This thread is privately moderated by Dani123, who may elect to delete unwanted replies.
Old Nov 12, 2012, 01:20 PM
Dani123 is offline
Find More Posts by Dani123
Dani123's Avatar
Israel
Joined Jan 2005
Mini-HowTo
mini regulator - going SMD
Back to my search for small and lightweight 2S lipo regulator, I've found this tiny AMS1117 unit, which is surface mounted component.
It regulates voltages as high as 12v down to 5v. It is very tiny and light, the downside it is only 1A current rated.
I gathered the required components and soldered it this evening. First of all, SMD component are really easy to solder , there is really nothing complicated when you have the right tip for the soldering iron (there are great videos at YouTube).
For now I had this electrolytic capacitor, later I will replace it with tantalum one,which is smaller and lighter.
As you can see, the most weight is from the connectors and wires, the unit works. Later I will put some shrink at it.
Dani123 is offline Find More Posts by Dani123
Old Nov 12, 2012, 01:36 PM
Dani123 is offline
Dani123's Avatar
Israel
Joined Jan 2005
one last thing - my test bench
Just wanted to introduce my 'high tech' test bench for the stuff I do.
I have this servo tester which can cycle continuously three servos, I feed it with 2s lipo through the regulator, I monitor the voltage at the input (left meter) and at the output (right one), also I measure the total run time with the timer and I check the regulators temperature (by hand) - it should get warm but I should be able to touch it. Once this setup works for 2-3 hours, I feel comfortable to put the reg in my DLGiis.
Dani
Discussion Walkera Mini CP tail motor not going Samw5 Micro Helis 7 Sep 14, 2014 09:12 AM
Sold Bambucopter Mini Y6 FPV Frame with A1510 Motors, Simonk ESCs, SMD Leds daign Aircraft - Electric - Multirotor (FS/W) 6 Sep 30, 2012 07:35 PM
Found 12V Voltage Regulator (mini/compact) flyandi FPV Equipment (FS/W) 5 Jun 07, 2012 04:15 PM
For Sale SMD Soldering Hot Air Rework Station Mr.RC-CAM Non R/C Items (FS/W) 0 Apr 29, 2012 11:35 PM
Help! Racewood 900MHz video tx - need to identify damaged SMD component altek DIY Electronics 6 Feb 27, 2012 10:46 PM
