Old Dec 08, 2003, 06:06 PM
AllenS is offline
Find More Posts by AllenS
Flt 76..N.bound..feet dry
AllenS's Avatar
Baltic CT, USA
Joined Dec 2000
3S series li-pos ESC cut off voltage
Which is correct? Castle Creations instructions read 7.2 volts for 3 series packs, but common practice is 9 volts
AllenS is offline Find More Posts by AllenS
Old Dec 09, 2003, 12:43 AM
myk is offline
myk
Find More Posts by myk
myk
myk's Avatar
Lake Sawyer, Washington
Joined Jul 2003
Do a search in this forum, this topic has been covered many times, however the short answer is 9v, CC is updating its manuals now I believe.
myk is offline Find More Posts by myk
Old Dec 09, 2003, 01:42 AM
Awakened is offline
Find More Posts by Awakened
Nimble with Gimbals
San Diego, CA
Joined Apr 2003
Thunder Power also recommends that their packs NEVER get below 2.9V per cell under load and never below 3.3v at rest. You should set your power system up accordingly.
Awakened is offline Find More Posts by Awakened
Old Dec 09, 2003, 03:29 AM
Greebe is offline
Find More Posts by Greebe
radar jammer
Greebe's Avatar
Bradenton, Florida
Joined May 2003
9v is correct... what little is left you'll need to get on the ground safely
Greebe is offline Find More Posts by Greebe
ESC cut-off voltage for 3S lipo? eta Batteries and Chargers 4 Apr 28, 2005 06:55 AM
Cut off voltage for Li batteries w/Phoenix 25 gquiring Batteries and Chargers 5 Oct 13, 2003 07:17 PM
Dymond Super Turbo discharge cut-off voltage JohnM Electric Plane Talk 5 Apr 29, 2002 08:11 PM
Range check adivice - short range after BEC cut off !!! JensJakob Foamies (Kits) 0 Aug 08, 2001 01:38 AM
Jeti JES 18-3P Cut Off voltage mumblety-peg Power Systems 2 Jul 06, 2001 12:20 AM
