Lancer-rubber powered
Hi, all. I was thinking of building a Lancer for RC, but keep the rubber power so stick time is not limited by those batteries' nasty habit of discharging. I've never seen it done, and was wondering if it's a bad idea, or if it's not, the best way to go about it.
The Rx and battery could go in the top of the cabin, and the servos could go in the sides of the fuse with the arms coming out of the top, they probably would not interfere with the rubber there. Or maybe the rubber could be lowered and the servos put laying down in the top.
RPM314 is offline Find More Posts by RPM314
Old Nov 13, 2012, 09:54 PM
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i can be done, but battery tech is pretty cheap. with Electric power you can build the airframe lighter, an dget longer flight times.
rubber powered can be done, its just never been done cuz its a step backwards.
i say go for it.
nemoskull is offline Find More Posts by nemoskull
Old Nov 14, 2012, 01:39 AM
perttime's Avatar
Tampere, Finland
Joined Nov 2004
With rubber power, your flight times will be shorter and you'll spend a lot of time winding.
I'm pretty sure you'll get more stick time with electric.
perttime is online now Find More Posts by perttime
Old Nov 14, 2012, 06:18 AM
Plane and simple
RPM314's Avatar
Joined Apr 2012
I'm aware of the flight time constraint, but the endless supply of flights (provided you have replacement rubber), I think, balances it out. The main reason I want rubber is that my RC fund has suffered serious budget cuts, and this can be done for under $40.
As for winding, I could make a two pronged thing to put on a collet adapter instead of a prop, and wind the band most of the way with a motor.
Old Nov 14, 2012, 07:41 AM
perttime's Avatar
Tampere, Finland
Joined Nov 2004
There were some discussions on rubber powered R/C in the Free Flight forum. Here's one:
http://www.rcgroups.com/forums/showt...ighlight=radio
My impression is that the best bang for the buck would be a glider, instead of a rubber powered model. You can get a glider in the air very quickly with bungee or towline, and the glider doesn't have to carry the weight of the rubber or motor.
Old Nov 14, 2012, 10:59 AM
mcm1303's Avatar
Houston, Texas
Joined May 2007
I think you could make a very successful R/C rubber airplane for outdoor flying. If you build an old time rubber airplane like the Gollywock that has a high fast climb and a folding propeller then you could launch the plane and when the propeller folds you have a nice R/C glider that can stay up for a couple of minutes or much longer if thermals are present.
mcm1303 is offline Find More Posts by mcm1303
Old Nov 14, 2012, 03:19 PM
Plane and simple
RPM314's Avatar
Joined Apr 2012
Maybe next time. Remember, dirt cheap.
Hey, is it possible to use rubber longer than the fuse if the propeller is kept from coming out?
Old Nov 15, 2012, 10:21 PM
nemoskull's Avatar
Joined Sep 2009
i dont know. your getting in to the free flight stuff . check there forum out for contsruction and practical tips.
this does sound cool, i must admit.
Old Nov 16, 2012, 05:53 AM
Plane and simple
RPM314's Avatar
Joined Apr 2012
Will do. Thanks for the help, I'll be ordering parts tomorrow. Do you want pics?
Old Nov 17, 2012, 04:54 AM
nemoskull's Avatar
Joined Sep 2009
yes please! i want to see how this turns out.
Old Nov 17, 2012, 08:03 AM
Plane and simple
RPM314's Avatar
Joined Apr 2012
Alright!
Dang-parts order has been delayed till next week.
Old Nov 17, 2012, 06:45 PM
United States, WI, Slinger
Joined Mar 2006
The rubber motor is always longer than the fuse, usually several times the fuse length.
MikeCr is offline Find More Posts by MikeCr
Old Nov 18, 2012, 09:14 PM
Plane and simple
RPM314's Avatar
Joined Apr 2012
That's before stretching, right?
So, since the Lancer has ~18" of space in the fuse for rubber, then 3-4 feet of rubber?
Old Nov 19, 2012, 05:59 AM
Joined Mar 2006
Yes, the length is w/o stretching it at all, I would say double the length of the fuse..
Old Nov 19, 2012, 03:12 PM
Plane and simple
RPM314's Avatar
Joined Apr 2012
Then I should probably go up to a 7" prop instead of the stock 6".
Discussion The "Maggie"-Rubber-powered RC airplane builderdude Parkflyers 85 Jan 15, 2013 08:29 AM
Build Log Guillow Lancer RC Conversion ElectroAviator Indoor and Micro Models 10 Jan 03, 2013 01:21 PM
Discussion Rubber powered Wright Flyer- possible rc conversion? shagrug Indoor and Micro Models 17 Aug 22, 2012 12:39 PM
Build Log Rubber Powered Free Flight Conversion to RC mark1968 Parkflyers 0 May 28, 2012 11:41 PM
Discussion Guillows Lancer RC Conversion *Power Questions* finchkid24 Indoor and Micro Models 22 Jun 02, 2009 02:37 PM
